JD 3720 Noisy Hydraulics
/ JD 3720 Noisy Hydraulics #1
TC33DA
Member
North Carolina
I needed to move some dirt and gravel the other day and noticed my hydraulics were noiser than normal. The outside temperature was in the 40's so it was cold. I let her warm up for 10 minutes and the engine temp was normal. When I raised the FEL the hydrualics were noisy almost a winning noise. Same from the the 3 pt when I raised the box blade. No issues when moving the tractor. It is a hydro. I know the hydra fluid is thick when cold but thought it should have warmed up. Maybe not since I did not really work it.
/ JD 3720 Noisy Hydraulics #2
Did it quiet down after using the FEL for a few minutes? If yes it was probably the cooler oil. Since the tranny is HST the charge pump helps warm it but this heat is not transfered to the FEL circuit until you start operating it.
Roy
FEL was still noisy after running the system. Talked to dealer and he said the "screen" before the pump might be dirty. Only has 100 hours so it is in warranty. Headed to shop after holidays.
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
Unverferth 432 (A64119)
Unverferth 432...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2013 Bomag BM-211D Vibratory Soil Compactor (A61572)
2013 Bomag BM-211D...
2009 389 Peterbilt Winch Truck (A62679)
2009 389 Peterbilt...
HARDEE GATOR TAIL PTO PUMP (A63291)
HARDEE GATOR TAIL...
