Bleed Hydraulics???
/ Bleed Hydraulics??? #1
AGGIE00
Gold Member
I broke a hydraulic line and lost most of the fluid. After the repair and oil replacement the loader cycles very slow. Never had a problem before or thought it needed to be done, but if so, how?
/ Bleed Hydraulics??? #2
I just changed the fluid in my MF . Manual on it shows bleeder plug to loosen while running , let air bubbles out , shut tractor off , tighten plug . I don't know if your procedure is the same or not .
/ Bleed Hydraulics??? #3
Chances are you have air in your system. Have you cycle your boom and bucket cylinders in and out to their max. If not lift your boom to its maximum height and hold the lever in the lift position for a few second until you heard the engine taking the load, then do the same in the down position, this will probably raise your front end. You will have to do the same with the bucket.
/ Bleed Hydraulics??? #4
It :thumbsup:is posible you damaged the pump if you ran the hydraulics out of oil.
And this is the process for purging air out of the system?
/ Bleed Hydraulics??? #6
This is how we use to do it with are heavy equipment. I still do it every time I hook-up my fel, to purge any air that could have infiltrate the system during installation or removal.
John Deere 4960 Tractor (A64047)
John Deere 4960...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
Tufline Box Blade (A64047)
Tufline Box Blade...
PORTER CABLE AIR COMPRESSOR (A63569)
PORTER CABLE AIR...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
