horse shelter
/ horse shelter #21
My 2 cents, is to advise against metal sides, metal roof is fine, but sheet metal and horses don't mix well. It might cost a little more in material and maintenance, but I recommend wood siding, like T-111, then paint or stain it.
Even though there may be no rough edges right after your project is done, damage to the metal is likely to occur over time and sooner or later you'll have some sharp edges exposed.
Have to agree with this.
I used 1"x8" rough sawn pine on my horse sheds and 1"x12" Rough Saw Pine on my barn for this very reason.
as an added bonus it was half the cost of the metal too.
/ horse shelter #22
I'm no expert, but I took a quick look at some span tables. If I read it correctly, for a roof rafter with no drywall, and a light snow load, it looks like you'll be fine with your 2x6 rafters on 16" centers on your span of less than 12' ... especially for a horse run in.
As to the 2 x 4 purlins on the roof, the 2x4 are only spaning 16" so that is not the issue, the consideration is the metal roofing, what it can span. I think 2' centers on the purlins will be more than adequate.
Enjoy your building project. It's looking good.
/ horse shelter
here are some additional shots, not quite done yet but almost ready for the horse.
still need to do the following:
* add another 2x10 on the inside of the posts
* front and rear fascia to cover exposed rafters
* gutters
* Vertical 2x8 on walls to keep them from bowing out and seperating
* exterior walls - will be wood instead of metal (going off suggestions here, thx!)
/ horse shelter #25
Nice looking shelter. Its amazing how much the horses like these things. Horses like to chew wood mostly on the edges and corners. I bought some aluminum angle and mounted it on the edges and ends of the interior wood to stop the horses from chewing the wood.
/ horse shelter #27
Good job indeed...
/ horse shelter
i forgot to put that on my todo list but it's at the top - esp since winter is coming they get bored quickly!
/ horse shelter #29
here are some pics of what i have so far, should i be concerned with the 2x10 header (spans 10') or is it strong enough? we don't get much snow here but will get up to 6-8" which will last a couple days. i plan to block underneath the header at the post for some vertical support. it's attached with 5" long 1/2" lags. the joists are 2x6 and are 15' long but the span is just over 11' and they are 16" OC. i plan to add 2x4 purlins (how far apart should these be??) and then 29g metal roofing. then will close the face and back with 2x6 treated fascia.
Very Nice job the only thing I would have done different is put the headers on top of the post !!! Lucky for us here in the PNW it's not that much of an issue usually as like you said we don't get lots of snow!! :thumbsup:
/ horse shelter #30
The only thing that concerns me is that the shelter is open on top. This could allow wind and rain to blow in on the horses. The very thing that the horses are trying to get out of. But from the pictures this shelter appears to be tucked in the woods where wind may not be a problem. Pictures are always great. They explain a lot of things unsaid.
/ horse shelter
thanks for the compliments and suggestions.
i designed this one with more overhang than the others I have built, so far the walls have stayed completely dry and though we've had our share already the sideways rain of Nov/Dec/Jan is yet to hit. i am still considering putting up an exterior wall which would fully enclose 3 sides but then i give up air circulation. it's a tradeoff i guess and the horses are usually blanketed anyway most of the winter so should be fine with 3/4 walls, yah they are spoiled!
i debated the beam on top of the post to further safeguard against downward forces, hopefully i won't regret it. though compared to the other shelters i have which are 4+ years old i should be ok. if winter brings too much heavy snow in one blast i have a nice roof rake i can put to use.
i ended up getting some wall caps boy those are expensive, $17 for an 8' stick which, they are heavy duty though and should prove their worth. i am looking locally for a steel mill which will take flat galvanized 20/22g stock and roll it for me but will see.
/ horse shelter #32
HI,
I am a bit late but if i may and pardon my english i'm from "over the atlantic" :
I've built 2 horse shelters over the years and i've been repairing them and making them sturdier each time. The lesson : horses tend to destroy everything
in the end ! At least, my wife's ones !!!
So i would have gone on something sturdier. But now it's done.
First thing, i can see on one of the picture that you nailed the boards on the outside for the back of the shelter, i would nail everything on the inside side of the poles cos they tend to scratch their asses on the walls ! 500 kg or so pushing on the boards and i won't last long.
Nice job though, looks really neat
/ horse shelter #33
Cayenne pepper sprinkled liberally on your edges will keep the horses from chewing....
MK160
/ horse shelter #34
Do you get much snow? Here is Maine during a windy snow storm the horses could easily be standing in 1-2 feet of snow by the morning. Pain to shovel out- especially with manure mixed in. How about a drop down canvas tarp where you want it, pulled up when you don't? Even with the walls closed in, the open rafters provide a lot of ventilation. Diagonal or plywood bracing might be a good idea as well.
/ horse shelter
well so far this winter it's been extremely dry but usually precip is in the form of rain rather then snow.. so far so good, no chewing, rubbing, or otherwise ill results from the horses occupying. i have yet to add the second beam across the front and back but am taking some time off over Christmas and have added this to the list. one of the last projects was to build some slow grazer boxes which mimicks a horse grazing on the pasture and slows the consumption of hay so keeps them busy and their bellys basically working to digest their feed over several hours. if interested, i can post some pics of these things, they are super easy to build and so far have been working well..
/ horse shelter
HI,
they are actually screwed in but yes they are attached from the outside, the advantage i have here is that the horse spends most of it's time inside the shelter eating otherwise it's on the fence end sticking close to the othe horses which are across the "aisle way".. so far i have not witnessed any pusing or rubbing but i'm sure it will happen, most of our stock is pretty well mannered but they do get bored in winter and tend to spend long days finding ways to expend their energy which usually results in chewing.. time will tell, so far no battle wounds
/ horse shelter #38
i'll keep this in mind, but would likely have to apply when my wife is not around. :)
I read somewhere that chewing was a lack of some mineral- not sure what. Re chewing- we used to coat the wood with creosote. Always kept some handy.
/ horse shelter #39
Hi everyone,
Yes they tend to chew a lot during the winter, i will ask my wife she's the expert, but anyway i will try the pepper trick. I did put some old car oil on the poles in the shed mainly to do like the guys did in ancient times for weather protection and apparently it keeps the horses off from chewing also ! As for creosote, it's totally forbidden now here because of the catastrophic pollution it creates.
cheers
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2016 Bomag BW90 AD-5 Tandem Vibratory Smooth Drum Roller (A66734)
2016 Bomag BW90...
Unused 2021 MK Martin Axis 5-6 Hydraulic Took Arm Tractor Attachment (A66734)
Unused 2021 MK...
2014 Chevrolet Impala Limited Sedan (A66738)
2014 Chevrolet...
Unused 2024 Schulte 5026 26ft. Batwing Hydraulic Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2024...
2000 FREIGHTLINER FLD120 (A67714)
2000 FREIGHTLINER...
