Odd starting question
/ Odd starting question #1
VictorW
Erie, Pennsylvania
Kioti CK30HST
CK30hst, 450 hours. New oil, air, fuel, and hydro filters along with all fluids at 420 hours, (400 hour service). Started and ran perfectly for the 30 hours since service. Using same fuel with additive as I've always used. No repairs other than new hydro cooler.
Normal Winter starting for the past six years is cycle glow plugs once or twice, depending on the temp, and it starts with a few seconds of cranking and continues to run. Once in a while, you'll hear that not all three cylinders are firing but smooths out in about five seconds.
The last "two" times starting and the first it's ever had this problem, temps are 15 to 25'F, cycle glow plugs, crank, and it fires instantly, smooth with all cylinders firing, but dies after two seconds as if it ran out of fuel or you turned it off. Try starting again the same way and an instant fire with a run for two seconds. Go for the third start the same way, it starts and continues to run perfectly. Give it some warm up time and put it to work. It doesn't miss a beat and will run perfectly until you turn it off. If you do turn it off and restart after a few minutes, there isn't a problem. The problem has been identical both times.
Any ideas why the engine has this strange start problem? It's supposed to be @40'F this weekend and I will see if the temp has anything to do with it but it has never done this before. Even at -4'F, it has started fine. The throttle does respond as it always has so I assume my injector pump and rack are working properly. It runs fine at any throttle setting or rpm. Some members have mentioned changing their precharge pump when they experienced fuel problems. Would this be a possibility or not being that it runs fine once it starts? I was also thinking it might be the ignition switch which has caused many strange problems for members. When it fires, I let off the key for the run position. The next time I start it when cold, I will watch the shut off seleniod when I crank it and let off for run.
Any ideas or help is greatly appreciated.
Vic
/ Odd starting question #2
There are a few simple answers. The nice thing about these diesels, all you need is air, fuel, and compression and you are off and running.
Start with electrical, depending on the serial number of your tractor, there are 2 different solenoid set ups; Power Off (old style) and Power On. With the newer style power on solenoids, if power is interrupted to the solenoid, it will release and shut the fuel off. This can be caused by a bad key switch, relay, or harness plug.
Next, check the fuel source. It sounds like the injector pump and rack are fine. The lift pump can be a source of issues when cold since it is a diaphragm type pump. Easily checked by pulling the fuel line from the lift pump to the fuel filter. From there, pull the fuel line from the filter to the injection pump. Each time, crank the engine a few times and check for fuel. You won't get a lot, but there should be flow. You can also turn the fuel filter to air to bleed any air from the system.
Another source for behavior like this is a small air leak in the fuel system. Make sure all of the hoses and good, and that the clamps are all tight. A small amount of air can make the tractor stall. We have seen instances where mice chew a hose, not quite leaking, but sucking air. This can play havock on the fuel system.
Forget about compression, sounds like you have plenty.
We would suspect electrical first, depending on the solenoid type, then the fuel source. It doesn't sound like anything serious, just enough to be annoying.
Hope this helps
It's a 2004, D is the first character in the serial number. With the key off, the solenoid clicks and shuts the fuel off. I'll watch the solenoid when I turn the key to make sure it's working properly. I didn't think about it sucking air into the system. The filter bowl didn't show any air so I had stupidly ignored that. I'll check both the fuel lines and the lift pump to be sure.
Thank you for your help and I'll be calling depending what part I may need. First time the CK ever gave me trouble and it surprised me. It's been like the energizer bunny...just keeps running. :)
/ Odd starting question #4
A faulty engine stop solenoid was responsible for my Kioti's difficult starting ; it eventually failed completely. The only problem I've had so far.
/ Odd starting question #5
Before you go to far, a lot of times it is your key switch going bad. If you were to disassemble you would probably find some corrosion inside. Honestly you could clean it up and put it back together with some dielectric grease - but the truth is to just go buy a new one.
I had one yesterday do the same thing. Changed the key switch and now it runs fine!
Every KIOTI dealer has key switches in stock!
Tony
Wouldn't you know it, 25'F and engine started perfectly as it always had. Just to be on the safe side, I gave things a check. The solenoid works fine. It is the older style where the fuel is always on and when you turn "off" the key, it pulls in for about three seconds, turns off the fuel, then returns to fuel on. Checked all the hoses/clamps and all appear good. The hose from the fuel pump to the tank is a pita and I could only go by feel without totally removing it. Disconnected the line from the filter to the injection pump. Slipped a clear piece of hose on the filter out fitting, started engine, and fuel flowed with no air bubbles. I put my finger lightly over the end of the hose and there was a couple pounds of pressure spraying fuel. If it acts up again, I'll have to take off the hose from the tank to the pump for a better inspection. It may also be the key switch starting to go and falsely energizing the solenoid. I don't want the problem to come back but then hopefully I can find the fault. It's tough when the gremlins attack. :)
/ Odd starting question #7
My CK30 has started doing this and I'm sure it's the ignition switch. I've sprayed contact cleaner in it and is a temp fix. Sometimes I'll start mine and when the ignition switch returns from the crank position it dies unless I just barely hold a little pressure clockwise. I think the switches are around $50 and will be ordering one. You could try spraying contact cleaner or WD40 in you keyhole to see if it helps.
Those ignition switches seem to cause many problems that members have posted. My tractor is always under cover and I also made a key/ignition cover cap, like atv's have, to keep rain, snow, or dirt out when I'm using it. The ignition switch is the last thing I'd have thought of. I have a new one the way. Thanks for the info.
/ Odd starting question #9
Likely the ignition switch. Mine has been an on and off problem for years. Finally ordered a replacement and noticed the part number has changed. Hopefully this is a better switch. Hasn't arrived yet so can't visually compare.
/ Odd starting question #10
Well i have a 05 ck30hst. Just to be different, I'm thinking there is some water in there somewhere and it freezes and blocks the fuel. Just figure out how far back from the injectors two seconds of diesel is and there is your problem.
Mike
Thanks for the idea. Each time at 15F and 25F days, the first start was identical. All three cylinders died together just like stopping the fuel supply. The third day at 25F, the start was normal. The tractor was run for an hour each of the first two days. Maybe the water, if any, worked it's way through. I'm going to do some more testing/checking/starting before I install the new switch and I will disassemble the old one to see if the contacts are really corroded. I want to be sure of what caused the problem.
Vic
/ Odd starting question #12
On my DK45S, the main issue with the switch was dirt in the electrical contacts, probably from dust. Also, by the way, different contacts provide glow in the run position and the crank position
Just to update. I have been starting the engine every other day with no problem. Today was finally the coldest at 24F. It started up with no problems and ran fine as I plowed snow for about an hour. I have a new ignition switch which I'll keep on the shelf for now. Maybe as mrutkaus mentioned, it was water, but for now it seems like it's made it way through.
/ Odd starting question #14
I can't always get my tractor under cover. Would you mind posting a pic. of the key cover?
I couldn't find the actual pictures but here is the link to a post where I attached them before. This is what keeps the water, snow, and dirt out for me while using the tractor. I found this rubber cup at my local Lowes. Apparently it's for table legs or a large walking cane. I just cut it shorter so it would just fit over the switch hold down ring without hitting the dash and I had to slightly open up the inside diameter (1.25"). I trimmed a small amount off the closed end so the key could go completely into the switch. I made a small cut in the end where the key goes through and it's tight: http://www.tractorbynet.com/forums/...ting/70143d1171298808-real-turn-off-key-2.jpg
Your tractor should have a milk colored plastic switch cover that is attached under the hold down ring of the switch. Here's a link from a parts listing and it's #6. I use this when it's just parked and it works well. It's a Kioti part and another member, whose tractor was missing this, bought one to add on:
OEM Parts
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
2024 BIG TEX 102" X 25' GOOSENECK TRAILER (A65054)
2024 BIG TEX 102"...
2015 WINSTON AP22024-DC 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
3096 (A63117)
3096 (A63117)
2006 Ford E-350 Enclosed Service Van (A64556)
2006 Ford E-350...
JOHNSON 1R POTATO HARVESTER (A64278)
JOHNSON 1R POTATO...
