Grading Dirt Work
   / Dirt Work #11
What you have described sounds like easy work for that larger tractor. I have cleared a lot of ground with less than half the tractor you have. I did not have the box blade, I did it all with a loader, but I am sure the box blade would be a good attachment to have for this.
James K0UA
   / Dirt Work #12
Yep, I agree I think you have pleanty of tractor.
I leveled the area for my 30x50 barn using my little ole L3400 kubota, which is about half the size of that branson with about 1/2 of the lift capacity.
My area had about a 6-7ft drop over the 50' direction. I took the 3' from the uphill side and added to the downhill side to create a level pad.
I will however advise that you get a toothbar or some bolt on teeth for that bucket of yours. It will make digging virgin ground MUCH easier:thumbsup:
Heres a pic of what I did in about 1/2 a day:thumbsup:
   / Dirt Work #13
Lacking a box blade with rippers I set my tiller to 2 inches cut depth and have a go at the hard dry stuff. That makes easy work for the FEL to then scoop up the loose stuff. This does not tax my 21 hp tractor. Blueriver has the same idea with a disk harrow, just a different tool.
For really level work I go for a land plane. I do a fair amount of back yard smoothing up work behind bulk head construction or prior to laying sod.
I guess it depends on the tools you have.
I'm thinking you have plenty of tractor as long as you use common sense and not brute force. I see no point in abusing a good piece of equipment.
If you have never run a tractor keep asking questions. Somebody will have an answer that fits your needs.
   / Dirt Work #14
The seceret building on a hillside is to not build on any loose dirt. It is extremly dificult to compact soil that is on a slope and expect it to last or support a structure. This is VERY expensive engineering and construction. You need to dig away the dirt to create your pad.
It's not the pad that will be all the work, it's removeing enough of the hillside to creat a drainage ditch that will keep the water from coming off of the hill and into your building that will be what gets you.
A big, wide ditch is the best thing for moving water. Idealy, you want it to move the water slowly and to be able to hold everything that is coming down the hill and off of the building.
The most common mistake is to quit too early and think it's good enough. If you don't build it for the 100 year storm, you will have massive damage and issues when it happens.
What you will see others doing is to dug an ugly, but deep ditch to catch water, or build a wall that never lasts to divert the water, or put in a french drain with the hope that it will accomplish it. I don't like french drains on the best of conditions. They don't handle very much water and they have a life of about a decade before they silt in and stop working.
Yes, that sized tractor will get the job done. The real question is will you spend the hours that it will take to do it and haul off the dirt?
Eddie
   / Dirt Work
Eddie
Eddie,
Thanks for all the good info! I agree with you, it is very hard to compact dirt after you dig it up. For this dig I will be just smoothing out the pad site and leveling it. Fortunately it is already quite level and I will not have to move a lot of dirt. Once I get every thing moved I had a 1/2 ton cement roller I will use on the dirt and then on the sand base.
Concerning the water run off, the hill side is mainly a ramp for a fire road going up the hill. Right now when we have heavy rain the water runs down the road and crosses the front of the pad site. When I level the area, the pad site on this end will be a bit higher and I will make sure to have a gentile grade so the water will flow around the pad.
Thanks again for the good advice!
   / Dirt Work #16
Just a thought, but if drainage is an issue, could you put a small drain line across the front of the site with an intake above the driveway, build in a funnel-shaped area so that it goes in the pipe and flows underground to the other side?
   / Dirt Work
Ray,
I do not think drainage will be an issue, rain water run off now and after the site work is done flows around the pad area and even in very heavy rain is not a great quantity to call for a convert across the front of the pad due to the vegetation on the hillside and on the old fire road area.
   / Dirt Work #18
Eddie,
If you are pouring a concrete slab I would use a vibratory roller to compact the material in 4 inch lifts. I built this pad for my new shop last year and have since placed all the retaining wall block around the perimeter. A fel, landplane and vibratory roller is all it takes to shape the pad.
   / Dirt Work #19
You can do it using just the tractor to compact it if you go in very small lifts, I generally try to do an inch at a time. Time consuming but it works. We have a few pads that are several years old done this way, no cracks or settling to speak of. Also helps to wait several months after doing the dirt work before building.
   / Dirt Work #20
I agree with waiting to build on it, I finished the pad about April last year and hope to build in Feb-March this year.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2019 International Bucket Truck (A55973)
2019 International...
2014 Crossroads Sunset Trail ST33PB14 36ft. T/A Travel Trailer (A55853)
2014 Crossroads...
Adams 16T Tender Body (A55315)
Adams 16T Tender...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
