What rod/amps to use?
   / What rod/amps to use? #21
local liquide aire gets them here...
I'm in a 10,000 pop town. Can't get too much unless I drive an hour to the major metro areas. eBay and mail order stuff is sometimes the best/fastest way to get something. Or make due with what you have on hand or easily accessible.
   / What rod/amps to use? #23
on the other hand.. you get to live in a nice cozy small town environment.
many would envy that!
Oh trust me...I know! The lack of man shopping is the only thing that bugs me.
We moved here to a 17 acre property just 6 miles from town. Far enough that riff raff stays away and close enough for work/groceries.
We came from a city of 1 million people, hideous traffic congestion, and a 500 sq ft apartment. Then we bought this 17 acre, 2200 sq ft house for less than a 500 sq ft condo back in Alberta.
I do what I want when I want...but I could use more land!
   / What rod/amps to use? #25
I hear ya on the more land.
I'd like to get the property next to me as well. could head toward self sufficiency and even go off grid if the 'stuff' ever hit the fan.
best of luck to the both of us!
   / What rod/amps to use? #26
A trick you might try is to take some filler metal, either a welding rod with the flux removed, or other metal, then while holding the filler metal flat on the seam you want to weld weave you arc back and forth over it, the filler metal will absorb some of the heat so you won't burn through. either that or cut a flat piece of steel and put in back of the joint as a backing strip. With a name like sparrky, I have been at welding for quite a while.
I would have thought you were a bad electrician...LOL!
I'll try those tricks. Thanks.
   / What rod/amps to use? #28
or a stage and lighting hand. :)
   / What rod/amps to use? #29
Well when the current flows through me I tend to double my rr's , thus the sparrky
43 years self employed welder. :>) On my business card, I put "welding everything but the crack of dawn"
or...welding everything except plumber's cracks.
UNUSED FUTURE FT-46 1230MM HYD MULCHER (A57193)
UNUSED FUTURE...
2012 Ford Fusion Sedan (A55853)
2012 Ford Fusion...
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2019 Autocar ACX Xpeditor T/A EZ-Pack Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
2019 Ram 1500 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500 4x4...
