different kinda of grapple
   / different kinda of grapple #1
mroldstyle
cataract wi
2003 New Holland tc 29d
Heres a few pics of a log skidder type grapple I recently finished. I have some red pine plantations that need to be thinned this winter and hope to make good use of it. Fire away with questions or comments. I did a few preliminary pulls with it before painting, but dont have any good pics, Ill try to get some action pics if I think of it.
   / different kinda of grapple #2
Pics?
   / different kinda of grapple #3
Looks awsome!! I broke down and bought the wallenstein model and don't know how I ever lived without it. Great build and hope it serves you well.
   / different kinda of grapple #4
That looks real good.
   / different kinda of grapple #5
Looks really good :thumbsup:
Don't tease us, Give us some details :thumbsup:
I see you have a swing cylinder can you also rotate it ?
How much does it weigh and how big a log can you drop it down on ?
Are you running a fixed or hydraulic top link ? (From the picture it looks fixed maybe)
Get some action pictures
   / different kinda of grapple #8
Did you build the grapple also? Real nice! All you need now is a winch tucked into it and you would have my dream setup. Tell us some details and get that camera back out!
Thanks for showing.
Yes it swings from side to side hydraulicaly (sp?), it does rotate but only if you were pulling a log around corner, then returns to center, via spring. Spring is under the box up on top.
Havent calculated the weight yet, I dont have a scale but have a link to a weight calculator so I will try to get to that.
Point to point opening is 39", widest inside spread is 52".
I'm using an "adjustable" fixed top link. Not sure if there would be an advantage to a hydraulic for this or not. Other than a reason to buy one.:)
Thanks for showing.
yes that was last years project. Winch would be something to think about. Hmmm.;)
   / different kinda of grapple #11
Sorry, I just zoomed in on your pics and see that you did. Again, Real nice!
   / different kinda of grapple #12
It's a very impressive build... :thumbsup:
(darn I hate people like this... I feel so unmanly :p - I'm sure I just need more tools? :D plasma cutter for one :licking:)
THANKS for all the compliments!! I will get some more pics, I needed 3 hydraulic circuits, 1 for the clam, 1 for the swing, and 1 for the front grapple. which I want to be able to use for piling pulp. My tractor only has 2 rear remotes so I had too put in a selector valve, so with the pull of the valve I can switch from the swing circuit to the front grapple. I also put in a couple of needle valves to slow things down a bit. I will shoot some pics of the hyd. tommorrow and post.
   / different kinda of grapple #14
Well it looks like your talented enough to (next winter) make a hyd. tank out of that boom and add a pto pump with a 3 valve bank that you could reach from the seat to run the whole rear grapple and (soon) winch!
   / different kinda of grapple #15
That's gorgeous! :thumbsup:
Thanks
Interesting idea, but after some quick and rough calculations it would hold less than 10 so might not be worth it.
   / different kinda of grapple #17
Great job Looks Like factory built
I have been gathering info on and off this year ,on building a smaller version of the grapples I see on the internet.. I actually met with my welder friend yesterday. This is insperation. I will have somthing to show before spring. Mine will be much smaller though. Just for say 16 inch butt and down is all i need. Do you know how many pounds of pressure you have on the log grapple cylinder?
   / different kinda of grapple #18
That looks great, very impressive! What is the thickness of the steel used? Can you please add some photos of your grapple? Thanks, Stanley
   / different kinda of grapple #20
Very impressive!!!!!!
I'm looking forward for some pics of it in action. Do you have any steering problems or need for more weight up front? How about a video on youtube?
Thanks for sharing,
Eddie
(2) USED 3500 LB TRAILER AXLE W/ BRAKE (A60432)
(2) USED 3500 LB...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2020 DRAGON ESP...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
UNUSED FUTURE FTH50-(50) SHEETS OFGALVALUME (A60432)
UNUSED FUTURE...
2016 KOMATSU D65PX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
