When do you replace a battery?
/ When do you replace a battery? #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
Do you wait until the vehicle will not start, or do you use other criteria?
/ When do you replace a battery? #2
This year my battery was going bad. So knowing that i stuck a deep cycle battery in back of my truck. At work it fail, hook the deep cycle battery up made it home. Then i went out an got a knew one. I ran that battery as far as i could.
/ When do you replace a battery? #3
If an older (3-4 years) and jumps OK (meaning the vehicle starts) but requires another jumpstart by the following day, it's time to get the battery checked...and probably replaced.
If a newer battery...might be some else in the charging system.
/ When do you replace a battery? #4
I wait until it wont start. Then I have to jump it, and next time I use said vehicle, (provided it hasnt sat like more than a year), if I have to jump it again, I replace the battery.
Last year I was facing a winter with three five year old batteries in my vehicles. I have one of those computerized tester and all showed OK. I went ahead and replaced the one in the wife's van and the Power Trac. This year I replaced the one in my vehicle.
My wife's cousin asked me to test his battery after slow cranking. It tested as 160 CCA on an 800 CCA battery. So we replaced it. Strangely, he had some error codes for his oxygen sensors heating circuit that cleared up with the new battery. I suspect the low voltage on the electrical system right after cranking confused the engine computer.
/ When do you replace a battery? #6
I change them out before I critically need them if 3-4 years have gone by. Example if I'm going on a long trip and the batteries have some age I swop them out. When I was in snow Country I definitely swapped them out prior to winter.
At the price of batteries at Costco you can't go wrong and your life would be miserable if your battery died in some strange town of the middle of snow storm.
Yesterday I bought a 900 CCA battery for $80.00 on my tractor with a three year warranty.
/ When do you replace a battery? #7
I have a 2001 dodge ram with the original battery in it. Every year before winter I think I should replace it. But I just want to see how long this battery will go. I have a buddy who runs a auto parts store. He said 11 years was the longest battery he new of. I just hope the battery will give me signs (slow cranking) before it dies so I can replace it before it leaves me stranded. If your charging system is doing its job a battery should last quite awhile.
/ When do you replace a battery? #8
The battery in my 12 year old B1700 was still good when i sold the tractor.
As far as my vehicles, i carry jumper cables at all times, even in my new truck.
I feel no urgency to replace a battery till i have to
/ When do you replace a battery? #9
My 2001.5 Dodge has TWO HUGE original batteries in it.... [ did I mention that they were BIG ]... I hope they last ... forever...!!! So I am with you.. bro :)
/ When do you replace a battery? #10
I would say that 95% of the time a battery will have weak cranking or be unusable before I discover it. I do regular checks of electrolyte levels, but rarely do specific gravity tests unless something is suspect. For most cars, carrying a jumper battery with air compressor is a safety valve for when the battery goes south. With my diesel, I've been stuck once due to some dummy :rolleyes: leaving the door ajar all weekend so that the interior lights ran down the batteries, but that was hardly the batteries' fault. That required a tow because Mr. Rescue couldn't even turn over the engine with his weenie jumper battery.
/ When do you replace a battery? #11
We have a [pair of 2004 GM cars that still have the OEM batteries at 60,000 miles, I am planning to replace both when the weather gets warmer as I am pretty sure they will not last much longer. The OEM battery in my Y2K GMC started going bad at about 7 years old, it was not holding a charge well. As for my Deere, I was so sick of the vent caps spewing acid and corroding the battery compartment I had the dealer replace it under warranty, sold the brand new replacement and used the money to buy a SEALED battery. That one has lasted 7 years now, going to replace it at 8 years.
/ When do you replace a battery? #12
My wife still has the original 1998 battery in her Subaru Outback. I've never seen a battery go that long in my entire life. She says she will not get a new one till this one dies. So, long story short, you just never know how long they'll last. There are times that years don't count in a battery's life I guess.
/ When do you replace a battery? #13
I brought my Expedition in for an oil change a year ago last fall. They measured the battery and said I should get it replaced because it was reading low. I said it was still cranking well and I'd keep it a while longer. The next oil change I asked about the battery and they said it was still good. I questioned their different recommendations and they admitted that their tester had been faulty a few months before. So 15 months later, I'm still on the same battery.
/ When do you replace a battery? #14
I never change a battery till it needs it.
I typically get 8 to 10 years out of car/truck/tractor batteries.
My wifes car battery lasted about 8 years.
My last truck battery lasted 10 years. The original battery in my 10 year old tractor is still going strong..
/ When do you replace a battery? #15
Depends on many factors; how far in the booney's you live, do you have a another vehicle with a good battery to jump with, how many times the wife has said " I told you to replace that old battery before it quits" after they do, etc.
Cleaning the contact terminals and putting a little dielectric grease on them
every year lets a weak battery have a better chance of starting the engine.
On my old tractor, which has a battery as big as 4 car batteries and costs about as much as 4 car batteries, keeping a trickle charger on it in the winter as well as using the block heater when it is really cold has kept it working fine for many years.
The newer tractor is like a car with all kinds of electrical clap-trap on it that drains the battery over time with just a few operating hours in the winter so I have started using a trickle charger on it too. It has an intake heater to the turbo which draws current in cold weather at start-up so it needs to be fully charged and ready to go. I also plug in the block heater when it's really cold so the tractor starts as if it were in Texas heat.
/ When do you replace a battery? #16
I change mine when it is bad, but can see someone being a bit more proactive than that if the vehicle is used by another person, or if the winters are harsh.
You mentioned a new battery making some other issues go away. I have seen ABS errors go away on a BMW motorcycle. It tested its ABS system so quickly, I doubt the starter had stopped spinning. And a battery that had always started it, and still would too, that battery was just weak enough to cause the error.
I verified that by using booster cables...every time the cables were attached while starting, no ABS error, but removed while starting => error.
/ When do you replace a battery? #17
The last battery I changed was a Costco battery for my tractor, it lasted 7+ years on the 7yr warranty. That include too many time leaving the key on in the daytime and not seeing the little light was on:laughing: come back dead as heck, jump it and kept going. New Costco one has a 8 yr warranty:thumbsup:
/ When do you replace a battery? #18
By 7 and 8 year warranties, I assume you mean PRO-RATED and not free replacement? A pro rated warranty, by the time it nears the end, is almost worthless as you get such a tiny credit toward a new battery, and in the meantime the battery has increased in price a lot more than the credit you are given. My replacments are almost always the Wally World Everstart Maxx models, about three or four years ago they had a full 3 years replacement warranty but then back in mid 2009 they lowered it to 2 years.
I would investigate Costco batteries, but there are none of their outlets in mid-Michigan that I am aware of.
/ When do you replace a battery? #19
I am a retired truck driver. When I needed a jump after an overnight trip I bought a new battery (-20F, VW Diesel). But then I always had ready access to a jump. For my wife I replace after six years because getting a jump would cost as much as a battery.
/ When do you replace a battery? #20
You've got to keep jumper cables in your car...and know how to use 'em.
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2007 Toyota Camry Sedan (A61574)
2007 Toyota Camry...
Caterpillar M318 Excavator Service Manuals vol. 1 and vol. 2 (A63117)
Caterpillar M318...
