Wire welder torch connect, + or - ??
/ Wire welder torch connect, + or - ?? #1
SSdoxie
Elite Member
Cumberland Plateau, TN
Bobcat CT225
I have 120V 125 amp wire welder, mig capable. It says to hook up torch to negative with flux core wire and to positive for solid wire. What is the defference? Does one give hotter arc versus the other? I have always used with flux core because I am either welding outdoors or with shop door wide open.
/ Wire welder torch connect, + or - ?? #2
I am going to wade in here and get blasted out. I have a 240V AC stick machine. But I do know of the rods NOT to run. When on DC stick rods are marked as to the correct polarity for the charertics to make a good penetration.
When your manufacture says to change the polarity about for solid or flux wire it is to have more heat in the wire or base.
Craig Clayton
/ Wire welder torch connect, + or - ?? #3
Miller - Successfully Welding Sheet Metal With MIG And TIG
Electrode Polarity
For welding with solid wires, use electrode positive or "reverse" polarity. While EP directs more heat into the base metal than electrode negative (EN or "straight" polarity), you will obtain the best results with EP and following the guidelines provided here. If you've been using flux cored wire, be sure to change your machine's polarity from EN to EP.
Read your WIRE makers directions for flux core polarity if using specialty wire:
Why does flux core MIG require negative polarity? - Yahoo! Answers
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
1999 INTERNATIONAL (INOPERABLE) 4900 (A67714)
1999 INTERNATIONAL...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2020 CATERPILLAR 289D3 SKID STEER (A65056)
2020 CATERPILLAR...
2013 CHEVROLET CAPRICE CAR (A66091)
2013 CHEVROLET...
2016 Dodge Grand Caravan (A66738)
2016 Dodge Grand...
