2" Receiver Solution for X749
/ 2" Receiver Solution for X749
Ok...as promised pictures of the hitch setup. The new machine is awesome...I can't wait to do some work with it.
/ 2" Receiver Solution for X749 #22
Too late now, I guess. But, I found a bolt on 2" receiver adapter that fit right on the back of my 425. No welding required. I simply had to drill a second hole. I got it at harbor freight. It is down low. But, that's easily fixed with an offset ball adapter.
/ 2" Receiver Solution for X749 #23
I would be careful using that hitch as it puts the ball rearward a long ways from the rear axle. Really think you would be better off with the hitch ball much closer in to the machine.
If you are using this to move and park trailers, moving just a short distance the front weight bracket has a 1 1/4" receiver built in. This will handle more weight than you can deal with on the rear ball as you have it configured now.
Go slow while backing a trailer for the first time as the 4ws will over steer a trailer very quickly. The 4ws also has the effect of not making much difference which end is hooked to a trailer, reacts the same either end.
Thanks Steve - I've logged many hours on my old 425 AWS I just traded in so am definitely used to the dynamics when backing or pulling a trailer with it. I do agree with you on the hitch set up...I'll probably use the front receiver mount to move the big trailer. The hitch on the 425 had a pretty long moment arm too and it didn't really have any trouble with the big trailer but I generally had the JBSr. mounted to the front when doing so. The new machine is a beast compared to the 425!
/ 2" Receiver Solution for X749 #25
What about something like this for lighter loads? $9.99 at HF.
/ 2" Receiver Solution for X749 #26
That's similar to what I used. Only mine is about twice as long and attaches with two huge bolts.
/ 2" Receiver Solution for X749 #27
I too would be concerned about how far back the ball is from the axle.
I too just upgraded from a 425 to a x700. On my 425 I would move my 1000# 16ft utility trailer from the back of the shed to the driveway. With my 3pt hitch I could feel front end losing grip. I don't have any front weights, yet.
I ended up welding a 2" receiver tube about 12" off ground on my 425. I did this for a Kolpin dirt works 3pt electric hitch. I will do the same on the 700 but make it a bolt instead of welding to frame for easy removal if needed.
I like the Kolpin 3pt because I can remove the 3pt hitch for mowing when not needed so not sticking out back of tractor, but when I need a rear blade I have it.
/ 2" Receiver Solution for X749 #28
If I knew for sure I had other uses for the 3-point I might be able to justify it but for now I'll just go the simple route.
A box blade comes to mind right off.
/ 2" Receiver Solution for X749 #29
Do you happen to know the HF part #? I couldn't find it.
/ 2" Receiver Solution for X749 #31
Gittyup said:
They have a 12" : 97095
and an 18" : 97093
I think mine is 12"
link:
Trailer Receiver - Harbor Freight Tools
This is a different item. I was wondering about the reference above to a hitch like mine but with two bolts to secure it (mine only has one). The hitch in my picture above is item #65961. The two items here are 12" and 18" extensions of the 2" tube that slides into the hitch I have - not the hitch itself.
/ 2" Receiver Solution for X749 #32
I just made a receiver hitch for my x700. I will post pics middle of this week after it is all painted and installed.
I simply took 2pcs of 2"x6x1/4" and welded together to create a 4x6 plate. This is to be the mounting plate at the bottom.
next I welded a 3 1/2" long x 2" tube steel vertical in the middle, then took some of the same material (same size as a receiver tube, and made an "L" to be the receiver. I also welded a triangle gusset for support.
3rd I made a wide "H" or I configuration of of angle and flat steel. This is welded to the top of the receiver tube, then bolted to the sides of the tractor frame to existing holes.
/ 2" Receiver Solution for X749 #33
I figured out how to add a pic.
Here's a 3d sketchup of my design to help explain
/ 2" Receiver Solution for X749 #34
That looks like it's incredibly strong and certainly wobble-free. That's awesome.
/ 2" Receiver Solution for X749 #35
Not sure what you want. But that is what I used. It receives just like the item you reference, and I don't believe it would go into your part unless your part is larger than standard catIII. I added holes that match the hole pattern on my tractor and bolted it on. It accepts standard cat III towing accesories. I use a carry-all, a sleeve hitch, and a ball hitch (all standard unmodified) with it. Slide in, insert pin; just as it should. Sits low, but works perfectly for me. There is a "double" one availabe that I guess would raise the height. but, then so would an offset insert.
1043 (A60430)
1043 (A60430)
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
