Flow questions
/ Flow questions #1
6sunset6
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have a little experience with hydraulics. I thought I knew enough but now I am confused. New log splitter build.
Question 1. 16gpm 2 stage pump has a 1" diameter hose barb for suction. But all the flow specs say 1 inch on suction is good for 12 gpm. at 5 ft/min. My tank has a 1 1/4 FPT outlet after the strainer. I can get a 1 1/4 mpt to 1 hose barb giving 1 inch hose to the pump. Is the 12gpm flow real? Will that restrict the pump to less than 16 gpm?
Question 2 Strainers and filters have options for by pass valves , I guess.
no by pass, 3psi, 5 psi etc. What should I use? I have no plan for a gage on the filter or strainer to indicate plugged.
/ Flow questions #2
Just use 1 1/4 in hose for the suction line.
/ Flow questions
The how do you attach it to the hose barb of the pump which is 1"
Some kind of rubber sleeve 1"ID x 1 1/4 OD " . Piece of hose?
edit Just found some R3 hose 1" ID x 1 1/2 od Thats as close as I can get SO use 1 1/2 R4 hose for suction. That should work.
2020 Ram 3500 Crew Cab Pickup Truck (A61568)
2020 Ram 3500 Crew...
UNUSED WOLVERINE QC5-26-2DG QUICK ATTACH (A62131)
UNUSED WOLVERINE...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59908)
2015 ISUZU NQR 4X2...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
Cat CB24B (A60462)
Cat CB24B (A60462)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
