Kobota BX25 cannot start
/ Kobota BX25 cannot start #1
DE Services
Kobota BX25
My bx25 was running great, up until I got off today. When I got off the motor cut out. I tried re starting and it would not crank. I jiggled the PTO lever and it started and ran for a while. Now the motor just cranks and it will not start. Any suggestions?
/ Kobota BX25 cannot start #2
Check your fuses. The fuel shutdown solenoid uses a holding voltage to hold it open.
You shouldn't have to jiggle the pto lever to start it, sounds like the safety switch has worked loose.
Good luck
Dave
/ Kobota BX25 cannot start #3
Good luck
Dave
I agree...Sounds like a safety of some sort...
/ Kobota BX25 cannot start #4
Check PTO lever to make sure it's not engaging safety switch because it's sensing like PTO is engaged and will not start , look carefully.
DevilDog
/ Kobota BX25 cannot start #5
Good luck
Dave
If it is the newer D902 engine the solenoid only has a single coil for engine kill, nothing for hold open.
David Kb7uns
/ Kobota BX25 cannot start #6
DevilDog
+1 on this. Very common. The switch may need some adjustment.
/ Kobota BX25 cannot start #7
If it cranks but does not start, I would think it was possibly a fuse like said earlier. A safety switch not being made would not allow it to crank.
/ Kobota BX25 cannot start #8
You still could have a fuel supply issue.
/ Kobota BX25 cannot start #9
...A safety switch not being made would not allow it to crank.
Agree...look more closely at fuel system, especially fuel pump. As for jiggling PTO...most of us have/had that off-and-on...
Thanks for all the suggestions guys. I ended up adjusting the PTO sensor as the screws were loose. Also, I changed the fuel filters then checked all fuses and they were fine. Gave it a little throttle and turned the key and it started right up and worked great all day today. Ran for about 7 hours. Thanks again......
iDrive TDS-2010H...
karcher pressure washer (A61567)
karcher pressure...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
Marcrest BSP449 (A64127)
Marcrest BSP449...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
