Front brakes on a Zero turn!!
/ Front brakes on a Zero turn!! #1
newt92
Gold Member
Secor Illinois
John Deere 2520 and 2305
Has anyone heard of or seen this setup?? Genius idea IMO!!
[ame=http://www.youtube.com/watch?v=pcDs97X6U8c]Zero Turn Mower Front Brakes!! Check it out www.tedbrakes.com - YouTube[/ame]
/ Front brakes on a Zero turn!! #2
Seems like a good idea, but if this guy is so concerned about safety and not being killed shouldn't he install a ROPS on his mower too??? I'm just sayin'...
/ Front brakes on a Zero turn!! #3
It is a great concept, but if you are in a situation where the big fat tires on the back with you and the engine sitting over them dont have enough traction, how are your little slick front tires going to do anything?
Replacing the rear turf tires with some lugged tires to get more traction will do more for less money than adding brakes to the front
Aaron Z
/ Front brakes on a Zero turn!! #4
What am I missing? Why does he need brakes on the front tires? He drives around on that little hill like it's nothing, and it's not, but why wont his rear wheels do everything that his
new front brake feature is supposed to do?
Seems like a silly idea that doesn't accomplish anything or justify a reason to exist.
Eddie
/ Front brakes on a Zero turn!! #5
Aaron Z
Eddie
Have either of you used a Zero Turn mower, espcially on hills? I'm guessing not. The rear tires are almost worthless coming down a hill, front first.
I am fairly confident in saying no matter what tire is on the rear.
/ Front brakes on a Zero turn!! #6
I've owned my Skag Wildcat for 2 1/2 years. I'm very impressed with the gripping ability of my rear tires on dry grass. I go up, down, and sideways on it where I wouldn't dare go with the riding mower that I had before, or with any of my tractors except my dozer. Those two wheels, with their own independent hydraulic motors to drive them are AMAZING!!!!
Do you have a zero turn? Since you say that the rear tires are worthless, what do you have? Might be that we're not comparing apples to apples here and what you have might need additional braking power.
Eddie
/ Front brakes on a Zero turn!! #7
I'd have to agree with you. You don't need brakes if you just mow flat ground or slight hills. I believe the fellow invented them specifically for a steep hilly environment thus increasing the usability and safety of a zero turn mower.
/ Front brakes on a Zero turn!! #8
Sorry, you are incorrect. I have quite a few hours running one. I worked for Trugreen Landcare mowing and repairing mowers, so I am very familiar with how they work (I worked with 60-72" Exmark Lazers and 60" Huskvarnas).
We had a machine (not on my crew) which had a stuck front wheel (from not enough grease despite the crew saying "but we greased it at lunchtime" and me trying not to laugh at them) and it didnt slow the mower down much even on concrete or asphalt (tore the lawn up getting it back to the trailer though).
What would worry me the most with that system is that if going down a wet slope one wheel would catch on an obstacle rather than rolling over it and spin the mower around into something, or onto its side.
Despite his spiel about it being wet, in that video, you could see dust coming up when he turned around at the base of the hill in the first part of the video. No way that would be considered "wet" around here.
Aaron Z
/ Front brakes on a Zero turn!! #9
Make that a DRY steep hilly environment. Around here, it is wet enough that the front wheels will just slide around on the fresh clippings or dew.
Aaron Z
/ Front brakes on a Zero turn!! #10
I must have pretty steep hills.
Bought this mower in 2002
Took off the originals put these on...
Then went to these...
/ Front brakes on a Zero turn!! #12
My Woods front mount came with the tires you show in photo two. My problems going down hill are not sliding as long as I can control the hydraulics. I really should add the ROPES bar and seat belt. My problem is bracing myself so I do not slide forward and pushing on the sticks.
I break traction all the time with those tires going uphill. If my mower deck was wide enough I would add a dual kit.
/ Front brakes on a Zero turn!! #13
I'm guessing you have some pretty steep hills also.
/ Front brakes on a Zero turn!! #14
I've got a couple spots on my property with a pretty good grade change although they're only a few feet in length. No danger but my Carlisle Turf Savers can break traction going in either direction. I found that any significant change to one of the drive wheels is when I see greatest loss of traction. It is better in my case to just pick a slow speed and hold that through the slope.
/ Front brakes on a Zero turn!! #15
Eddie
I have the same ZTR that Eddie has and really have not experienced the problem going downhill apparently some have with other units. Doesn't seem to need any brakes on the front. The mower doesn't do too good in a mudhole, but just fine on hills. Without even using the brakes, going downhill you can pretty much control your speed to a creep using the levers.
/ Front brakes on a Zero turn!! #16
My last property had much steeper hills than the one I have now. I complicated my situation by adding a Swisher 66" pull behind. Towing or not, once I spin, the Carlisle's load up and then I need to back up. Not so good when I have slid up against the fence.
I may try loading the tires or adding some wheel weights before I invest in different tires.
I honestly do not know if the brakes on my mower work with the hydraulic control position or not. I thought they were only for the parking brake? There is no foot pedal. As long as I can "feather" the hydraulics, I have good control going down hill.
/ Front brakes on a Zero turn!! #17
I have a JD 757 zero turn and I mow some very steep hills across the face of the hill, not up and down. I mow some of the very steep hills with my 4WD tractor by backing up and driving down very slowly. On those hills I would be afraid to mow with the zero turn up and down even with front brakes as they could possibly cause an end over. If it's that steep its time for the string mower! I do use the seat belt and ROPS on the really steep hills with both the zero turn and the tractor. When mowing across the face of the hills some of them are steep enough that I sort of mow at a 45 degree angle. It chews the grass up a little, but it grows back. I really don't understand the how the physics of the small castering front wheel brake system can be very effective.
/ Front brakes on a Zero turn!! #18
If you dont have enough traction from the tires, adding more weight will just make you more stuck. Get new tires first.
You probbaly have "engine braking" from the hydraulics through the sticks and a mechanical parking brake.
Aaron Z
/ Front brakes on a Zero turn!! #19
None of the ZTR's I've been around have much weight on the front end, I don't see how braking lightly loaded smooth tread tires on grass is going to help? We used to just run chains on the ride ons for the hilly wet areas.
/ Front brakes on a Zero turn!! #20
If you dont have enough traction from the tires, adding more weight will just make you more stuck. Get new tires first.Aaron Z
Good point. I have been pondering the lug type tires shown in the first photo posted by Gizmo2 since as I said, the one's in photo two do not work well for me. Perhaps the mower makes the difference? A friend went from the latter to the former and his mower works much better with the lugs. I have also thought about going to duals in a narrower tire to increase the amount of ground contact without going past my mower deck.
Aaron Z
That's what I figure, My joy sticks need to be pulled into the center from each side to go forward or backwards. If the brake is on, moving the sticks in will shut off the engine so the parking brake is only for just that, parking.
FWIW, I would not buy a Woods again, (I believe Grasshopper made the front mount for Woods that I have) but I have so much money in it, I need to put up with it until it is time for a replacement.
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2022 MAXEY MAXX-D 40’ GOOSENECK EQUIPMENT TRAILER (A59914)
2022 MAXEY MAXX-D...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
Here are some similar links:
