Lubricating LA524 Control Lever Linkage
/ Lubricating LA524 Control Lever Linkage #1
Rail Dawg
When you guys are lubricating the joints for the control lever linkage I assume there are no grease fittings for those? If there isn't a fitting do you simply put some of your regular grease in there or do you go about it another way?
Thanks!
/ Lubricating LA524 Control Lever Linkage #2
All I've ever used in there is an aerosol spray grease, it's pretty hard to wipe solid grease on so it gets where it needs to go.
Sean
/ Lubricating LA524 Control Lever Linkage #3
I've been using a silicon spray lately, tractor supply has some spray with graphite that I'll try next...I forget what it's called.
/ Lubricating LA524 Control Lever Linkage #4
Some aerosol spray white lithium grease.
OK thanks. So there's no actual grease fitting... I just spray it on. Appreciate the help.
There's a cover plate on the bottom of the control lever (L3800 w/ LA524 loader). Do any of you remove the plate or just spray in there?
Thanks.
Thanks.
Did anyone have some insight on this? Do I remove the cover to lubricate under the control lever?
Thanks.
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63688)
2019 Cadillac...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
