Hydraulic top link help needed
/ Hydraulic top link help needed #1
dixie
I am interested in purchasing a hydraulic top link for my Kubota M5700. It is already factory plumbed for rear hydraulics. Is their a particular brand, style, feature, size, etc. I need to consider before I purchase? Any other issues I may need to consider?
Thanks in advance.
/ Hydraulic top link help needed #3
/ Hydraulic top link help needed #5
And now he shows up, late to the party I see:laughing::laughing::laughing:
Yeah, just got back home from seeing the new Sherlock Holmes movie with the wife. Very good movie by the way, at least IMO. :thumbsup:
/ Hydraulic top link help needed #6
Almost went to see that, then the wife said she wanted to go shopping:(
/ Hydraulic top link help needed #7
Unless she really likes shopping, she would have had a better time watching the movie. Wife says to let you know that she was the one who picked it out to go and see. :cool:
/ Hydraulic top link help needed #8
I'm sure she would have because after being in that mall all day I get a little fussy, I like to get in and out of those places - especially being as busy as it is with the holidays. But I guess it's the same way when I go take my time at the tractor store while she sits in the car - difference is she's learned to not come to the dealer and I still follow her to the mall
/ Hydraulic top link help needed #9
mtn. view has some pretty good stuff, but if you want a dpcv i have them on my my cylinder. (just to give you all your options)
/ Hydraulic top link help needed #10
I just purchased a hydro top link from Fit Rite.
The proprietor was extremely accomodating, very user friendly, and very responsive.
/ Hydraulic top link help needed #11
...if you want a dpcv i have them on my my cylinder...
dixie, just in case you don't know what DPCV do, it keeps an implement from dropping down even if it looses pressure. It has to have a certain amount of pressure to move it. (correct me if I'm wrong, please)
MtnViewRanch does not have that but his can "float" in and out when you need that function. His will also hold an implement in place but if your valves leak, that will also be seen in the implement dropping down.
Both have their place and use... You can do plenty of reading about both types by searching "DPCV"...
/ Hydraulic top link help needed #12
This cannot be said any better, period. :thumbsup:
/ Hydraulic top link help needed #14
Some spools have what's call "Float Detent", it locks the valve in an open position (so of speak) to allow the hydraulic cylinder to freely move in and out with no pressure. FEL have this feature if you push it all the way forward, it will lock in. This allow the bucket to float along the surface of the ground and you can smooth out rough areas.
For a Toplink, that mean if you have it in float position, you can pull or push the rod to fit an implement. Where the DCPV you have to use the valve to adjust it to the correct length. It can only be moved under pressure.
/ Hydraulic top link help needed #15
Teg thanks for the info. I am looking at getting TnT for my Bobcat 235. I have two rear remotes. One has a detent and one does not. From what i have read in the manual, I thought in the detent position hydraulic fluid is constantly supplied to the implement.
/ Hydraulic top link help needed #16
You're right, I meant to say "Float Detent", Sorry about that.
/ Hydraulic top link help needed #17
You can get them from MtnViewRanch above. Just click on his link:thumbsup:
/ Hydraulic top link help needed #18
Hey, Martian, are you looking for some brownie points. :laughing: ;)
Float position is a great option to use with a hydraulic side link when final grading- smoothing out a road also. Especially where you have intersections such as a Y in the road. It's not that you use it a lot, but when you need it, it is VERY nice to be able to use it.
/ Hydraulic top link help needed #19
/ Hydraulic top link help needed #20
The valve for rear remotes normally does not have detent or float, and on some valves can be added.
When one adds rear remote, they should think about what their needs will be later on.
I think if I added remote valves, I would consider a three spool valve one spool with float, and one with detent for constantly running hyd motors, or log splitters, etc.
The first spool with float and the second spool operate the T-N-T, and the third spool with detents for something like hyd motors, log splitter, BH, etc.
If this were a stacked valve, you could add more spools for other functions, at any time.
This valve should also have PB.
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2018 Toyota Tacoma Pickup Truck, VIN # 5TFRX5GN2JX129061 (A61165)
2018 Toyota Tacoma...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A61567)
2001 Kubota L3300F...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
