new Bx 2360 owner
/ new Bx 2360 owner #1
bx2670
Pilot Mountain N.c.
2013 Bx 2670
Hello everyone will be getting new bx2360 in about a week how should I break in and what should I expect or look for as a new owner? From what I have learned so far from you all I know I won't be led wrong!!!!!!!!!
/ new Bx 2360 owner #2
Welcome to TBN. I purchased a BX2360 this past spring and now have around 100 hrs on it. I broke mine in by generally using the machine but keeping away from extremes. Varied engine rpm and did not exceed around 2600 for the first 50 hrs. At 50hrs I changed over to Rotella T6 15-40 synthetic and changed all filters. I also changed the HST over to SUDT2. I'm sure you'll get many opinions though. Best luck with your new toy.
/ new Bx 2360 owner #3
:welcome:
I haven't had a new tractor before, so I'm not all that familiar, but know several threads here have talked about checking your front axle fluid many times in the first few months. They come very low.
Enjoy that new :tractor:
BTW, you don't have a tractor until you post pictures. :laughing:
/ new Bx 2360 owner #4
The manual will tell you what to do--generally don't max it out for the first 50 hours. But whatever you do, don't lug it. Those diesels are designed to be run pretty hard. I would limit it to 2500 rpm or so for the first 50 hours, and don't drive at full speed either.
Have fun, be safe, and send pictures.
/ new Bx 2360 owner #5
Check the level of gear lube in your front axle. Its very common for it to get low after just a few hours of use. Mine was low when I first checked it. To check it, there is a orange colored dip stick on the left front axle, and it can be hard to get out of its hole.
/ new Bx 2360 owner #6
I checked all fluid levels, grease fittings, bolts, belts etc. worked my way through the Manual. Also sprayed a clear dry film on bolts and weld joints ... its only gonna be this clean once! Will break it in like the others have said and change all filters and oil at 50hrs.
/ new Bx 2360 owner #7
Can't go wrong with the advice so far. I did pretty much what others have said only I ran ours a bit higher, but with cool down cycles.
You don't need to baby it, just follow the manual and do regular fluid checks, clean your screens etc.
How is it equipped, FEL, tires etc.?
Enjoy your new tractor.
/ new Bx 2360 owner
Thanks for valuable info !!Ordered with turf tires 54 mmm and loader valve, really to mow lawn 2 1/2 acres pretty much flat.Hopefully down the road FEL and other toys to put behind it.Been mowing with Cub Cadet 42" 19 HP gas and tired of it taking 3 hrs or more plus now I will be the Big Boy in the hood !!!I know its probably overkill was torn between it and the 1860 but you can't add HP later plus 0% was a no brainer.Got it for $12000.00 before taxes so I hope that is'nt too bad.First price was $12800.00 got a quote from GA and he matched after I showed it to him I'm in Nc
/ new Bx 2360 owner #10
Can I ask why you purchased the 54" deck versus the 60"? When I purchased mine this past spring the dealer pushed the 54" deck so I agreed. However, TBN users convinced me the 60" was a better choice. I called my dealer back and switched my order to the 60" deck and I am glad I did. It was a $180 increase in cost so not a big deal.
/ new Bx 2360 owner
Main reason is my shed door is 60" and I hope I can fit it through holding up the rubber guard (anyone know for sure ?) but also didn't like how the 60" stuck out so far. I only drink and drive in the yard and would catch you know what from you know who if I hung the deck on some of her trees or bushes:) also picking up extra foot of cut so don't want to cut down on my drinkin time!!:D:D
/ new Bx 2360 owner #12
We have much in common....I got the 54" because I didn't like the extra overhang of the 60"...That's not overkill for 2.5 acres..Actually it's perfect.
I do like to put a hurting on a Coors Light or 4 when cutting in the summer too..:drink:
/ new Bx 2360 owner
Thats my brand also do you know if it will fit through a 60 " opening also where is the cruise control knob located on tractor have book on them (pic) but can't place where knob is on tractor?
/ new Bx 2360 owner #14
I really don't know the overall width of the 54". I keep mine in a garage, so I never had to worry about it....Mine appears to be around 68" with the shute down and around 58" or so with it up...I think the design of yours is slightly different.
My BX23 doesn't have cruise, so I can't really say...Don't see a close-up on the Kubota web site..
/ new Bx 2360 owner
Anyone else care to chime in ? Only 1 week till I get it!!!!!!
/ new Bx 2360 owner #16
All I can say is I remember the anticipation when I ordered mine this past spring. What a relief when the call came to schedule delivery. You are going to be very satisfied. Post those pictures as soon as you can.
/ new Bx 2360 owner #17
New here too. Have about 70 hrs on my BX 2360. Probably the best investment I have made. It has been a workhorse on my 10 acre property. Did the 50 HR service myself. Front axel oil was very low, but I would have known to check that had I found this site sooner. I too have learned quite a lot just browsing the posts here. Have fun.
/ new Bx 2360 owner #18
Based on the mesurements I gave, looks like you should just make a 60" door...No gurantees though...I'd get the tractor and make the door wider if need be, once you have it in your posession you'll see why.
You may even end up building it it's own garage...Mine lives in a climate controlled garage and it's quite happy.:D
/ new Bx 2360 owner
Will post pics as soon as son comes home from App State (Boone NC) he is the guru on that. I have the book on BX tractors from dealer but can't place cruise control on tractor from pic in book says it is standard on 2360 also is newer (2011) deck any different than one a couple of years older ?54" mmm is what I,m getting Ya'll know the first thing I'm gonna do is wax it:D:D
/ new Bx 2360 owner #20
The cruise control is located on the console adjacent to the throttle lever. You select the speed you want with the treadle then lift the cruise control knob and release the treadle and it maintains your speed. Low tech but mine seems to work well.
2017 Frontier FM1015R Flex Wing Finish Mower (A63116)
2017 Frontier...
John Deere 335 Round Baler (A64047)
John Deere 335...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
ATS T460 Mini Skid Steer (A64047)
ATS T460 Mini Skid...
2016 EZ Trail Seed Tender (A64047)
2016 EZ Trail Seed...
2013 John Deere 2623VT Vertical Tillage Tool (A63116)
2013 John Deere...
