My Latest Knife
/ My Latest Knife #1
Jeff Lary
Hartland Maine
Kubota L2950
I have been making a new knife and finished it today.Every deer season after I get my deer for the last 4 years I have retired that seasons Knife and built a new one.This one will be for the 2012 season if I am lucky enough to get my deer next year I will build a new on for the next season. It is just a hoby hope you enjoy the photo, I will hand sew a new leather sheath next.
/ My Latest Knife
Well I will try the Knife photo again,If you check this out and there is no photo and you want you could maybe help me caues this is my third attempt.If you help thanks
/ My Latest Knife #3
Nice,.
Kinda fun to do as well.
Last I made used an old metal file and shaped it into a general purpose/skinning blade.
We were able to quarter a large moose without honing the blade.
File steel sure keeps a good edge.
/ My Latest Knife #5
Good looking knife. I had a friend in Tennessee. whose Father made and sold knives that he made from crosscut saw blades. When his supply of crosscut saw blades became low, he sometimes substituted circular saw blades. What kind of wood is the handle made from? At first, I thought it might be rosewood, but it appears to be stained. :thumbsup:
/ My Latest Knife
It is made from a sash gang saw blade I used to be a saw filler for Hancock Lumber in Pittsfield me.The wood is Cherry it is not stained just clear poly it came from my fire wood pile.
/ My Latest Knife #9
Nice work Jeff! Its nice to see excellence in American craftsmanship.
/ My Latest Knife #10
Good choice in wood. I really couldn't tell from the photo. Didn't mean to appear subjective in regards to the stain issue. Good handiwork.
/ My Latest Knife
Well I dont know about excellence but this was quite a bunch of work to be sure.That itself can be a problem for me as I have almost zero patience. But I have learned a lot doing this and no matter when you screw it up by hurrying, you have to remember there is probably a bunch of work to get to the point that you just screwed up. It's no fun to mess up 10 hours into a project.
/ My Latest Knife #12
Do you re-harden it after you have shaped/formed the blade?
/ My Latest Knife
No I do not with the saw steel I do not have to anneal it so no. The saw's have a rockwell hardness of 63.With the the bering race yes 500 degrees for 1 hr ,air hardening I think it is called ( no water or oil used)I let it cool in cat litter or just wait till it it cool enough to touch
/ My Latest Knife #14
>>>>>Jeff Lary<<<<
Great looking.
Here is one a fellow veteran made for me, its stone with a antler handel
Army Grunt
/ My Latest Knife #15
Here is the one.
Army Grunt
/ My Latest Knife
Thats quite a knife very crafty I must say good job
/ My Latest Knife #17
Nice knife! Here's a Damascus blade that I made for a friend. The handle is not carved it just looks that way. Spalted Big Leaf Oregon Maple.
/ My Latest Knife #19
Nice,.
When you use an old file do you just slow grind it to keep the temper. ie. grind dip grind dip?
/ My Latest Knife #20
Wow nice work guys, the stone knife is really a piece of art! I too am an amature knife maker. I make mine from leaf spring steel and hammer forge them. I've only made 6, wish I had more time to do it. The details are very time consuming. This is knives #5 and #6, I made them for my best friends. They are both hunters, so I get plenty feedback on how they perform. The secret is is the heat treat as you all know, but these have cleaned 5-6 deer/hogs each and still shave! When we get moved out to our homestead I plan to set up a nice permanent forge. I plan to try a forge welded, or "Damascus" blade next.
Wagonranch, did you forge the blade yourself? Very nice by the way!
case 370 glass door never installed (A61307)
case 370 glass...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
500 Gallon Pull Behind Sprayer (A61166)
500 Gallon Pull...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
