Traction wheel weights or fill the tires?
/ wheel weights or fill the tires? #1
Elklakedoug
Member
John Deere 2320
Sounds like filling tires is the way to go - beet juice? I live in Michigan - move dirt & rocks with my 200cx loader, but also plow snow, etc. -
input?
thanks, Doug
/ wheel weights or fill the tires? #2
I had mine filled with Rimguard (Beet juice). Seems to be more stable than a comparable size tractor we have at work that has wheel weights. Also, the weights stick out which I don't like when manuvering through the woods.
I live in an environmentally sensitive area, so beet juice was really the only way to go for me. Also, it has a high weight per gallon. I had it installed for $2.50 per gallon back in August.
Mike
/ wheel weights or fill the tires? #3
I have weights on mine. I considered filling the tires but if I need to take the wheel off...which I did to replace an axle seal, the tire/wheel's a lot easier to handle after the weights are removed.
/ wheel weights or fill the tires? #4
I went with the weights . They worked out fine for my uses .
/ wheel weights or fill the tires? #5
I've busted too many knuckles on wheel weights. I went with RimGuard on my last tractor.
//greg//
/ wheel weights or fill the tires? #6
I have seen a couple of post on weights vs filling, but have not seen much info on the benefits of filling vs weights. A couple of questions:
Does filling lower the center of gravity of the tractor by applying the weight lower in the tires vice hanging weights at axle height?
Does filling reduce the weight applied to the rims by not hanging on the axles? I would think filling would apply pressure directly to the ground without applying extra stress to the axle/rims.
/ wheel weights or fill the tires? #7
Filling is usually cheaper per pound added. That tips the scales for a lot of people. Weight's usually around $1/lb; Rimguard is closer to $0.25/lb. Labor will add to the cost for both unless you DIY; more labor is required to fill tires than add weights.
Filling will also put slightly less stress on the tire itself, but I haven't ever heard of anyone having any trouble because of that. The weight of your tractor on your wheel bearings will be the same with weights or filled tires.
/ wheel weights or fill the tires? #8
Obvious pros and cons to both as mentioned earlier, but one advantage that was not mentioned is that with Rim Guard or other fluid you don't have the weight bearing on the axle itself, instead it is on the ground. This also makes for some uneasy moments when lifting heavy objects with the FEL With filled tires the back end will raise slightly until the weight is taken off the ground and transfered to the axle of the tractor. With wheel weights you don't have that since the weight is always bearing on the tractor.
/ wheel weights or fill the tires? #9
True, but the weight's on the *axle*, not the wheel bearing. I haven't ever heard anyone even suggest that this could casue a failure, let alone heard of an actual incident. People have been adding weight to wheels for years.
This effect is so small that if you notice this, then you don't have enough rear ballast to be safe for the load you're lifting. Add a counterweight.
/ wheel weights or fill the tires? #10
... makes for some uneasy moments when lifting heavy objects with the FEL With filled tires the back end will raise slightly until the weight is taken off the ground and transfered to the axle of the tractor. With wheel weights you don't have that since the weight is always bearing on the tractor.
You've got the wrong concept. Tire ballast (liquid or solid) is intended to improve traction and increase transverse stability. Think lateral. Weight to counter front loads should be behind the rear axle. Think longitudinal
//greg//
/ wheel weights or fill the tires? #11
sorry bad choice of words on my part.
Bearing as in: The force of the weight is acting on something in a particular direction, not refering to the actual wheel bearing (adj vs noun)
Yes I do use counter weight in addition to loaded tires, but that doesnt' change the laws of physics.
I'm not advocating one or the other. In my case I probably would have put steel weights on if the cost would have been less. Everybodys situation is diffent and there are advantages to both.
/ wheel weights or fill the tires? #12
//greg//
I think we are saying the same thing. All I am say is that no matter what/or were you put the weight on the back of the tractor when you lift a load with the FEL you will take ground pressure off the backtires proportional to where your center of gravity in the longitudinal axis. With the fluid in the tires the fluid weight does not become effective until the squat is taken out of the tires and the fluid wieght transfered to the rear axle.
Keep in mind that once your rear wheels do raise off the ground you have just moved your center of gravity over the front axle and all that weight you put in/on/behind the tractor is (bearing) directly on the front axle as it is now a fulcrum.
/ wheel weights or fill the tires? #13
I can still remember my wife driving past me with my old Ford 1710 with the (full) bucket sorta high and the hub of the right rear wheel at my chest height. I yelled and she saved it, but I know my heart stopped for a time...
The nice thing about loaded tires is that the weight is always there. For most chores using the loader, the beet juice gives me enough anchorage to avoid lifting a wheel. But when I'm moving stone or anything that might be a challenge, I add a box blade with weights.
When I do have to remove a loaded wheel and move it, I'll call a neighbor!
/ wheel weights or fill the tires? #14
Sure, but as I said - if you can notice your wheels "unsquatting," you need more rear ballast. (And possibly more air in the rears.)
If you notice your rear wheels raising off the ground, you REALLY need more rear ballast!
Anyway, the OP was specifically asking about traction. Steel's 2-4x more expensive than beet juice but doesn't leak and can be taken off when lighter ground pressure is desired. That about covers it.
/ wheel weights or fill the tires? #15
Each has pro's and con's. In most compact tractors, the big advantage of fluid is that one can get more weight on the wheel. With JD tractors, the wheel weights are very expensive from the company and do not add all that much weight relative to the ballast that can be achieved with fluid. The drawback to fluid is that one is stuck with it all the time. My little 2320 has loaded rear tires and though great for loader work, snow removal, etc., the machine can compress delicate grass/lawn and the fluid cannot be taken on and off. In this case I would have probably been better choosing weights. Smaller tractors, like sub-compacts, have the opposite problem. The rim size, relative to the tire volume, generally means much more weight can be added to the wheel than to the tire. For example, on a JD 1026 with 26x12x12 tires (which are pretty small), the machine can hold about 50 pounds of ballast per tire but can be spec'd with up to 172 pounds of cast iron ballast as wheel weights per wheel (72 pound starter and two 50 pound add-on's). The opposite almost always holds true on larger tractors, except with R1 style tires. As for center of gravity (COG) there is little difference. Most places that ballast try to fill the tires as fully as they can to achieve maximum weight. This means that even with some air in the casing the tire is pretty full of fluid, usually passing the centerline of the axle easily. Wheel weight v fluid both add stress to the axle. Most companies consider this when designing their machines because they know most folks are going to need to ballast. Also, the axle stress from this is much less likely to be harmful than having excess slippage and the stresses associated with that. There also is the consideration that in most compact applications the amount of on-wheel ballast recommended by the manufacturers exceeds what can be specified with EITHER liquid or cast iron weight, so one could argue many of us need to be running both to meet factory recommendations. All this said, my general advice has been: for small sub-compacts or compacts less than 25 HP with smaller tires/wheels one can almost always add more ballast with cast iron than fluid. For all other compacts, the opposite is more likely true (but I realize not always). Unless one has a specific need to remove the weight (finish mowing a delicate lawn, large time periods of non load-bearing tasks on pavement or concrete), or in an instance where an attachment offers significant ballast (compact with a back hoe for example), I recommend liquid ballast. In those other unique applications, one would probably want to consider removable ballast unless it is cost prohibitive. I like Rimguard. From an environmental standpoint it makes sense, but from a practical standpoint it does as well as it is very heavy and has a high solute.
John M.
/ wheel weights or fill the tires? #16
John M. very nice writing! The only thing that I don't quite understand (wouldn't be the first time) is when you mention the stress on the axle when adding weights to the wheel in the form of wheel weights or liquid. I can see adding stress on the axle by adding a ballast box. For example, if I was to remove the axle with the wheel and tire still attach to it, and would hold one end of the axle and have someone adding the weight to the wheel, it would not put any more stress to the axle in my opinion. I would still only have the weight of the axle and it would be the same at the other end where the wheel is bolted to the axle, but if I was to ask him to add weight to the axle itself which in this case would be comparable to the tractor weight plus ballast box, now we are adding stress to the axle. Yes, yes, I know, I would've drop the hole thing a long time ago,:laughing: So my point is, if you add weight to the wheel, the only stress is on the rim and tire or am I missing something here. :)
/ wheel weights or fill the tires? #17
All the talk about "stress on the rear axle" is misleading. First, adding weight by hook or crook to the rear tires/wheels doesn't increase axle stress when the tractor's on level ground. Second, the rear axle is built to take the additional stress you'll get from sidehilling with loaded tires or weighted wheels *and* rear ballast.
What's *not* built to take the stress is the front axle. If you are ever lifting your rears off the ground, or lifting so much that your rears "unsquat," you're overloading your *front* axle. Keep doing this and you'll break it or at the very least need new bearings sooner than expected. Both of these, of course, assume that you live long enough to break the axle and don't kill yourself with a rollover.
I've never heard of a rear axle breaking because someone added weight, loaded the tires, or even did both. It's just not a problem worth worrying about.
/ wheel weights or fill the tires? #18
Agree 100%! This is the first thing the service manager told me when he saw that I wasn't using my ballast box with my snowblower. I told him that I did not need it for traction and he said that it was not only for traction but for eliminating excessive stress to the front axle due to the extra weight of the blower.
/ wheel weights or fill the tires? #19
I loaded my rears with anti freeze and windshield washer fluid.
(22 gallon each) That is the best products available for me to use here and now. I'm sure there are other products available that are better options for others.
I have an older JD855 with 33" turfs and 2 link ladder chains.
Made a BIG difference. Wish I had done it earlier.
Good luck
/ wheel weights or fill the tires? #20
Elk Lake Doug - from another Doug in Michigan - I have rim guard in my rear tires and love it. I also throw on the box blade for extra weight for heavy loader work or snow removal with my FEL plow (like the 9" we got dumped on us yesterday). :thumbsup:
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
2025 JMR 66in Hydraulic Single Cylinder Brush Grapple Skid Steer Attachment (A59228)
2025 JMR 66in...
