2305 Trans issues
/ 2305 Trans issues #1
JED2305
JD 2305
I was using the tractor and got off while running (put in neutral) and when I got back on it wouldn't move in reverse and just creeps fwd. Checked fluid, debris, broken line, linkage etc. Don't see anything. The loader, pwr steering, PTOs & 3 pt hitch all work. Pedals feel soft and don't come back to neutral position on their own? Trying to find a diagram of the linkage and pedal to make sure a pin didn't fall out or something simple like that before going to dealer. Owners manual lacks detail photos.
I'd appreciate any insights/help!
Thanks!
/ 2305 Trans issues #2
Hmm! Never had that problem before. Your probably on the right track as for the linkage. I assume you are getting the same result in high or low gear. Hang in there, someone will come up with something. :thumbsup:
/ 2305 Trans issues #3
Will this help?
/ 2305 Trans issues #5
I had something similar happen in the winter when snow and ice froze around the linkage.
I would look to see if a stick or trash is stuck in the linkage.
/ 2305 Trans issues
Thanks all! It was the linkage. The pin connecting hydro drive lever to the rod fell out. I actually found the pin and washer in the leaves where I was working. That was definitely a blessing!
Thanks again for the help!
/ 2305 Trans issues #7
Good for you! Now enjoy it. :thumbsup:
/ 2305 Trans issues #8
Cool!
Can it be pointed out in the above drawing? Others may want to take a look see at theirs to make sure all is as it should be.
/ 2305 Trans issues
Yep! The parts are #29, #5 & #3. Somehow the spring clip pulled out??? Getting the pin back in was a bit of a challenge. Not much room for your hand.
Case IH 5100 (A64119)
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
Cat 20 KW Light Tower (A64194)
Cat 20 KW Light...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
2006 FREIGHTLINER COLUMBIA (INOPERABLE) (A65643)
2006 FREIGHTLINER...
John Deere D110 Riding Mower (A62679)
John Deere D110...
