used front end loader for jd 2240
/ used front end loader for jd 2240 #1
mhtmtree
Dover Plains, NY
jd2240 jd4200 jd310b jd450c ASV 4810
looking for a loader for my 2240. Any ideas on where to look and approx. cost
/ used front end loader for jd 2240 #2
Where are you located? I'd guess $2500-$4000 depending on the loader.
JD loader models that will fit are 145,175,48 & 245.
Thanks for the reply. I am located in Dover Plains NY. I have a tlb and skidsteers but wanted to get more use out of this machine.
/ used front end loader for jd 2240 #4
How about the 146, too?
AKfish
/ used front end loader for jd 2240 #5
My vote is the JD 175. Try tractorhouse or machinefinders
/ used front end loader for jd 2240 #6
My neighbor's got a 245SL on his 2640. Now, that's a LOADER! :D
AKfish
/ used front end loader for jd 2240 #8
I have one on my JD 2030, might be a little too big for a 2240
It is a pretty big loader... he put on some real big front tires and rims to handle the added weight!
Not sure of the difference in tractor size/frame size between the 40 series, either.
Come to think of it, though - he was using a 2240 (50hp) on a JD 336 baler and using his 2640 to work a big round baler - in the same hay field.
The 2640 was definitely a bigger machine.
AKfish
/ used front end loader for jd 2240 #9
Basically the frame sizes are the same. Of the 2 tractors you mentioned the 2240 is just shorter wheelbase because it has a 3 cyl engine vs a 4 cyl engine in the 2640
/ used front end loader for jd 2240 #10
I would go with the lightest loader with the shortest frame. meaning the load is carrier closer to the tractor. you might have trouble reversing or spin a bit with a big loader on your tractor. Not to turn you from green paint but westendorf has some very good loaders probably a bit heavy for that tractor. Bushhog something like a 2425 or 2426 is a decent low end loader, fairly cheap to buy 1500-2000 or so and can bolt to the side rails and front end.
/ used front end loader for jd 2240 #11
rdbigfarmboy
You brought up a good point about side rails. Not all JD utility tractors came from the factory with side rails. Side rails need to be installed if not already installed before adding a loader.
/ used front end loader for jd 2240 #12
With the 2030 and 245 loader, I have the optional HD front axle, and 11-15 front tires. Even with loaded rear tires and 4 110lb wheel weights I have to put on rear implement for real heavy loads. I have lifted logs so heavy the grapple would not curl back.
If he does not have the HD front axle, I would not recommend a 245 loader. A great loader, but too big for that tractor.
/ used front end loader for jd 2240 #13
If your 2240 has a straight front axle, you can go heavier on the loader. However, most were not straight axle, also the 520 loader will fit as well.
John Deere 7000 3-Pt 2-Row Planter (A66285)
John Deere 7000...
(10) New CATERPILLAR Keys (A65579)
(10) New...
2000 SHOP TANDEM AXLE TRANSPORT TRAILER (A65643)
2000 SHOP TANDEM...
Stidham 2 Horse Trailer (A65640)
Stidham 2 Horse...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
