Rear Blade Frontier Land Plane
/ Frontier Land Plane #1
markwillcott
JD 5105
I'm giving up on the box blade for trying to get our road and the new pasture level. The local Deere dealer has a Frontier LP1172 that he will give me for $1,000 plus tax.
My question is do i want a 6' or a 7'? We have a JD5105 and a 6' is going to ride in the tire tracks as near as i guess, a 7' would ride outside the tracks and i thought might level a bit better.
Seems like a reasonable deal, but wanted to solicit opinions.
MRW
/ Frontier Land Plane #2
I have an LP1196 that I use with a 5105 that I just purchased. The rear tires are set at 6 feet center to center. The rear tires outside to outside are about 7 feet wide which gives the land plane about 6 inches of overlap on each side of the tractor.
Measure your rear tires outside to outside and see what you need. I do recommend that the land plane at least cover the tire tracks.
And attached is a pic of the newest part of the pasture that could do with some help.
I do like the deal the guy is offering us, but the wrong implement won't seem so affordable later when i'm not happy with it....
MRW
/ Frontier Land Plane #4
6 foot land plane
Where are you located??? 6 foot, frontier, like new, land plane $750
I don't know this seller... (although, pretty sure he's a dealer :mad:)
Aint that always the way... I'm down here in Houston.
/ Frontier Land Plane #6
Mark,
I use my landplane all the time and it is one of the handiest tools you can have for smoothing up drives and fields. I use mine primarily to smooth out lawn and pastures and built mine with straight set blades. Works extremely well for removing mounds and filling dips. I built this one in 2009 for about $900 to $950 with 96" double edged reversible grader blades. Weighs about 950 lbs and has skids that are 60" in length. I use this with my 4520 which is ballasted to about 5500lbs. Works great with a tractor of this weight and should work well with a 5105 ballasted. I limited mine to 8' blades so that my overall width is 102" for trailering and transport.
Several of us on the forum have found that wider is better because planing with a wide blade in opposing directions will give you a flatter finish. Same with longer skids, which average out the ground better. So the long and the short of it is get the largest plane you can. I prefer a plane with a lot of structural strength and rigidity and about 125 lbs/ft of width so mine is heavier than the Frontier.
Here are pictures of the 8ft landplane, 8ft spiked tooth harrow I built and my lawn that I used the landplane on to smooth it out.
/ Frontier Land Plane #7
The blades aren't adjustable on the Frontier and though maybe not as important, it doesn't have rip blades either. The Land Pride and Agri Ease both cost the same and have both those features. There all probably from China.
/ Frontier Land Plane #8
No, they're not from China. Don't make assumptions unless you know for sure.
/ Frontier Land Plane #9
Nice work on the Land Plane jenkinsph!
/ Frontier Land Plane #11
AgriEase is from China and LandPrides is identical to it so I presume it is - don't know about Frontier. There's been worries about excessive/premature wear on the blades and teeth of the LandPride unit. I'd suggest it's due to China's inferior metal.
/ Frontier Land Plane #12
I have no idea who builds the Frontier landplanes so I won't speculate on this. I can say that when building mine that the two 6"x96"x5/8" double edged blades were about $440. With plow bolts this amounted to about half the cost of the materials. With almost three years of moderate use there is no appreciable wear on the blades and no notches.
/ Frontier Land Plane #13
Dredging this thread back up from the dead... :)
Anyone else using a Frontier land plane? I like the price of the LP1172, but I like the weight of the LP1207 a lot more! :D
/ Frontier Land Plane #14
I have the LP1172 as seen in my signature below and wouldn't use anything else to maintain my slightly less then 1000 ft driveway. A box blade is not the right tool for this job and requires interaction by the operator to raise and lower the box blade to obtain the same results the land plane would obtain with no interaction
2021 Topcat SSSTG200 Stump Grinder (A62679)
2021 Topcat...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Cattle Feeder (A65640)
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Bucket (A64194)
Bucket (A64194)
