Cheap Cutoff Saw
/ Cheap Cutoff Saw #1
rmully
Gold Member
North Carolina
YM 2020
What would you recommend for an inexpensive cutoff saw? Are used ones a big gamble?
/ Cheap Cutoff Saw #2
I've had good luck with the best HF chop saw, once I got a name brand blade on it. Note that HF has three qualities. I have not hear good things about the cheaper ones.
This is the one I have, 68104: 3-1/2 HP 14" Industrial Cut-Off Saw
Got mine for $80 a couple of years ago.
/ Cheap Cutoff Saw #4
How much of a difference did you notice with a "name brand" blade? What brand did you get?
I bought a Norton cutoff wheel at Home Depot. Big difference. I had to really lean on the saw to get it to cut with the HF wheel and the wheel started getting hot, the Norton just cuts.
/ Cheap Cutoff Saw #6
Dad bought a DeWalt back in the late 80's, and I'm still using it. And I've cut a LOT of metal with it..!! Of course, that's not saying thye are of the same quality today...
Don't even bother with the cheap Chinese blades. You'll get a good cut for the first inch or so on the blade, then just dust from the blade, then back into more hard abrasive for a while.
For cheaper blades, I have the best luck with the DeWalt blades. I usually shop online, or go to Epay, and find a deal on a full box, of lke 10.
/ Cheap Cutoff Saw #8
Wait for a sale and use the 20% coupon, always available at this site:
Actually, I meant the blade. I was in Tractor Supply last weekend and they had a closeout on a 14" saw for $49.99. I really wasn't in the market, but I decided not to pass it up. It cuts better than anything else I've got - nice square cuts - but I was wondering about a better blade, and you helped me decide. Thanks again.
/ Cheap Cutoff Saw #9
I bought a Makita chop saw, and strongly agree about buying the good discs, the cheap ones wear out quickly and overheat the metal if it is of any size.
I use a spray bottle top cool it, but have given up on cheap discs.
I have heard good things about the Milwaukee
/ Cheap Cutoff Saw #10
You might as well spend the money for a good saw, because when you buy the cheap one and find out it sucks , your going to end up buying a good one anyway... I have used a friends HF chop saw, and about killed it cutting 4 inch exhaust pipe... My Ridgid would not even have balked at that little job !
WALK OVER LADDER (A68842)
WALK OVER LADDER...
2015 COTTRELL CAR HAULER (A67714)
2015 COTTRELL CAR...
2009 FORD CROWN VICTORIA POLICE CAR (A66091)
2009 FORD CROWN...
2023 CATERPILLAR 920 WHEEL LOADER (A65056)
2023 CATERPILLAR...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
