have to bleed to start
/ have to bleed to start #1
tpcowfish
John deere 2210
Just wondered if anyone knows why, after my JD 2200 sits a while,(overnite), I have to bleed at pump to get it to start, after started and warmed up , runs fine, and restarts easy, any Idea's, thought maybe fuel cap, but like i satated, i can run it all day, shut it off, start back up, but once it sits for a long while, just turns over , and has some smoke, Thanks, Tim
/ have to bleed to start #2
Might be the fuel line leaking from the tank to the pump, i had a problem with a larger JD doing the same thing and that was the cause. JD fuel lines have been noted for that prob
/ have to bleed to start #3
I agree. Check fuel lines first. What model is it? 2210 possibly? Or is it a 4200 or 5200? Never heard of 2200.
Yes ,its a small 2210, and tnx, i just cant find a leak
/ have to bleed to start #5
Sounds like fuel system is getting air. Sometimes air will leak in very small cracks where fuel does not. Try tightening all fuel line connections and make sure the filter is tight and the bowl is not cracked.
/ have to bleed to start #6
Mine was a fabric coated line and i couldn't find any leaks either, but it did feel wet when you felt of it. I replaced it (pretty cheap even at a dealer) and it fixed my problem.
Replaced all lines, except the vent line that goes under dash, still having same issue, but tnx for the replys
/ have to bleed to start #8
Have you tried turning fuel off at the filter housing when you're going to stop engine for an extended period? Are you sure the large nut is tight on the filter housing that holds the bowl on?? Have you considered installing a check valve to keep fuel from returning to tank via the supply line?
Have never turned off fuel ,unless changing filter,I think the bowl is tight, thought about maybe o-ring is bad on bowl, Never had this problem before, so i wouldnt think i need a check valve, but will try the shut off valve
Update, Talked to dealer, they think it's ignition switch, Glow plugs are wired directly thru switch, on a check, plugs werent being activated while turning key, but worked if wired with a jumper, and started, Tnx everyone
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
4021 (A59228)
4021 (A59228)
40ft Shipping Container (A64194)
40ft Shipping...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
