What would you look for in your next tractor?
   / What would you look for in your next tractor?
Ok i just thought of a couple more. A replacable cutting edge on the bucket loader. Mine is all worn down & now it's going to be a big pain to try to replace it. As someone else mentioned a speedometer would be nice.
   / What would you look for in your next tractor? #12
For me it is :
Quick detach loader (mine is a bear to get on and off)
operator station access from the left and right
Larger fuel tank
More traction (weight)
More loader lift capacity
Hydrostat drive, I'm doing a lot of tight loader work
More power (50HP should do it)
Bigger operator station (leg room)
tlescoic 3 pt lower arms
I like a cab but I get on and off to often...seems like it would be a pain..
thats my list..
   / What would you look for in your next tractor? #13
I'd like a personal assistant to do the maintenance on my tractor. Specifically, a female; about 5' 2", eyes of blue, could she could she could she coo. Has any body seen my gal?
I forgot quick attach loader bucket set up
   / What would you look for in your next tractor? #17
Top n tilt (TNT) is when you replace the factory top link and side link on the 3 point hitch with hydraulic cylinders so you can make adjustments to your attachments while on the fly.
I my pictures the tilt cylinder hoses are disconnected right now. I'm using those ports for my snowplow angle. I need to add another set of remotes for next year.
   / What would you look for in your next tractor? #18
I like my 2615. It is a simple design without a lot of electronics. I do wish it had R1 tires and TNT. It has done all I have asked.
   / What would you look for in your next tractor? #19
I have already made changes to my 2615 that I would have liked to see from the factory.
1) Reinforced top edge of bucket and added grab hooks.
2) Added a cab with heater.
3) Added a lower hose heater.
4) Installed a suspension seat.
5) Added extra lighting front and rear. Plus a flashing strobe.
6) Increased bucket lift capacity by a few hundred pounds.
7) Installed a larger tool box.
I am happy with the way my tractor has performed. It has done everything I ask of it. If I bought another tractor it would have all of these items plus a front quick attach setup and more horsepower.
   / What would you look for in your next tractor? #20
George, please elaborate on how you increased bucket lift capacity so much.
2007 MACK CV713 ELITE DUMP TRUCK (A60430)
2007 MACK CV713...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
Bobcat T590 (A53317)
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
