Used M7040
/ Used M7040 #1
dlauffenburger
Warren PA
JD 5425 w/542 Loader
I am looking at a used 2006 Kubota M7040 over the internet and am curious if there is some place on the net that shows the specs of a 2006 or what has changed in the model since then. I have researched the 7040 but everything i have seen is for the current production model which may or may not be what is on the 2006.
Are there any issues with the M7040 tractors? I have seen a couple of post talking about a hydralic issue but am not sure if it was an isolated case or a model problem.
Any thoughts or comments?
Thanks,
/ Used M7040 #2
If he doesn't show up, check with Builder as he has a 7040 he bought used and uses commercially.
/ Used M7040 #3
/ Used M7040 #5
They are very consistant with specs from 06 to current!
/ Used M7040 #6
Art, the newer models (not sure what year the switch was, I believe 08 or 09) are heavier than the first ones. I want to say around 800 lbs heavier. Also slight hp gains. You are right, mostly the same though.
/ Used M7040 #7
I doubt that the new M7040 is 800 lbs heavier than the 2006 model, but I could be wrong. Do you know what they changed to add 800 lbs? I believe that Kubota did add a turbo to the newer models, primarily to meet emissions requirements.
/ Used M7040 #8
The kubota with a cab m6040 went from 4650 to 5450lbs. I dont know about the 7040.
/ Used M7040
HRCARVER,
I contacted Kubota HQ and they sent me the spec sheet for the 2006 M Series.
  • 2006 M7040 Specs from kubota hq.pdf
/ Used M7040 #10
HRCARVER,
Thanks, the weights are different than I thought.
Who did you contact? I'd like to know the weight with the cab.
/ Used M7040
Carver,
I sent them an online email via their Contact Us page on their website, it says that it can take up to 7 days to respond but it only took 1 day.
Dave
/ Used M7040 #12
Good deal. Thanks
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2020 FREIGHTLINER...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
STORAGE FEES (A59910)
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
Case 580 Super M Backhoe (A64047)
Case 580 Super M...
