Attachment kick stand
/ Attachment kick stand #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I wasn't sure what else to call them. I found these a my local trailer parts store. I paid $35 for a pair. I bought them for a different project that didn't work out. I had been looking for a good way to make stands for some of my attachments. These fold up out of the way. They lock in either position. When they are down they extend from 12" to 19" . If you look on ebay under stabilizer jacks they make them in different lengths.
Bill
/ Attachment kick stand #2
I have busted off two kick stands by forgetting to raise them when I took off. don't have to have a full set of brains to run a tractor I guess:laughing: since I put my implements in the same spot all the time I have a 4x4 cut to the right hieght that way when I drive off I don't break anything:D
/ Attachment kick stand #3
I welded on a trailer jack from harbor freight on my rear blade. Swings out of the way when connected. Since I don't have a quick hitch I have to get off the tractor to attach the blade so I don't forget to swing the jack too!
/ Attachment kick stand #4
Nice Job :thumbsup:
/ Attachment kick stand #5
Good idea!:thumbsup:
Those look like the stands I had on an old crank-up camper in the past. Mine would let you jack the camper up, using a steel rod for an handle.
If anyone is looking for something similar, you probably could find them at a RV supply place, or order them from a RV supply house.
/ Attachment kick stand #6
Bill
Great idea, they look real sturdy.
/ Attachment kick stand #7
Bill
Looks good, they look like the stands for the back of trailers, so the tongue doesn't rise when you drive on the ramps.
That's what I did on my rake and back blade. Made it easy to inch it up or down when needed while hooking up. but now I have HTL with quick hitch so I don't need the incremental movement. still works fine but so would any pipe or stand.
These are the type that can swing up or just come off, a short section of tube is welded on.
JB
/ Attachment kick stand #8
You won't get ONE decent trailer tonque jack around here for $30, but I do have a couple of old campers out back. Gonna take a look at them tomorrow as I have a couple of light trailers that are just crying for tonque jacks that will fold easy....
/ Attachment kick stand #9
Look good!
I've been using them on my blade and rake for a few years now (post of my install) Here and they've worked out well.
/ Attachment kick stand #10
/ Attachment kick stand #11
Bill
Does that have a spring latch to hold it up? I had made one for my BB and while grading the blade jumped, jack folded down and it ripped off. Back to using a 4x4 block :eek: I would hope yours has a good latch (it is intended for trailer use) but the motion of a rear blade can be a lot more violent than a trailer tongue.
I now make them with a through pin - can get dislodged.
/ Attachment kick stand #12
my jb batwing mower ha sthe lil round nub for a trailer jack on it, so you can swing it up and back when needed.. nice deal...
/ Attachment kick stand #13
Bill
Nice job:thumbsup:. I've used trailer tongue jacks for the same purpose.
