toxicjeeper
Is that a ball bearing pulley you are using for the additional speeds.
If it is, where did you purchase it ?
no it isnt.. i would have rather used one but was in a bit of a rush to rig it up and try drilling the holes.
3.5 cylinder --I just got mine done 16-gpm 2 stage pump 8 horse it works real good on the smaller wood but I save the big chuncks for the big splitter 6 inch cylinder and 28 gph -2 stage 16 hp koehler lift table 4 way wedge it will split anything but is a little slower I built this one 35 years ago.
I have a gage , have not put it into this problem yet. It is not at 4gpm because it does that as it enters the wood. Most of the time it never even down shifts. I never realized it was running so slow. But it definatly shifts back and forth. I am going to replace that kinked hose first. When I can get to it.Your time factors suggest the pump is running at the 4 GPM rate, and high pressure. Can you verify that.
Do you have a hyd gage installed?
This is a question to those who have built there own hydrolic tanks, i salvaged a peice of square tubing that will serve as my hydrolic tank as well as axle( 1/4 thick). However it has been sitting outside for a while and has rust on the inside...Should i sand blast the inside to clean it out or??? will a coat of paint on the inside hurt anything? I am thinking what will happen to the hydrolic components on initial start-up... and most set-ups i see have the filter on the return side..also can anybody shed some light on baffles? should i add them while i can?
Id be a bit weary of that tube.
Clean well painted metal is best. Rust or other particles and your pump is bad mojo.
I think i will take that sound advise and use this tube as the axle, plus a peice for extra height and buy a new hydraulic tank..they arent that pricey...
