kubota b2150
/ kubota b2150 #1
dhethrington
kubota b2150
Hi my name is Dave and I live in Zeeland Mi. I have a Kubota b2150 4wh. It has a center Pto and am looking for info in putting on a front blower. I picked up a kubota 60" rear mount and am looking for info on mounting on front using the center pto.
/ kubota b2150 #5
Welcome!
The front blower is a B2660 I think. I've only seen a couple used and they were originally very expensive. I never considered it as you need a special subframe for the blower and it isn't compatible with the loader frame...Good Luck.
/ kubota b2150 #6
Welcome!
Yes.... Just as moeh1 said, the Sub-frame for the B2660 front blower on the B2150 is not compatible with the FEL. In other words you it's one or the other. It's not a simple matter of dropping one and mounting the other, it involves a complete sub-frame removel and re-attachement of the other sub-frame.
That's "one" of the reason I went with a rear 3-pt blower for my B2150.
And as moeh1 also pointed out.... it is/was expensive as all get-out. About 4-5 times the cost of the rear blower.
/ kubota b2150 #7
Before you get all involved in fabricating, I'd check the pto speeds both mid- and rear. My 2150 had a significant difference between the two. The snowblower, thus, might not operate properly or at all and a much higher than the 540 for the rear mount.
f.
/ kubota b2150 #8
he is right about shaft speed difference, also the mid pto shaft was a rather unique one as I recall. I have it on mine, never have had any use for it since I don't have a mid mount mower either.
/ kubota b2150 #9
I used to own a B2150, great tractor. If I recall it has four speeds for the mid mount pto, but mounting would be a problem as others have stated. What's the objection to a rear mounted blower?
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2010 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2010 CHANDLER TRI...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
