DK45SE HST FED won't Engage
/ DK45SE HST FED won't Engage #1
stacemoss
2006 Kioti DK45se HST
I have a DK45se HST with about 600 hours on it. The FWD switch is not engaging the front wheels. The light comes on solidly if the switch is engaged, less bright and flickers, but never goes out when I turn of the switch off.
I did check under the tractor for unplugged connections or other obvious issues, but everything looks good there. I raised the front end of the tractor, raised one rear wheel and hit the forward pedal. The rear wheel spun, the drive shaft to the front end did not with the switch engaged or non engaged.
I understand that there is a magnetic switch that engages the FWD system to spin that driveshaft.
Is this something I can test and get to easily? Any help would be appreciated!
/ DK45SE HST FED won't Engage #2
im looking thru the service manual
heres the info for the switch.
also, check fuse #4 . it supplies 4x4 and pto engage
/ DK45SE HST FED won't Engage #3
heres a blurb on the FWD system...for what its worth. again fuse seems like the likely thing
Thanks, I'll check those out soon. Would the light for the FWD be on if the fuse was blown?
/ DK45SE HST FED won't Engage #5
that i have no idea about. it might be powered by some other source.
does your PTO engage.....i mean actually turn?
/ DK45SE HST FED won't Engage #7
I've attached three circuit diagrams for the Australian EX series that seem close to the DKSE series. I have the DKSE manual and the diagram for this part is the same(posting the EX diagrams is easier than scanning parts of the DK diagram).
Electric_1 and Electric_2 show the 4WD light as always "hot" and the '21' reference on Electric_2 connects to '21' on Electric_3, which completes the connection to ground. I'm not that good at these, but it appears this connection will be made (and the light will shine) even with a failed 4WD relay and/or a failed PTO\4WD fuse.
From the diagram it looks like if the PTO is working the fuse for PTO and 4WD is OK; and the problem (if electrical) would be the 4WD solenoid or its wiring.
  • Electric_1 106.pdf
  • Electric_2 107.pdf
  • Electric_3 101.pdf
/ DK45SE HST FED won't Engage #8
stacemoss,
Just out of curiosity, did you figure out the issue? I've been having problems of the same nature recently. I suspect it may be related to the ignition and thus the electrical.
I too have a clear light come on. For a while, I could get the 4wd to engage when the switch was off, but not when on. As of today, it won't engage either way. I'm planning on getting a new key switch on Monday and I hope that fixes that problem and an issue I'm having with my glow plugs not working properly.
Justin
/ DK45SE HST FED won't Engage #9
Happened to me a couple of times on my DK40se. Each time I had managed to disconnect some of the electrical connectors under the operator station just inboard of the left step. Reconnecting fixed it. Brush was the culprit in each case and I think it was when I was reversing out of thick brush.
stacemoss,
Justin
My issue was with the PTO solenoid. It was shorted. With the PTO switch engaged, the light stayed on for the 4WD. I disconnected the PTO solenoid and everything works great now.
/ DK45SE HST FED won't Engage #11
I have a Bobcat CT335 (similar to the DK35) with HST drive and have noticed a few times when I disengage the the front wheel drive (FWD light does go off) that it doesn't always fully disengage until I move forward a distance. Then it in disengages with a noticeable clunk. Has anyone else experienced this issue and if so what was involved in fixing it. By reading the above I have clearer idea what actually process engages/disengages the front wheel drive but still looking for some incites into fixing my issue.
/ DK45SE HST FED won't Engage #12
Are you disengaging while stopped or while moving? Has it always done this since new? Are you engaging 4WD while moving? If so, you should be stopped completely before engaging 4WD or damage may occur.
/ DK45SE HST FED won't Engage #13
I've got a couple hundred hours on this tractor and I never noticed this happening till just recently. I've always come to a full stop before engaging the FWD. Since I noticed this issue, I've been reversing a short distance prior to/or post shifting from FWD which helps with disengagement. I'm hoping its just an adjustment to the solenoid or maybe a poor wiring connection, but I've had no luck actually finding the solenoid and I'm starting to wonder if its housed inside the transmission housing.
/ DK45SE HST FED won't Engage #14
A couple of additional questions: Is this tractor under warranty? If so, contact your dealer; if not I suggest re-posting in a new thread- here in the Kioti section, (or in Bobcat section), and see what answers you gain from a fresh thread addressing your specific issue, which is somewhat different than the OP who started this thread.
Basic start at the beginning question: have you checked the axle fluid and made sure it is at the proper level in your front axle?
I doubt the solenoid is buried in the transmission, but I could be wrong.
Someone here should be able to verify location....
If you don't have a local dealer you could contact Rick Wallace of Wallace Tractor, a former Kioti dealer, now a Bobcat dealer. He knows his stuff and is well liked on TBN. He should be able to get you any parts you might need and tell you where to locate the solenoid for the 4WD.
