Electrical test meters,,,got one ?
/ Electrical test meters,,,got one ? #41
its so slow now... i dont do much of ANY work :laughing:. but i do have 3 new 3500-3800 sf customs that i just signed up...maybe things are finally turning around??
What is bad for someone like yourself being a local in Idaho is that often government jobs help outsiders more than locals. One of my last jobs was northwest of Idaho Falls, they paid me to travel from southern New Mexico up there to perform some repairs.
/ Electrical test meters,,,got one ? #42
Never had one living in the city, but was one of the first things I bought when moving to a rural area. Between the well and a few other projects this has been a life saver.
/ Electrical test meters,,,got one ? #43
I have four meters and enjoy the learning. One of the first tools I bought my son was a meter and showed him how to use it. I am still learning and enjoy the dialog in the Forum.
/ Electrical test meters,,,got one ? #44
Well the Simpson 260 served me well for years. It would work on firealarm systems and my $300.00 fluke couldn't do it. I do like the hrz setting on the Flukes for the adjusting of Gen-sets and checking a lot of other problems..
/ Electrical test meters,,,got one ? #45
I remember using the Simpson 260 and Triplett 730 back in the 70's and they were good for tuning as watching the needle move was more intiutive. Now I don't have anything that requires tuning though so not much of a need anymore.
/ Electrical test meters,,,got one ? #46
One of my meters is a Simpson model #260. I have owned it many years and recently it quit working. I have changed the battery and checked fuses but no luck. Love this unit but now it doesn't work. Any ideas?
/ Electrical test meters,,,got one ? #47
First and obvious thing: If you can't get ANY readings at all, have you verified your leads are working?? It's possible one of the leads could have a frayed connection where it solders to the jack, or the test probe. If you are able to get ANY sort of readings, then the leads are obviously ok. Which leads to a likely defective component on the board inside it, or possibly the meter movement could have gone bad. Only way to tell that is to open it up and start checking things with another meter.
/ Electrical test meters,,,got one ? #48
Hadn't seen it here . . .just an FYI for the casual user.
Beware of the $5.00 analog meters around digital control circuits.
The meter's internal resistance is rated at 5000 ohms per volt.
When doing resistance readings, enough current will flow from the meter to damage digital circuits. I won't buy a meter rated at less than 20000 ohms
per volt. Worked electronics for the last 45 years and seen a lot of people that should have known better :(do stupid things with meters . . .such as measure -21000 volts on a high power r.f. transmitter with a common meter. It arced from where the banana plug went in the meter to his leg.
/ Electrical test meters,,,got one ? #49
Yep. Fluke digital automatic. Idiot proof. I should know. :D
/ Electrical test meters,,,got one ? #50
I didn't want to get into testing anything other then our tractors.
Just makes it more confusing for some and I'd really feel bad if somebody got hurt with higher voltages.
Aw heck Willl, it took 8 or 10 replies go get off track on this one. Usually it only takes 2 or 3.:laughing:
/ Electrical test meters,,,got one ? #51
Had a case where automatic was not "idiot" proof. I test stuf as a final check before they go out the door at work. A fellow had done final assembly on a system that charged its battery backup from AC, but actually ran from the battery. The charger was purchased speced to support the system at max demand. The guy checked that the charger and all system modes worked, but did not catch that the battery was discharging under the high demand mode. The reason was an automatic ranging meter. The meter set itself to a comfortable range - one range higher than was actually needed for the voltage. When I tested manually with a meter set to a more sensitive range I saw battery V constantly decreasing. He hadnt seen it because he would have had to look 10 times as long. The supplier had mistakenly supplied an identical looking lower capacity charger. Automation can mess you up ... right after it makes you complacent.
larry
/ Electrical test meters,,,got one ? #52
ok, heres another one... how can i convert one of my electrical meters to a turkey temperature readout for next years thanksgiving dinner?
/ Electrical test meters,,,got one ? #54
I have an air probe that I insert in plenums that would handle that job easily. Should work with most meters The probe is long enough to stick into the center of a large turkey to get your reading.
What I use in my kitchen is a good quality thermometer with probe used in boiler systems and hydronic heating. These would normally be used to measure the temperatures in a heating system and are vastly superior to the crap sold to women to use in their kitchens.
/ Electrical test meters,,,got one ? #55
larry
That is a profound statement, Larry. I need permission to borrow that one.
FWIW, the meter I have had least joy with was the most expensive I have purchased. A Snap-On auto-ranging unit made by or cloned from Fluke. First and last auto-ranging meter I will ever own.
/ Electrical test meters,,,got one ? #56
Rick,
My Flukes are auto ranging but do indicate which range you are on. You can still use the meter in manual mode too, user selectable. I use a
Fluke 187 dvm, and the 336 current clamp/dvm.
/ Electrical test meters,,,got one ? #57
Rick,
True, but one needs to deselect auto ranging. I have other issues with this unit that are unrelated to the autoranging function. It boils down to a lack of confidence and general bad attitude on my part toward it at this time. It is simply an overpriced POS real or imagined. I have a MATCO that cost half as much that I would hang my hat on every time.
/ Electrical test meters,,,got one ? #58
On Simpson 260 be sure to read out your leads to make sure they have continuity? Use your other meter to do it? Sometimes they break inside without showing, then there is the stretch test ? They will stretch at the break? A battery usually brings mine back. Now I need to remember to remove the battery, to prevent leakage from it sitting?
/ Electrical test meters,,,got one ? #59
Simpson 260. Used it professionally for years to diagnose and fix consumer electronics. Bought it in 1971 and still have it. As stated in an earlier post, it is as much how the needle swings as it is where the needle stops, especially when measuring across PN junctions of semiconductors. I could tell instantly if the solid state device was blown or not just by observing the needle swing.
Best combination for electronic troubleshooting just about anything analog is a 260, Fluke, O-scope, signal generator and Variac. You can make a living with just those five instruments.
/ Electrical test meters,,,got one ? #60
Appreciate all who have provided comments on the Simpson 260 and hope to have it back and working soon. It is a great tool if one knows how to use it properly. Do you think I could locate a user guide somehow, somewhere?
PALLET OF AMMO BOXES (A64281)
PALLET OF AMMO...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
Caterpillar 322B/ 322BL Excavator Service and Parts Manuals (A63117)
Caterpillar 322B/...
2006 KENWORTH W900 T/A DAYCAB ROAD TRACTOR (A64276)
2006 KENWORTH W900...
2021 Land Pride RCF2072 6ft. Rotary Brush Cutter Tractor Attachment (A61572)
2021 Land Pride...
PALLET OF (73) 4.80/4.00-8 GOLF CARTS TIRES (A64281)
PALLET OF (73)...
