Winter Projects?
/ Winter Projects? #1
YannyMan
Taxachusetts
(3) YM146's, 1 GT14
What's everybody doing to their tractors this winter? For those that have winter... :thumbsup:
I'm going to rebuild my BM480 deck. It will include sandblasting the entire deck, powder coating it once stripped, rebuilding the spindles and replacing every nut and bolt with stainless units. Bye, bye rust! :thumbsup:
You?
/ Winter Projects? #2
I'm going to make a second attempt to install the hydraulic tilt onto the 3PL,
The first time didn't go so well:cool: I had a problem where I tried to locate the remote, Now I have found another place and actually more convenient to reach and out of the way from the lift arms, also a better straight line position for the hydraulic lines into the cylinder,;) Hope to have it working by spring,
Incidentally ..... I had to weld a ball socket onto the top of the cylinder so it would fit over the pin, I tried to weld in short intervals and let cool, But a couple of times I could smell rubber,:cool: what is the chances I might have toasted the seals? :eek: I have not yet test it with oil inside, although I have cap off the ports and cannot budge the cylinder in or out manually,
/ Winter Projects?
Sounds like they got a little melty... How much I can't say. ;)
/ Winter Projects? #4
I am hopign to get started on pulling the motor & rebuilding my engine in my 336d. and speaking of. anyone know hte best place to get rebuild kits? Reasonably priced would be nice also ha ha
/ Winter Projects? #5
Let's see:
Oil and filter
fuel filter
right brake shoes and brake drum oil seal (leaking tranny fluid).
new seat
replace cheesy spotlights on fenders made of plastic and keep coming off.
get horn working.
replace original headlight bulbs.
And maybe some paint and bodywork might be in order.
And forgot another: rear drive shaft seal is leaking.
It'll all be after Christmas though, Aaron, so you can hold off on salivating 'til after New Years. ;0)
Stan Henley
/ Winter Projects? #6
Not sure this could classify as a winter project but here is what I have been up too. First two pictures of my old toolbox arrangement which got hit too many times when my quick hitch goes to extreme height - last four of my new arrangement. Might wonder about the tach numbers in last picture. My old tach is not real accurate so those are corrected numbers using a Harbor Freight hand held tach. I use different pto gears in some situations and like to know how fast things are spinning. Things look a little crowded around the seat but I actually fit in there pretty good. One more thing, the 2x4 going across the fenders helps dampen the fender vibration I experience at certain rpms. Enough! :D
/ Winter Projects? #7
Nothing really. But i ned to do my annual oil change w/filter. And i have had the hydro fluid that i picked up at agrisupply back this spring, that i will change.
/ Winter Projects? #8
I did all of my maintenance over the summer so all i have to do is polish up the hood every so often. :thumbsup: I am in the midst of selling my yanny though, it will be sad to see it go but I need to upgrade to something bigger. ;)
/ Winter Projects? #9
Was thinking yall only had a few acres which at least half was woods. I knew you always are grating a dirt road but what do you need a bigger tractor for? I know we all want one but just curious about your needs?
/ Winter Projects? #10
Clemson... don't ya know he's a growing Boy, it's probably more him outgrowing the 169 rather than the size of his property, ;) .... myself being 6.2 230 lbs I could understand , Sometimes my 1700 seems a might cramped:cool: although I have made a few modifications to help with being more comfortable on it, custom seat bracket let the seat back further, a different steering wheel that brings it up higher for more lap clearance, wider/larger foot running boards, as well as the padding wrapped around the ROPS so that my elbows don't hit quit as hard when I turn to looked toward the rear to backup.:D
/ Winter Projects? #11
Looks like I get to put in a new clutch this winter. The loader finally took it's toll on it. Other than that, everything else is still working fine on it.
/ Winter Projects? #12
To YannyMAn
On changing to stainless steel bolts they might not be as strong as graded steel #5 SAE which is 3 </ . I have found them to gall if they are removed under torque and reused. I also feel they are more brittle than graded steel. For sheet metal great, but for holding the real parts on I would use only SAE graded I do not like spinning shafts chasing me.
I might be wrong on the grading of S.S.
Craig Clayton
/ Winter Projects? #13
For just grading the driveway, the yanny does a great job. But i need something more in the lines of a skid steer to do the work I have. I want to be able to split mass quantities of firewood, do some serious land clearing and leveling in the areas where we cut down numerous trees, defiantly stump removal and clearing heavy snow. I have used a skid steer in place of the yanmar for a day and the amount of work I got done was incredible. Nothing against the Yanmar, I just need something with better lift capacities, more maneuverability, and more hp. :) If i have enough $ I would keep my yanny but skid steers aren't cheap. :(
/ Winter Projects? #14
Will need to change oil this season. Had knee surgery last spring and did no maintenance.
/ Winter Projects? #16
I dont really have a project in mind on the tractor I am caught up on everything but my final drive noise. I will take that job on in spring when I am not needing to blade snow or till just give me a couple months window to accomplish that task parts avail etc.
I modified my post hole digger recently to fit the Yanmar and I mounted one of those 350# harmonic balancers I used for wheel weights on top of it.
The last 2 weekends I have built a 6' x 120' wood picket privacy fence next door at my garden property and man does that digger dig its like drilling in butter. :thumbsup:
/ Winter Projects? #17
I was thinking just what your last sentence was. a used Skidsteer is in the 15K range give or take 5k depending upon how beatit is. And dont those fire wood processors for the bobcats cost like 30k? Seriously that will never pay for itself for personal use, you would need to sell several cords a week to pay for that i would think. Also i dont think a skid steer can efficiently dig stumps out, can it?
/ Winter Projects? #18
For firewood, I could make a log splitter for around $1000 which would be operated from inside the cab. For stump removal, I would get or make a backhoe that would also operate from inside the cab, It would be identical to my grandpa's backhoe : Skidsteer Backhoe - Tractor Videos - Kubota, John Deere, New Holland and More You are correct on the price. I am saving up to get into the $15k range. Locally there are several decent, low hour machines available in the $15k range. As far as how much wood I split, i split 11 cord and sold it this year in 2 weeks time and have the ability to process much more wood given i have the equipment to get it done in a short period of time. I can say I am well on my way towards my goal, and i will keep working at it. The way I see it, I only have so long where i wont have any monthly payments, now is my chance to save up for my goals. Besides, when I am older I will tank myself for buying the equipment to maintain my property or have it for odd jobs. :)
/ Winter Projects? #19
Trust me buy it now! You will never live cheaper than when you live with mom and dad. I would live with them as long as you and they can stand it to save up for when you move out. Im amazed at how much money i seemed to have when i made 10K a year when in school etc. I make $60k now and due to all the things you have in life it dosent seem to be as much as when i was in college partially under others wings still. I bought all my own chlothes gas fixed things myself and paid my insurance. But being out on your own there is food, gas, power, cell, cable , i net, house health ins, home ins, taxes, car ins, truck maint, trk payments if u got one (i have none) taxes on every **** thing like boats etc. I think you need to make $100K in todays world to seem like you are well off?
/ Winter Projects? #20
Very true. I am fortunate enough to have the ability to make $$$ doing various jobs. I know that this is my best chance of getting the $$$ to reach my goals and I will thank myself later in life for achieving my goals. :)
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
2011 WESTERN STAR 4900SA (A63569)
2011 WESTERN STAR...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2012 PETERBILT 337 FLATBED W/ LIFTGATE (A67714)
2012 PETERBILT 337...
2013 Ford Fusion Sedan (A66738)
2013 Ford Fusion...
3144 (A63117)
3144 (A63117)
