Drying Firewood
/ Drying Firewood #21
What is a "rank" of firewood? Never heard of it. Measures out to be 44 cubic feet? Which is a little over 1/3 of a cord. People who buy "face" cords need to be careful, but most of them are ignorant. A normal pickup truck cannot haul a full cord of wood without some serious bending of parts/dragging on the tires.
btw I have cut and hauled many, many cord of wood over the years -- usually hauled 1/4 to 1/2 cord at a time.
/ Drying Firewood #22
Around here, a third of a cord has been called, "a rick."
I cheat on my cords by bucking to 15 inches instead of 16. So, if you get a cord from me, it will be 1/16th short of 128 cu. ft. It will likely, however, have been pressure washed of dirt and moss, delivered to the shed (I appreciate it when I get help stacking it, bark side down in their shed), and will be seasoned and dry come the fall. No one ever gripes about my cheating, as I do this service for my neighbors each year for free. The 15 inch length makes it easy to load my 47 inch wide cart.
If you could be a decent neighbor, buy out our Neighbor From He!! (NFH) and I'll help you with your wood too.
/ Drying Firewood #23
I curious as to why you would stack bark side down?
I normally stack bark side up so that if it is raining hard and the wind blows the rain under my wood stack, at least the bark can help shed the rain. Is my thinking wrong?
Here's my wood stack. Not all is bark side down (I have helpers when I stack), but a lot of it is.
/ Drying Firewood #24
Probabally meant either rick or rack?? I think both are 1/3 of a cord. Which is "typically" the same as a face cord. A SINGLE stack of wood 4' x 8' (and usually 16" long peices)
And I have had a few "normal" trucks that would BOTH haul a FULL cord:D
I too have always heard bark side down for wood out in the elements.
/ Drying Firewood #25
I forget where I read it many years ago. It was either The Foxfire Book, or one of the Eric Sloane books like, A Reverence For Wood, or Diary Of an Early American Boy. Anyway, what I read was, when stacking under cover, barkside down. When stacking out in the weather, barkside up. I have found that the in-the-weather stacks will be mostly dry after years out there. The bottoms of the ricks get wet, even though I put them off the ground on runners, because the moles push the dirt up against them.
/ Drying Firewood #26
I work for a rather large company that produces Charcoal,firewood,chips,chunks, and fire logs. I believe I can help you with your problem. I am unsure of what temps you can reach with your heating system but I will throw some numbers out. To achieve 25% moisture in 24ton cycles in a 40hr period we input 280 degrees with 70cfs air flow. We usually dry in the neighborhood of 1000T per year and I am sure you can pull back the heat and air flow to accomplish your drying needs. Our wood sizes vary as well coming thru a KordKing but you can usually figure on 40hrs for 24T. If you are drying 5T or less at a time I used a tight insulated structure that makes reaching 140 degree ambient temp easily done with a oil or gas burner with the forced air blowing in thru the bottom of one wall. Now this is the tricky part. You need to make a curtain ran in the same direction as your stacks.Attach it to the ceiling and laying on the wood to force the air flow through the wood an not allowing it to pass over. Also you need to install two baffle gates one on either side of the building high up on the walls. Switching the open/closed sides ever 8 to 10 hrs. This should dry 5T in 72 hrs. For mine that I built I purchased an Amish built portable barn 10x12 and insulated it with fiber board. Used a oil burner from a local garage that had closed down and burned used motor oil which was happily donated by the community. Its EPA approved and efficient. I built a heat channel made of metal duck work to run 15 feet to the inlet of the building. In the summer months I can hit 170. I installed a couple of spark screens that I purchased from the local fireplace store as fire safety. I have noticed it takes us(me,wife ,kids, and any neighborhood kids who show up and are bored enough to help) about the entire cycle time to haul in saw up split and have ready for the dryer 5T for the next cycle. My company uses this exact set up with saw mill slab wood for the production of Charcoal. Works awesome brings 60T of wood down to 10% or less in 50hrs at 375degree. There is of coarse some much bigger heat and air sources but the same concept.:thumbsup:
What a cord of info! You have summed up what TBN has come to stand for, "great info from knowledgeable members"!:thumbsup::thumbsup:
/ Drying Firewood
Thanks that tells me it does not take hears to dry firewood down to below 25 percent. We now have over a hundred firewood sellers in our area. The dry wood from summer went fast do to the home heating. Aim buying cords of green wood for $40.00 dollars for next year and to kiln dry now. If your now a regular customer I have to turn them down. You want green wood it's cheap here in the heart land. A fellow at the truck stop said he payed $450.00 for a semi load 22 tons. Take it back to Kankakee dry it and make 42 ranks and sell for $110.00 sounds high but what do I know about Kankakee. Later gang
/ Drying Firewood #28
Now that is what I call a nice neat pile of firewood!
/ Drying Firewood #29
The method you use to prevent moisture entering the wood also acts as a deterrent for moisture to escape the wood. This is the reason they say to stack wood bark down. Anyway, that is the general consensus of those who measure such things. Do not know if this premise is data driven or old folklore and I haven't done any personal experiments with the oak and maple I burn every year. As capillaries are exposed at the end of the wood and the split surface itself, I would think most wood dries from its ends coupled with capillaries exposed at the split so I am not sure about the wood stacked further down in the pile as opposed to the wood at the top and exposed to the sun and wind. I do know that when I stacked wood 3 deep, the middle row was hardly dry even after 2 years. In this case, I guess it didn't matter a wit if that middle row was stacked bark side up or down.
/ Drying Firewood #30
At our company we have dried 1000's of Rick's of wood. It will not make a huge difference bark up or bark down do to what some of the members have touched on. Wood dries through the capillaries on the end. When wood is split instead of sawed like lumber only the capillaries on the end are opened. If you have ever busted green Hickory you can really see what I mean.Think of it this way water travels through the wood during photosynthesis and water will leave the wood in the same fashion. About 85% of drying will happen like this.There will be some water lose from surface area evaporation but not much and its slow. Keep the Rick's space about 6" apart in your shed and you will dry the wood in about 3 months in summer temps. The key is surface area to allow the internal temps of the wood to rise so we split even the 5" rounds to allow the wood to absorb more ambient heat. Never stack unbusted wood to season or you are defeating your purpose by making the process a lot longer.
/ Drying Firewood #31
In the wet country I live in, this matches my experience.
Also, I'd have to say that the bark side up for uncovered wood seems to work well. This includes wood that comes from rounds large enough that the segments are split the other way and so, have no bark. I stack them so the rings are arching toward the top side, and this seems to work the same as if it had the bark on.
When I stack out in the open, I never do three ricks wide, as the middle one definitely holds moisture. For my two-wide ricks, I prefer to run them north/south so each side gets some sun, when there is some, that is.
One side of my shed has three 12 foot rows of buzz-sawed limb wood and the other has 5 rows of split trunk wood, stacked about seven feet tall. I use it up one row at a time, so if the inner rows in the shed are holding any moisture, by the time one row is used, the next has had plenty of time to catch up on drying.
We had a good hard frost last night (still freezing out now). I find that sub-freezing temperatures are great for pulling moisture from the wood, including those inner rows.
/ Drying Firewood #32
a pickup bed brimming full of wood is usually considered 1/2 cord.so it takes 2 loads to make a full cord of wood.yall wouldnt like me because we burn 20 to 22in wood,not the 16in stuff.
/ Drying Firewood #33
Good Afternoon Lou,
I have to agree 100 % , I also burn mostly oak and maple with some others thrown in occassionally, and have the seen same thing in all my years of burning... :)
Most drying is occuring from the ends, other variables on drying time is crossection of the wood being split and the length..
As one astute poster did mention earlier in the thread, temp and airflow can help aid in quicker drying...
/ Drying Firewood
When we deliver a rank or a Rick a 4 x 8 x 16 inchs we load from the stack to a holder it is 4 x 8 x 16 inchs and dumped in the pickup bed. If you arrive at a customers house and the boys in green with the yellow badges are there you better have a 1/3 of a cord or $2000.00 fine and maybe time. And the type of wood you said you were delivering.
/ Drying Firewood #35
I put a cord and a quarter of green alder in a '60 GMC 3/4 ton once. The springs were way past maxed. Sure glad I didn't have to go far with it.
/ Drying Firewood #36
What happened to my post?
Ah well.
I probably overdo it, but I cut ahead, and when this winter is over I move some into the barn for ~7 month of indoor drying time. It is extra work but the stuff is nearly match-lightable.
We had a lot of red oak die from drought stress this year so I am a bit ahead on firewood. I probably should sell some.
Note that I keep the stacks covered(mostly with old tin) to keep trash and moisture out. There are 6 stacks visible there and one hidden behind the blue tarp and this years wood is in the barn.
/ Drying Firewood #37
There is no standard definitionof a "rick" "rank" "rack" "face cord", etc. since none of them contain the 3 required dimensions to have a known volume. Those are all regional and should have died out a 100 years ago.
Harry K
/ Drying Firewood #38
Unfortunately enforcement of the firewood regulations is way more observed by its absence. Usually only when a customer complains and maybe not even then. I would think it would be simple for an inspector to just read the "firewood for sale" column and start making house calls. Rick, rank, rack, load, face cords would disappear in short order.
Harry K
/ Drying Firewood #39
Up till last year I was delivering 3/4 cord plus loads on a 1/2 ton PU with high quality tires. Catch there is that the wood was very thoroughly seasoned dry Willow. Almost had to tie it down to keep it from floating off. I had a customer that really liked willow and was paying $120/cord.
Yes the pickup had cab high racks and contained 2 ricks crosswise, one in the front and one in the rear as a tailgate -rest loose thrown. It was measured 'in the stack' before loading so I know the 3/4 plus is accurate.
Harry K
/ Drying Firewood #40
I started out this year with some wood that I had split last year, in that note I stack my wood next to the wood furnace and before you know it the stuff will light up with just a torch... It also helps to have the dehumidifier going.... I don't know if my wood would ever reach 20% my dehumidifier reads around 35% this time of the year...
2017 Ram 5500 Bucket Truck (A63118)
2017 Ram 5500...
2011 FREIGHTLINER M2 112 CNG (A59909)
2011 FREIGHTLINER...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
2019 Ford F450 Extra Cab 4x4 Service Crane (A62613)
2019 Ford F450...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63118)
2019 Cadillac XTS...
