shooting rest build ideas plz
   / shooting rest build ideas plz #1
Mean Jean
Gold Member
Hazelridge, MB
Kubota L1801 and Massey 65
Looking to build a shooting rest.
Who has plans for an easy build?
Rifle, not handgun.
   / shooting rest build ideas plz #2
Just search homemade shooting rest and you'll find a bunch. When I worked for Remington, all we used were leather sandbags on all the test ranges and that was for 100's to 1000's of rounds per day.
   / shooting rest build ideas plz #3
Lotsa ways to build a "shooting rest". I used to manufacture a wide variety of monopods, bipods and tripods....and all of these were called "shooting rests". But I belive you are looking for a shooting table (or a shooting bench). No?
I've seen lots of plans for a portable shooting benches and designed some rigid steel frame benches with wood tops for our local rifle range.....and a few portables for my own use. Maybe a bit more description on what your looking for would help get you steered in the right direction. :confused:
I poked around on-line for pics.
90% of the pics were of bench rests made of titanium, with 34 different adjustment points, and 3 carpenter levels.
I thought I would ask here as we tend to be resourceful, and creative folks.
Cheap and easy is what I'm after.
A step above sand bags would be great.
I would like a rest which can be shot off a bench, or from the truck bed.
Not too heavy.
Any bi-pod and tri-pod ideas would be great.
   / shooting rest build ideas plz #5
This is the one I built for prairie dog shooting. The top is a hollow core door and the legs are the ones you buy to make folding tables. I cut the rear leg down to a single to give you room to sit. It is light weight so I could carry it to different shooting points.
   / shooting rest build ideas plz #6
FEMA... sandbags. Fill with sand. Adjust as necessary. Trying to duplicate something like the Caldwell Lead Sled seems like a lot of labor and $ for marginal return.
For my rifles I put Harris bipods on the front and then on my long range rifles they've got a rear monopod.
-Luke
   / shooting rest build ideas plz #7
For supporting the rifle on a hood or shooting bench, I use a one-of-a-kind rigid foam front rest with a V in it.....and use a bunny ear leather rear rest filled with kitty litter. Purrfect! :thumbsup:
I really like the front and rear rest as opposed to a metal cradel rest or a "lead-sled". Maximum versatility and better accuracy with most guns. If you want a lead sled....save your time and money.....I think your better off buying one than building one.
I would prefer to build vs buy.
Biggest reason is b/c I like the R&D, challenge, and time in the garage.
Luke, did you build your monopod?
Could you post a pic?
Rigid foam is a good idea, and I have some hanging around.
I'm considering using the foam from the inside of a hockey helmet.
Some guys use a mouse pad. Contors easily, readily accessible, and cheap.
Foggy1111
AGREED
   / shooting rest build ideas plz #9
I use the legs of old blue jeans and fill with sand. I usually end up in the bed of the pickup on a stool shooting over the cab....or over the hood.
A good rest is key to sight a rifle.
   / shooting rest build ideas plz #10
On my 50 the monopod is built into the stock.. Barrett M82A1.
Rem 700 has a "gun show" stock that had it as a feature. Dunno the brand.
   / shooting rest build ideas plz #11
A step above sand bags would be great. QUOTE
Search---auto jack shooting rest--------for cheap and easy
Very nice, there are a few designs to work with.
I think I've found a winner.
   / shooting rest build ideas plz #13
I have a steel ironing board works great and portable
Ironing board, I like it!
   / shooting rest build ideas plz #15
XXXXXXXXXXX
Here is a very simple rest to make. Adjustments are solid and fairly easy to do.
Rest is made out of 1" X1/8" box. I suppose you could use 1X1X1/8" angle for the front and rear cross pieces and the feet/legs and make it even lighter if so inclined. I prefer a heavier rest. I usually put a sand bag on each side of the front cross member.
The front yolk is made out of a 3" pipe/EMT hanger. The rear is a 5/16" bolt with the head cut off and welded onto a short/bent piece of chain link tension bar. Both were dipped several times in plastic dip to give them some padding and scratch prevention on the rifle stocks. Front has infinite adjustments until it bottoms out or completely unscrews itself. Rear only has about 1" adjustment.
Fine adjustment is done my turning the 5/16" knurled knob loacated on the top/center of the upper arm.
This is a picture of my pistol back stops. 24" X 48" X .250" plate. Lag bolted onto the 4X4 or 2X4 pressure treated frame. I have shot warm 30-30 rounds at both from about 60 yards and they deflect downward as they should. The do put a dimple in the plate though. Pistol rounds just seem to leave a streak of lead and or copper as they deflect down. About once a month I reclaim the lead and make fishing weights out of it.
Here is a picture of what a good rifle in a good rest can do with an experienced shooter and a long time reloader can do. The shot on the left was my first shot at center mass of the plate. I guess I over corrected about 1" for the next 3 shots. The last three shots are overlapping and are about .7" center to center.
Hope this helps a little.
Chain Bender
Thanks very much for the ideas.
I will incorporate (steal) some the the designs you've used for your rest.
That's some great shooting from 305 yards, very nice work.
   / shooting rest build ideas plz #17
XXXXXXXX
thanks,
I think the next one I build will be wider and longer on the bottom half and incorporate a turn-buckle as the finite adjustment. Been too busy making booms (front and rear) root rakes, ballast weights, bucket forks, carry all's and playing to get serious with a new rest. But I think that will be my next mini-project. Can built that in less than an hour if I don't stop for a coffee break.
Good luck with your "steel".
CB
   / shooting rest build ideas plz #18
XXXXXXXXXXX
Chain Bender
Those dimples in the plate (shown above) is what can get you hurt. A bullet that hits into that dimple can follow the curvature in order to ricochet back at you or bystanders.
Allowing the use of ammo that can make dimples is a no-no. Either use harder steel or reduce the velocities IMO.
   / shooting rest build ideas plz #20
Kays_Supply,
I like your shooting table.
I might be thick headed, but I'm not sure exactly what you did in cutting the rear leg down to a single? In the picture, I can't tell. Seems like if you cut one of the upside down u shaped legs off, it would wobble. Got any more pics?
Thanks.
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2018 CATERPILLAR D6K2 XL CRAWLER DOZER (A60429)
2018 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED FUTURE MINI...
iDrive TDS-2010H...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
