Will this work
/ Will this work #1
travisc454
This my bender
the ram is 10 ton 14" stroke. it uses this pump
its 1 1/2hp........0.57 gpm@ 4000psi
could i use it to operate this ram?
Couldn't find any specs on it but it is also 10 ton probably only a 2" stroke. I read somewhere that it is rated at 15 tons @ 10000 psi but couldn't confirm if the info was correct. it is used in my shop to punch holes and press dimples into sheet metal. I know i would have to get the same quick connector. I have seen people run them with air/hydraulic. Would this be dangerously fast? Is this enough info for an answer. Thanks in advance i don't like being the guy that just pops onto a forum for a question but i couldn't find an answer anywhere and this is way over my head.
/ Will this work #2
I think it would move very quick unless you somehow reduced the flow.
Maybe use a needle valve to adjust the speed.
/ Will this work #3
Whatever it is I want one. Definitely didn't come from Harbor Freight.
Joe H
/ Will this work
Can i do that without hurting my pump? I cant afford to damage my bender pump.
Joe H
You can get one from HF. but the punches are not as good. I think the hand pump and ram are the same (same factory in china just painted a different color like many things now days) the set from HF is $99 minus 20% if you have a coupon. greenlee is about a thousand. I got the Ram from HF and bought good punches from greenlee and dimple dies to match from Barbed wire offroad.
/ Will this work
Your ram looks to be single-acting. Your pump, with a Cetop D03 mounted on top, looks to be double-acting.
Sure you can use it, but you'll have to find a way to retract the cylinder.
HydraulicStore has some double-acting high pressure rams. I ordered my high-force maintenance kit from them.
The ram has a spring that brings it back not sure if that is double. my bender just holds and if i press down it retracts i think with the a spring on the inside because it retracts slow.
/ Will this work #7
Yep, that elec/hyd pump will work on the Greenlee ram.....they are both single acting
The yellow ram is an Enerpac RC-1014 (or equivalent clone)...http://www.buffalohydraulic.com/enerpac/html/enerpac_rc_series_cylinders.html.. develops 10 tons when pressurized at 10,000psi(max rating)........your pump on your bender is rated at 4000psi which will only give you 4 tons at that pressure...
the Greenlee 767a Hand pump (http://www.mygreenlee.com/GreenleeDotCom/im/IM1317REV07.pdf) is rated at 6500psi .......so the greenlee ram can handle the 4000psi easily from your power unit on the bender......
/ Will this work
The yellow ram is an Enerpac RC-1014 (or equivalent clone)...enerpac RC series single-acting hydraulic cylinders.. develops 10 tons when pressurized at 10,000psi(max rating)........your pump on your bender is rated at 4000psi which will only give you 4 tons at that pressure...
Thanks for the info. would this mean that my pump will be under powered? I found the coupler fitting. I will order them monday when i get them i can post up a video of it in action.
/ Will this work #9
Yes, it will be underpowered but it won't blow up in your face....
Even the bender obviously doesn't need the full 10 tons of power, with 4000 psi it'll only push 4 tons....
New/Unused Quick Attach Auger with Three Bits (A61166)
New/Unused Quick...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
1998 Ford F-150 Ext. Cab Pickup Truck (A61568)
1998 Ford F-150...
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
