8Ft blade on MX5100?
/ 8Ft blade on MX5100? #1
OrangeToys
SW Missouri
2016 Kubota M7060HDC
Im trying to decide if I buy an 8ft blade for the 3pt is gonna be to big if I ever need to rotate the blade 180 Degrees (from pulling with it to pushing with it).
Or is the 7ft the better fit?
/ 8Ft blade on MX5100? #2
The ability to turn the blade 180˚ might be an issue if the boom on the blade is too short and the blade could hit the wheels. If the blade offsets that might give you the room to do it. What size blade you can handle depends on what you are planning to do with it. If just light grading and snow, etc. an 8' might work OK. 7' would be my choice. I had an 8' on a 63 HP tractor and that was plenty of blade and sometimes too much in our hard ground. I now have a 10' on a 108 HP 2WD and its plenty of blade when trying to take a good cut. The important thing is having the blade cover your tire track when angled.
Kim
/ 8Ft blade on MX5100? #3
I think an 8' blade will be WAY too much for that tractor for anything but the lightest work. We have a pretty heavy 8' Deere blade that we use on an M9540 and it is plenty for even that tractor. I'd say go for a medium duty 7' unit. Also, most (good) blades are designed so the frame is long enough so you can rotate the blade 180* on any tractor.
/ 8Ft blade on MX5100? #4
Just my :2cents:. But I feel that a good medium duty 96" blade would work great with your tractor. If you can get one that is in the 600-800lb range you would be pretty happy with it I think. As was already mentioned, any good blade is going to have a boom long enough to be able to pivot 360 degrees. I have a 108" blade and it pivots 360 and I believe that even their 10 footer does also. Take a look at these models of Land Pride just to get an idea of what you should be looking for.
Land Pride RB35 Series Rear Blades This blade is close to doing a 360, would need to double check with Land Pride to verify.
Land Pride RBT35 Series Rear Blades This blade would be the one to get if you can swing it. Very good blade.
Other manufacturers have similar blades, this were listed to give you an idea.
Remember, when it comes to new implements, you usually get what you pay for. ;)
My dealer call me friday saying he had the 8ft for $750 (thats all i know for now)
i can get a woodsRBH84 for about $1,200+tax
Then i call the landpride dealer about the same size blade and he wants $1500
Then i found a king kutter in 7ft for $380 I know nothing about this brand
Any input?
/ 8Ft blade on MX5100? #6
Go by the weight, not just the width. Heck, I think that Land Pride has 4 or 5 different 7' wide models. You will be best off with something that weighs 600-800lbs if you are really going to use the thing vs just moving around light weight or loose material.
Look at the specs before you buy!
/ 8Ft blade on MX5100? #7
personally i would go with the 7ft blade.as its more than big enough todo what you want.an you can work with it easier.an you can turn the blade pretty easy.if you had a loader you could pick the blade up an turn it backwards if you want to.
/ 8Ft blade on MX5100? #8
I have a seven ft.Bush-Hog medium duty(rear) blade for My L4240.Used mostly for snow removal,but also do some grading with it.I wouldn't advise you do much "pushing" with a rear blade(tough on the three point).
As advised by others;go by the specs,weight means a lot with a rear blade.
I had one of those lite duty(6ft.) rear blades,kept breaking it.
The seven ft.blade I have now can be rotated all the way,angled and tilted.
/ 8Ft blade on MX5100? #9
Blades are rated to match horsepower. I would be very careful to buy a blade heavy duty enough for your tractor. If you bend it, it is worthless. I like the Landpride that was mentioned. Wish I had one! You also may want to consider adding hydraulics to control the tilt and angle. It adds more costs, but will vastly improve the function if you are expecting grading that requires finesse. Please let us know what you decide and how it works.
Anyone heard of Bison blades?
/ 8Ft blade on MX5100? #11
Bison blades are very good blades, at least the heavy duty ones are that I know of. ;)
I know that some of the John Deere-Frontier blades are made by Bison.
I looked at them extensively before I bought my Land Pride. Main reason that I went LP was I didn't want to wait for 6 months to get the blade that I wanted. If your dealer or your dealers distributor has the blade in stock that you are interested in, then for sure consider a Bison blade. :thumbsup: :thumbsup:
As was mentioned, if there is any way that you can swing the hydraulics, even just the angle hydraulic, it will make your life waaaaaaaaay easier. Might want to consider a tilt hydraulic also. If you have other grading implements, a tilt cylinder of a top and tilt set on your 3pt would be the way to go.
One other item that I have found to help out quite a bit is to have skid shoes on the blade. They really help out with only allowing the blade to cut X amount or even to hold it up off the ground for snow removal. Of course all this stuff costs lots of $$$$. So I would guess that you will be looking somewhere between $1200-$4000, all depends on how far you want to go.
Your tractor weighs about 5k pounds with the loader and without any ballast, do you have it ballasted with filled tires or wheel weights? The added weight will get the tractor to perform better for grading. Do you have any remotes and if you do how many?
A dealer in town has a bison for $900 and the tractor dealer has a woods for $1200. Almost identical blades...bison weighs 200lbs more
/ 8Ft blade on MX5100? #15
King Kutter blades are junk in my opinion. Used a 7 footer on my 8N for 2 years, then bent the mounting bracket. Got a Land Pride 7', it was nice. Moved it to my L3940 and added hydraulic angle myself. Philip.
/ 8Ft blade on MX5100? #16
PHILIP Its KING KRUTTER get it right ! :D
I agree unless there The Pro Series there are junk.IMHO also.
Like others have mentioned Bison makes good stuff. :thumbsup:
Iowa Farm Equipment -- Bison Tractor Rear Blades
Boone
/ 8Ft blade on MX5100? #17
Price is right that's for sure, and at 677lbs & rated for 65hp it will work good for you. :thumbsup: As you noted same blade, but one is 200lbs more, which makes them not the same quality of blade. You probably have to jump up another grade quality with the Woods to get up to the same weight class. Big weight differences of the same size units will almost always tell you which one is the better product.
I still feel that an 8 footer would be good, but a 7 footer will work out fine for you and the Bison is a good product for a great price.
Let us know what you decide to do.
/ 8Ft blade on MX5100? #18
I have a MX 5000 and have a QA 7.5 blade mounted on the front. When angled it just covers the wheel spacing. Our machines have plenty of power to handle an 8' blade, so don't worry. You will need loaded tires or chains. If you have a loader i suggest you go with a QA front blade, so much easier going forward especially on long stretches.
/ 8Ft blade on MX5100? #19
I think that the OP is going to use this for grading, not so much for snow.
KUBOTA M108S TRACTOR (A64280)
KUBOTA M108S...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A64280)
UNUSED SDLANCH...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
Caterpillar E200B/EL200B Excavator Service and Parts Manuals (A63117)
Caterpillar...
