Oil & Fuel Diesel additives
/ Diesel additives #1
zlock24
New Martinsville, WV
jd 445, kubota bx1500,wheel horse c-160, wheel horse h-520
Should I being using a diesel additives in My bx xx00 series tractor since all there is anymore is ultra low sulfur diesel?
/ Diesel additives #2
yes!! i run it year round.mske sure it is a formula for ulsd, as it will add lubricity.
/ Diesel additives
Thank you, this is my first diesel tractor. Do you have any recommendations? I live in the snow belt, so I see temps below 0 in the winter and up to 100 in the summer
/ Diesel additives #4
This is my first diesel tractor also, I am using Power Service Diesel Fuel Supplement. I have heard lots of good things about it.
/ Diesel additives #5
i use howes or kleenflo, but lots on here swear by power service. they have two kinds, white bottle and grey bottle. One winter, and one for the rest of the year.
/ Diesel additives #6
I live in Central Kentucky which is not much different weatherwise for most of WVA and I don't put anything in my fuel most of the time and I have had no problems to-date with fuel gelling. I also have other diesel vehicles and it is the same for them. I do store everything indoors in unheated buildings and use them regularly during the winter. If I didn't use them often I probably would add some antigel/cetane boost product.
/ Diesel additives #7
The additives posts really leave me confused. Ive owned diesels in Idaho for over 16 years now, and ive never added any fuel assist products.
The diesel here is winter blended 6 months of the year.
I have been told that the ultra low sulfur diesel doesn't have any less lubricating properties as the older diesel. Sulfur ISNT a lube.
My engines are run regularly and dont sit unused for months at a time.
So, Are fuel additives really necessary or are they just another method to take $$$ from out collective wallets.
In 16 years none of my 5 diesels have had any gelling or failure issues.
Just asking ? im confused
/ Diesel additives #8
I guess I should clarify my post. I do have a storage tank in my shop for diesel fuel. I purchase fuel when I start to run low at the end of the "busy" season, usually October and that is still the summer blend here with no additives. Therefore, if I didn't use my tractors/vehicles regularly during the winter months I would add antigel/cetane boost. Also, I am not sure that using off road diesel that they change the formula or not.
/ Diesel additives #9
This is my first diesel tractor, so I have no proof. In my gas engines I have always used Techron. It is a good injector cleaner and you can feel the difference.
/ Diesel additives #10
actually the sulfur is a lube.
/ Diesel additives #11
Uhhhhh ...... Really????? :laughing:
/ Diesel additives #12
I use Power Service in both my Kubota and my '97 Ford diesel truck year round. Because the truck will be sitting outside unused for the winter, I also treated both tanks with Power Service 911 and Bio Kleen to help prevent any gelling or algae issues.
I've never put 911 or Bio Kleen in the tractor. That's always stored inside and I've never had a fuel issue with it yet.
As far as sulfur is concerned, on the website http://www.cdxetextbook.com/fuelSys/emission/types/sulfurcontent.html I found this:
The refining process used to reduce the sulfur level can reduce the natural lubricating properties of the diesel fuel, which is essential for the lubrication and operation of fuel system components such as fuel pumps and injectors.
/ Diesel additives #13
Sulfur is not a lubricant in of itself, but it can combine with the nickel content in many metal alloys to form a low melting point eutectic alloy that can increase lubricity. The process used to reduce the sulfur also reduces the fuel's lubricating properties. Lubricity is a measure of the fuel's ability to lubricate and protect the various parts of the engine's fuel injection system from wear. The processing required to reduce sulfur to 15 ppm also removes naturally-occurring lubricity agents in diesel fuel. To manage this change ASTM International (formerly the American Society for Testing and Materials) adopted the lubricity specification defined in ASTM D975[12] for all diesel fuels and this standard went into effect January 1, 2005.[13] The D975 standard defines two USLD standards, Grade No. 2-D S15 (regular ULSD) and Grade No. 1-D S15 (a higher volatility fuel with a lower gelling temperature than regular ULSD
fuel manufacturers have been adding a lubricating agent to their fuels for years.
/ Diesel additives #14
Now were talking. Thanks fellow pack member!!!!:licking:
/ Diesel additives #15
My local fuel supplier told me (take it for what it's worth) that because of the law (I didn't ask if it was state or federal) but the low sulfur home heating oil could not be sold to be used in diesel engines.
The reason is that heating oil has additives in it to help break up the sludge that collects on the bottom of storage tanks while off road diesel has additives to increase the lubricating properties of the fuel and, of course, the anti gel. The law is so that the additives used are not burnt needlessly.
Is it true, I don't know. But what I do know is the price is usually close enough that my delivery guy will sell me both for the same price and that he has two tanks on his truck, one that always has heating oil in it and the other that he either has off road diesel or kerosene. He's gone as far as to tell me that I would have to wait a couple of days because he had kerosene on his truck.
I've had people argue this point with me, not sure why, if you bought home heating oil I would put an additive in (better safe than sorry). But if you bought off road diesel the only time you need an additive is if you have diesel fuel that doesn't have the anti-gel added to it because you bought it in the middle of summer and you'll be using it in the winter. Otherwise it's really up to you if you want to spend the money.
/ Diesel additives #16
Sulfur is not a lube. The problem is the fracking process they use to get rid of the sulfur also gets rid of the natural lubricating properties of the diesel.:thumbsup:
/ Diesel additives #17
yup..thats what i said. but the refiners have been adding a lube to the diesel for many years. even before the ultra low fuels.
/ Diesel additives #18
the sulfur that was removed was good at killing the bacteria that starts the algea process and on the power service note I have seen the white bottle with the anti gel actually gel on the road -I had used it for years now I use HOWES which guarantees you go or they pay the tow
/ Diesel additives #19
I use MMO since it does not mess with UOA like POwer Service.
/ Diesel additives #20
The white bottle power service is for winter, the gray bottle for summer, and the red bottle for already gelled fuel. I personally use Howes. Napa had it on sale in October, $11 a bottle. I bought a case. My tractors get used a lot in the summer, only one gets used in the winter. I treat them all. I have had fuel gel here in western Wyoming, with temps around -30f, and it's a b***h trying to change the filter with no feeling in your hands. I don't know if any are better than the next, I buy what ever is on sale. I just know that even winter blend fuel gels at -30f. I just want my equipment to start and run when I need it!
International 3 Row Bottom Plow (A64119)
International 3...
2005 Rolls Rite 26ft. 24 Ton T/A Tag Tailer (A61573)
2005 Rolls Rite...
2007 Utility Trailers Mfg. FS2CHA 48ft. 40 Ton T/A Flatbed Trailer (A61573)
2007 Utility...
2002 Ford Ranger Pickup Truck (A61573)
2002 Ford Ranger...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
