Farmtrac 360DTC Dead to the world
   / Farmtrac 360DTC Dead to the world #1
Theron W
Farmtrac 360DTC
Hi, I've got a Farmtrac 360 DTC that has always ran well and operated like a dream. Yesterday I was sitting on the tractor while it was running and turned it off to hear something my son was saying to me...when I tried to restart it, nothing happened, at all..
The only way I can describe what it's doing is to say that it is acting exactly like it does if the PTO is engaged or the clutch is not engaged when trying to start. In other words when the safety bypass is not allowing you to start the tractor. I've been doing some land clearing, which is rough on tractors, but I almost have a feeling it's just a part gone bad...
Can anyone tell me what it might sound like to them?? Switch relay? Disconnected wire...hung selinoid?
Any suggestions would be appreciated!!!
Theron in NC
   / Farmtrac 360DTC Dead to the world #2
Can anyone tell me what it might sound like to them?? Switch relay? Disconnected wire...hung solenoid?
Theron in NC
I would check wires under tractor such as brake, PTO and similar safety switches as wires can ripped off by branches.
   / Farmtrac 360DTC Dead to the world #3
We have a Farmtrac forum . Maybe the mod/adm can move your post over there as we have some good Farmtrac service guys on the 360 dtc over there.
It could be bad battery connections/ignition switch/starter circut or any number of electrical things. My FT60 did that last winter and it was the starter solenoid gone bad.
   / Farmtrac 360DTC Dead to the world #4
I had the clutch safety switch vibrate loose and fall out of the little bracket that holds it after a few hours of tilling with a borrowed Kubota. Thought I killed the tractor. Scared the crap out of me!
Ok, I would be glad to be moved to the Farmtrac forum. I wasn't aware that there was one..
Ladia....did you say brake safety??? Is there a brake safety switch on that tractor???.....
Thanks!!
Theron
   / Farmtrac 360DTC Dead to the world #6
I just gave you generic advice to point you to certain direction. I don't know about Farmtrack. On my tractor the parking brake has to be set or normal brake depressed, PTO disengaged etc to be able start the engine.
   / Farmtrac 360DTC Dead to the world #7
We had a FT 360 ... I know this may sound simple since you probably were not using the PTO ... but, have you checked to make sure the PTO switch is not turned on. Where it is located it is possible to turn it on with your knee without realizing it (I know because I had ours not start a few times :eek:).
Otherwise I would check the wiring from the clutch safety switch to make sure it wasn't pulled from brush. I doubt the PTO wire would be pulled lose since it is not located under the tractor. But, any of the switches could have gone bad.
As far as I know there are only the clutch and the PTO safety devices that prevent starting. I know the 360 does not have a seat safety switch and I don't think it has a switch on the brakes.
Just out of curiosity - have you had any problems with your clutch - that is the main reason we traded the FT 360 DTC BH/FEL for a different tractor.
   / Farmtrac 360DTC Dead to the world #8
it sound like a PTO switch is left on.
Ok, the first thing I checked was the PTO switch, and it was not on..I actually turn it on when I turn the tractor off on a regular basis as a safety measure in case one of my children were to hop in the seat and try to start it...so I'm used to turning it off in order to start it.
I talked to an 88 yr old tractor mechanic today and he said "no matter how much you think it can't be the battery, it probably is!" So as soon as I pull it out of the woods, I'm going to check all the connections and replace the battery.
I will also be able to check the clutch safety switch a little better once I get it up on some concrete by the tool shed.
As far as my clutch, knock on wood, I've never had any trouble with it whatsoever. Really the tractor has been unbelievably reliable since I've had it..which is probably for 7 or 8 yrs...
I admit, that I've been giving Kioti's sidelong glances lately though....it's just not in the budget with the economy what it is....
Theron
   / Farmtrac 360DTC Dead to the world #10
Theron
My 360 did the same thing this summer and it turned out to be a cracked battery terminal. They're a pretty cheap deal and required a good bit of cleaning being corroded into the wiring. I hope yours is as simple and cheap a fix, I also had the battery come loose once but caught it before it loosened up enough to get damaged.
   / Farmtrac 360DTC Dead to the world #11
From what I see in the 390HST service manual I have, the circuit is pretty simple. The DTC may be a different story having the clutch. The PTO switch always gets me. You might also check the fuses. I think there is one for the engine stop circuit but it looks like one of them might be used for the starter relay or something. The wiring diagram is hard to read on my service manual. You might also check the starter relay. I agree with others it is probably something simple. Check your lights and see if they work that might be a quick test of your battery connection. If they were tight enough to get lights but loose enough to not start I would suspect you would at least hear the starter try to turn over or hear the glow plug relay click.
I had some wires under my dash rub through and it shorted my lights out. That one wiring bundle isn't protected well from the frame under the steering column. It's possible something wore through and broke a wire under there. Probably nothing like that, but if you run out of options there is one place to check.
   / Farmtrac 360DTC Dead to the world #12
Theron,
Under to foot pan on the left side on the clutch pedal there should be a clutch switch. Check to make sure you did no snag the wires and disconnect it or pull the wires out.
Aha! Found it...apparently the yellow wire on the clutch safety switch had broken! Took me literally about 2 minutes to find it once I had a friend haul me out of the woods today...I used a jump wire to test it and she fired right up......gonna be hard to get to for resoldering....
Thanks to everyone for their answers......I love forums
Theron W in NC
FENCE PANELS (A58214)
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
2019 JOHN DEERE 325G SKID STEER (A60429)
2019 JOHN DEERE...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
