caster wheels on plow
/ caster wheels on plow #21
The solid rubber tires I have have tread and look just like the pneumatic ones so gripping is not an issue.
Are they like a never flat wheel barrow tire?
/ caster wheels on plow #22
All the wheel barrow tires I've seen just have grooves around the circumference of the tire. These solid rubber tires actually have tread on them. The rubber is somewhat firm. Probably like a pneumatic tire that is pumped to it's max rated pressure. The picture I posted is not very good for looking at the tires. I can take another tomorrow and post and probably figure out who I bought them from if you're interested.
/ caster wheels on plow #23
No thanks, I am just curious. I am perfectly happy with what I have.
/ caster wheels on plow #24
I am searching for the same solution. I have a Frontier front blade that I want to pull the shoes off and insert same style with a roller. My use is on hard surface and don't want to score it up. Keep me posted on your solution.
Gary, I just bought the AF11 Frontier blade for use on my JD 1070. Nice set up, save for the fact that the standard skid shoes dig right into the pea stone driveway. I would like to mount some adjustable pneumatic casters on the plow, using the same pipe brackets that the skid shoes go in. Did you ever set up your Frontier blade with casters? Any luck?
2018 Johnston C201 Compact Street Sweeper (A61572)
2018 Johnston C201...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
NEW CAST IRON FARM BELL KIT (A64281)
NEW CAST IRON FARM...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
