john deere 850 4x4
/ john deere 850 4x4 #1
RHemmer
Member
Independence Minnesota
Kubota b2400
Recently bought a John deere 850 with alittle under 1200 hrs on it. It runs well but notice a fair amount of smoke come out from the crankcase breather tube. Seem like the tractor needs to be warmed up before this begins. What the problem. I am not much a of a mechanic. I would appreciate your thoughts
Thanks
Randy
/ john deere 850 4x4 #2
When the engine is cold look for condensed moisture on the dip stick above the oil level.
When the engine is warm, pull the dipstick and try to set it a fire with a lighter, indicating fuel in the oil.
If you have either of those conditions, consult a trusted mechanic.
Good luck
/ john deere 850 4x4 #3
Not sure of normal breather smoke for your vintage Yanmar diesel which is the engine in your tractor. My Cat mini-excavator has a 3 cylinder Japanese engine of similar design and power. It s a Shibaura built by Cat under license from Shibaura. It puts out a lot of smoke from the breather tube when hot and working hard, but power is very good and it uses very little oil. I have a lot of experience with the Shibaura/Caterpillar and know it is the nature of the beast. It could be the nature of the beast. However, my brother-in-law has a Deere one model larger than your tractor and he did suffer a cracked valve seat. When I looked for info on the web, I did find quite a few others reporting the same thing but that is more likely to leak exhaust gas into the coolant instead of the crankcase.
Thanks you both for your input on this. I have started it quite abit lately with out letting it warm up really good. I am hoping its condensation thats built up and needs a good warm up cycle? The reality is it probably needs some motor work.
Thanks again.
Randy
/ john deere 850 4x4 #5
Thanks again.
Randy
Try to plan your work so that the engine gets a good workout.
If I don't have enough actual work to do with mine, I'll let the tractor run at half throttle for twenty minutes or so just to burn off condensation. Better to waste a little fuel than to cause premature engine wear. (IMHO)
/ john deere 850 4x4 #6
These are notorious for frozen clutches; that is the clutch literally rusts to the pressure plate if tractor is layed up for extended periods creating an over thousand dollar repair. To mitigate this, find a method to keep the clutch pedal depressed if tractor is not going to be used for awhile. Amount of smoke you describe coming from breather is not normal for these Yanmar engines in the 850 series.
/ john deere 850 4x4 #7
I should have said that the 20 minute run time is 'after' the initial warm up period.
/ john deere 850 4x4 #8
I own an 850 with about half the hours on it that yours has. I don't have smoke coming from my Crank breather at this time. What color is the smoke, whiteish? it could be steam from a coolant leak of some sort. Keep and eye on your coolant levels and the dip stick for milky slime indicating coolant leaking some where. If not coolant, I would guess that your rings maybe getting tired and it is just plain blowby. A hard starting Diesel in the cold can be from low compression as well. Does it start hard in the cold?
thanks, Phil C.
/ john deere 850 4x4 #9
thanks, Phil C.
I have seen these engines go 7000 -10,000 hours before any sign of blow by. Your 850 must be a real beauty with only 600 or so hours and pretty rare for such an older tractor to have so few hours.
The tractor is alittle hard to start when temps dip, but I always contributed that to being a diesel trait. The smoke is grey and starts up only after the tractor is warmed up.I dont notice any coolant missing and no sludge on dipstick/oil cover. I am preparing myself for a trip to the mechanic and see what is going on. What i find odd is the smoke coming out of the beather tube but you dont really notice anything as far as excessive smoke coming from the stack?
Thank you all for your advice and thoughts!
Randy
/ john deere 850 4x4 #11
Randy
This tube is allowing exit for crankcase blow by only and not exhaust. This can happen with bad rings but I find it difficult to think that your rings are bad especially that you are not exhibiting excessive exhaust smoke. I'd find it easier to believe that the oil in your crankcase might be a lighter viscosity than needed for your tractor. I'd change the oil first if you have not already done so to a 15-40 wgt and see what happens. Someone could have put in 10-30 or even 5-30 automobile oil before you got it.
Arrow, thanks for the advice. I will change the oil and refill with heavier wt. Hope its as simple as this!!
Thanks all for the help!
Randy
Went to Tractor Supply today and bought 15/40 wt oil, drained old oil and refilled with new+oil filter. Ran it for about 10 minutes and no sign of breather smoke. This is really good news. Thanks agian Arrow and everyone else for your input. I plan on put it to the real test tomorrow (jan 1) and see if a extented warm up still shows no smoke. The tractor is really is in great shape and wanted to have for awhile.
have a great new year!
Randy
Caterpillar D7H Series 1 and 2 Dozer Service Manuals (A63117)
Caterpillar D7H...
2018 HINO 338 4X2 S/A 26FT CDL REQUIRED BOX TRUCK (A59912)
2018 HINO 338 4X2...
JOHN DEERE 2018 BATWING ROTARY MOWER (A64280)
JOHN DEERE 2018...
UNUSED WOLVERINE TDB-11-66W-66" BUCKET (A64281)
UNUSED WOLVERINE...
2011 Isuzu NRR Dovetail 22ft. Flatbed Truck (A61573)
2011 Isuzu NRR...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
