B3030 Cab WSM?
/ B3030 Cab WSM? #1
PSDStu
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
I was wondering if anyone had a WSM for a B3030 Cab model?
If anyone has one, does it cover how to access A/C Evap coil?
I know how to remove the cab ceiling.....but not clear how to get access to clean the evap coil.
Thanks,
Stu
/ B3030 Cab WSM? #2
Thanks,
Stu
Stu, I don't have a manual but was wondering why do you feel the evaporator coil needs cleaning? I too have the B3030 cabbed tractor but never had the roof off and you got me thinking that maybe I should look to see if my coil is dirty. I have over 200 hours and use the 3030 to cut grass and move snow. Also, the heat and a/c work terrific. Thanks, Stanley
/ B3030 Cab WSM?
Stan,
The a/c has been working fine, but I have this "musty" smell in the cab, and have cleaned alot of dust out of the cab..... so I was thinking I'd like to take a look at the evap coil and see if thats where the musty smell might be coming from.
Stu
/ B3030 Cab WSM? #4
I have 300hrs on my B3030 HSTCC and my A/C works great. I would make sure that the drain hoses that come down both front pillars are connected and or not clogged. Maybe all of the condensation isn't getting out. While you have the roof off or the head liner down, I suggest going to the hardware store. In the window and door insulation section you should be able to find what looks like Mylar bubble wrap. Get a piece of it and put it on the bottom side of your roof. Your a/c and heat will work half as hard.
/ B3030 Cab WSM? #5
Stan,
Stu
I noticed that when I cut the grass (using a belly mower) that I get a lot of water dripping out of the drain hoses on both sides of the cab. High Compression has a good point.
/ B3030 Cab WSM?
Thanks. Condensation not draining doesn't appear to be a problem as both side drain tubes seem to drain fine.
I will have to look into the Mylar wrap.
/ B3030 Cab WSM? #7
Stu, If you don't mind can you let us know what you find out? Thanks, Stanley
APPROX (20) 1" X 8" X 12"' & (30) 1" X 8" X 10' (A64281)
APPROX (20) 1" X...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
MASSEY FERGUSON 7.5' DISC HARROW (A64276)
MASSEY FERGUSON...
2018 Ram 1500 Crew Cab Pickup Truck (A61573)
2018 Ram 1500 Crew...
2025 32in. Mini Excavator Bucket Attachment (A61572)
2025 32in. Mini...
