At Home In The Woods
/ At Home In The Woods
On Saturday, after I had carried the log pieces to the splitting area, I cut them into 18" lengths. I have two chainsaws, one with a 14" bar and one with a 20" bar. I inherited both saws from a relative. The bigger saw has been sitting in our basement because it would not start. A few weeks ago we took it to a chainsaw shop and had them clean the carborator and get the saw to run. Even though I did not need the big saw Saturday, I used it to see how it ran and to use up all the gas in it. The saw ran fine. It seems to cut through the logs a little faster than the small saw; it might just have a sharper chain. The bigger saw is significantly heavier than my little saw. Bending over the logs with that heavier saw did not make my back happy.
I set one of my new box crates beside the splitter so that I could take wood off the splitter and stack it directly in the box crate. That arrangement worked out awesome. These box crates are extremely convenient. Man I would love to find more of them!
I am enjoying the log splitter. I stacked some logs beside the splitter and used them as a makeshift table. I placed pieces of logs on the log stack while I was splitting a piece to reduce the number of times I had to reach all the way to the ground to pick up pieces of wood. For easy to split pieces, the log splitter doesn't really speed up the process much over using a maul and axe. However, the log splitter really helps when splitting knotty, forked, and otherwise difficult to split logs. In addition, using the splitter doesn't wear me out like swinging a maul does. However, I did find my lower back getting tired as I stayed bent over the splitter. If the splitter were a foot higher off the ground, my back would complain less.
At the end of the day, my wife stacked the second pallet while I split the wood. We then put plastic over all the pallets of wood. I wish I had covered the pallets two weeks earlier before we got all the rain. Our firewood got pretty wet and now we are having to burn some wet wood.
Tomorrow I have an appointment at a fireplace store. I am going to compare the combustion air control on their Quadrafire 7100 fireplace to the control on our fireplace. I would like to put to rest the question as to whether or not our fireplace has a manufacturing defect.
Tom,
Thanks for the info. I would need 15 or 20 baskets to store my firewood. At $50/ea that turns into $1000. Plus, they would just sit out in the weather and rust if I used them just for storing my firewood. However, I could see the usefulness of having one or two around to use for easily transporting stuff.
Obed
/ At Home In The Woods #3,545
Fix that break on the top rail by scabbing a board over it, before it dumps your whole load. This kind of effort expended up front saves effort later on.
/ At Home In The Woods #3,546
Why is it I have the feeling you have a closet full of blue shirts and grey pants?
Am I the only one who never buys clothes specifically for outdoor work.
I hardly ever weary anything fancy, so when clothes get worn or too dirty, they get demoted to "work clothes" and I get something new for casual wear.
The only problem is that it takes an awful lot for something to go from "work clothes" to rags, and I have mostly work clothes.
/ At Home In The Woods #3,547
You put the stabilizer legs on the roof. That way you can use the standard ten inch version. Also, the ladder can't slide sideways (even with the legs on a pile of wood!).
That one tip is worth reading the entire thread.
Every picture I have seen of a stabilizer, it is resting on the side of the house, and I never even thought about a better way.
Putting the stabilizer on the roof makes a lot of sense.
/ At Home In The Woods #3,548
No i dont buy work chlothes. I just wear my normal daily stuff or stuff that holy or dirty that i dont wear to work. Im a forester so my work clothes look like my "work" clothes in most cases.
I went to the fireplace store, American Fireplaces, in Sevierville, TN this morning. This is not the store from which we purchased our fireplace. Our store does not have a display model. The salesman Jerry at American Fireplaces was extremely helpful, especially considering that I am not a customer. Jerry helped helped me remove the faceplate and air control cover so I could compare their fireplace to mine. I took measurements of the air control in their fireplace and compared them to ours. The measurements were the same. I have to conclude that the air control device in our fireplace was manufactured as it was intended.
/ At Home In The Woods #3,550
There's chemical totes that come with a metal cage and pallet, around here they sell for about $100 with the tank included. They would work great for firewood.
/ At Home In The Woods #3,551
Obed,
Have you tried using the splitter in the vertical position? The advantage is twofold. One, on the bigger rounds you just roll them around and not having to pick them up. The second thing is take a round and use this as a seat and set next to splitter, this way youæ±*e not bending over the splitter. Helped process a lot of wood over the years, still hard but enjoyable work.
Dave
/ At Home In The Woods #3,552
Obed,
Have you tried using the splitter in the vertical position? The advantage is twofold. One, on the bigger rounds you just roll them around and not having to pick them up. The second thing is take a round and use this as a seat and set next to splitter, this way you羆*e not bending over the splitter. Helped process a lot of wood over the years, still hard but enjoyable work.
Dave
This is exactly what I do...I line up the rounds and sit on one an just roll them into the splitter set up vertical...makes it so much easier..then when I have split all those I line up some more ..I never end up lifting a whole round or bending much at all...Sure is better..
/ At Home In The Woods #3,553
Obed, just wanted to comment, I like you thread. :thumbsup: I'm a 'do it yourself' guy as well and while I'm not a professional at everything, I get things done as best I can and usually enjoy doing it. Keep it up!
/ At Home In The Woods #3,554
Obed is kind of like Jim Carrey in the Truman Story. We are all watching from the outside and rooting for him.
Obed, you have an awesome place that is truly the fruit of your labor. I like your resolve and "can do" attitude. That is why i continue to read this.
Wood_Butcher_Dav said:
Obed,
Dave
Dave,
No I have not tried vertical yet. I am interested in seeing how that goes.
Obed
Kyle and sld,
Thanks for the kind words and encouragement. This thread has been invaluable to us. There have been many times my wife and I have been discussing a house question and my wife has asked me to post the question on TBN to see what you guys think.
Obed
/ At Home In The Woods #3,557
Obed said:
Kyle and sld,
Obed
Smart lady.
/ At Home In The Woods #3,558
Do you ever just put the cut wood in the front end loader, position it so you don`t have to bend down, then put the split wood in the near by bin so you can then just lift the whole load up to wherever you store it? Tony
/ At Home In The Woods #3,559
We use these IBC totes all of the time. We get them in 275 and 335 gal sizes - used. We pop the top of the cage off, then cut the tops out to make a very sturdy pallet with sides. Most will have metal pallets.
We order them by the semi load (60 per load). Your trucking cost is the major factor, but I have got them at less then $40 ea. Of course that's for a truckload.
1995 Ford LN8000 Galbreath T/A Roll Off Truck (A61568)
1995 Ford LN8000...
DSP 900 Balancer with Split Weight (A63118)
DSP 900 Balancer...
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
New/Unused Pallet of 5 Binders and 10 Chains (A61166)
New/Unused Pallet...
2007 Caterpillar C5000 5,000lb LP Forklift (A61567)
2007 Caterpillar...
John Deere 2355 Tractor (A61166)
John Deere 2355...
