How to fix crushed Gas can
/ How to fix crushed Gas can #1
twinjayhawks
NE of Tulsa, OK
Century 3045
Does anyone know an easy way to rehabilitate a crushed plastic gas can? I am not sure why this happens... and I don't really care. I have about 5 cans that look like this. I am looking to make them useful again.
/ How to fix crushed Gas can #4
Any way to blow a little compressed air into them?
/ How to fix crushed Gas can #5
"Smart" was not a part of your request for an "easy way to rehabilitate a crushed plastic gas can.":D
Drain and set out in the sun for a day and all the moisture will be gone.
/ How to fix crushed Gas can #6
The problem results from a warm can being sealed, then cooled. The cold air contracts and sucks the sides in....
No problem with the water, just let them dry before adding fresh diesel. (or whatever you keep in blue tanks)
Leave empty cans with the top a little loose so air can get in and out with temp changes...
/ How to fix crushed Gas can #7
I would go with the hot water idea, I think it would need a little hotter than tap water out of the water tap though.
david
/ How to fix crushed Gas can #8
Fill with hot water then apply a little air pressure to expand. This could be done by just blowing into the spout (dont forget to open the pour valve) if you dont have an air compressor. With extremely hot water in the tank, it wont take but a very little pressure to expand it. If using your compressor, go gently with the air or you could explode the tank as the plastic will be pretty soft.
/ How to fix crushed Gas can #9
Is that smart to have water in a gas tank?
The amount of residual water left in the gas tank after emptying is considerably less than what is already in the fuel. You would not even have to wait for the insides to be completely dry. It may be a good idea to know why it happens so you can eliminate the reason for any future purchases.
/ How to fix crushed Gas can #10
easiest 2 cures
1 put them in the back of my truck, every can back there swells up like a possum on the side of the road.
2 carefully remove the lid of your trash can, quicly insert all the unvented safety cans, carefully replace lid on trash can.
/ How to fix crushed Gas can #11
easiest 2 cures
I like your 2nd suggestion the best.
Okay, I give... Why does it happen?
/ How to fix crushed Gas can #13
Put a little gasoline in it and set out in the sun. Don't let it bloat too much or it will never stand up properly again. Then, as mentioned earlier do not close an empty warm can tightly, or even a partially filled one, for that matter. I know, an open can could spill. Gas cans need to be stored so they can't tip anyway.
/ How to fix crushed Gas can #14
I came for the info. I stayed for the entertainment.
/ How to fix crushed Gas can #15
Even when mostly empty, most cans have enough gasoline in them to be full of gasoline vapor. Seal it up on a hot day, or even a warm one, and the gasoline vapor condenses on the next cold exposure (say overnight) creating a partial vacuum. The can is not designed to hold a vacuum and collapses.
A few ounces of gasoline and warm sun will expand them as NormL suggests.
/ How to fix crushed Gas can #16
It happens because tanks today do not have a vent hole. Temperatures outside the tank warm up or cool down quicker than the contents inside the tank which can cause the tank to either collapse or expand. Its simple physics related to atmospheric pressure, which was one of the more interesting classes in High school many years ago.
/ How to fix crushed Gas can #17
easiest 2 cures
As for your #1 cure... It sure works well on the new plastic "safety" cans. I filled a brand new one, on a 85 to 90 degree day, hauled it maybe 5 miles. Stopped to eat breakfast for like 25-30 minutes, then on to the gravel pit, two miles away. It literally puffed up so much, it rolled over, with it's now round bottom.
/ How to fix crushed Gas can #18
A shucks - I wanted to learn how to straighten out metal cans. Not 1 little bitty suggestions. :laughing::D
Maybe a match on a long stick???? :thumbsup:
/ How to fix crushed Gas can #19
I ride around with a little 1-gal plastic can in the bed of my truck, & that sucker swells up to almost round in the sun ... & later that night when I park in my garage, it shrinks down so tight it sucks the sides in like OP's. Crushed.
It's just expansion & contraction due to temperature change ... & no vent.
/ How to fix crushed Gas can #20
We have pushed in many snowmobile front cowls and belly pans. A heat gun and a little patience the dents come right out. I guess the plastic likes to be in it's original formed shape. Not sure this would work on a plastic gas can though.
(8) 18X8.50-8 GOLF CART TIRES & RIMS (A64281)
(8) 18X8.50-8 GOLF...
Caterpillar Service Magazines (A63117)
Caterpillar...
KUBOTA BT2912A - 15" PIN ON BUCKET (A64280)
KUBOTA BT2912A -...
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
Kubota SVL 97-2 Skid Steer (A65579)
Kubota SVL 97-2...
