Kobota BX25 cannot start
/ Kobota BX25 cannot start #1
DE Services
Kobota BX25
My bx25 was running great, up until I got off today. When I got off the motor cut out. I tried re starting and it would not crank. I jiggled the PTO lever and it started and ran for a while. Now the motor just cranks and it will not start. Any suggestions?
/ Kobota BX25 cannot start #2
Check your fuses. The fuel shutdown solenoid uses a holding voltage to hold it open.
You shouldn't have to jiggle the pto lever to start it, sounds like the safety switch has worked loose.
Good luck
Dave
/ Kobota BX25 cannot start #3
Good luck
Dave
I agree...Sounds like a safety of some sort...
/ Kobota BX25 cannot start #4
Check PTO lever to make sure it's not engaging safety switch because it's sensing like PTO is engaged and will not start , look carefully.
DevilDog
/ Kobota BX25 cannot start #5
Good luck
Dave
If it is the newer D902 engine the solenoid only has a single coil for engine kill, nothing for hold open.
David Kb7uns
/ Kobota BX25 cannot start #6
DevilDog
+1 on this. Very common. The switch may need some adjustment.
/ Kobota BX25 cannot start #7
If it cranks but does not start, I would think it was possibly a fuse like said earlier. A safety switch not being made would not allow it to crank.
/ Kobota BX25 cannot start #8
You still could have a fuel supply issue.
/ Kobota BX25 cannot start #9
...A safety switch not being made would not allow it to crank.
Agree...look more closely at fuel system, especially fuel pump. As for jiggling PTO...most of us have/had that off-and-on...
Thanks for all the suggestions guys. I ended up adjusting the PTO sensor as the screws were loose. Also, I changed the fuel filters then checked all fuses and they were fine. Gave it a little throttle and turned the key and it started right up and worked great all day today. Ran for about 7 hours. Thanks again......
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
213138 (A64276)
213138 (A64276)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
iDrive TDS-2010H...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
