New built 3pt log splitter
/ New built 3pt log splitter #21
It's a result of surface friction. When you get into actual flow calculations, there are friction coefficients for carbon steel, stainless, copper, brass, etc., also values for new(clean) and used (dirty) as well as corroded. In general non-metallic materials are much rougher than metals. In addition to the friction itself,the rougher the surface, the quicker you will transition from laminar flow to turbulent flow which has a much higher loss.
GRSThegreat- the rails get a little stuff in them but I left about a 1.5 inch gap between the rails and the end plate so that it just gets pushed out. I have found more of a problem with some wood getting wedged under the wings of the wedge. It doesn't seem to bother anything so I just leave that little bit of wood in there.
JJ- Thanks for the info. Looks like I am ok using the 1/2" hose. I think I am going to use one size larger elbows however and adapt it back down as needed. If only they made 5/8" hydraulic hose. seems silly to do all this and then use three 1/2" poppet quick couplers. but since it is for such a sort space in the line it probably makes little diffrence.
/ New built 3pt log splitter #24
There is some logic about QD's, that say that QD size should be one size higher that the hose size to compensate for the reduction in flow through the QD itself.
For example, the 1/2 hose may pass 12 GPM, but the 1/2 in QD may only pass 10 GPM, so a 3/4 in QD would be call for in this example.
/ New built 3pt log splitter #25
Don't underestimate the friction from the crimped hose ends on hyd hose....
Have you ever tried to put a 1/8" punch through a crimped hyd hose end on #4 (1/4") .......on a Gates end your lucky if it goes in....
The friction and turbulence through the smaller dia in the fittings is greater than the hose material itself
/ New built 3pt log splitter #26
wdchyd,
If you crimp a 1/2 in ID fitting on a hose, the fitting should still be 1/2 ID. Are you saying that the hose past the crimp is squeezed down enough to make the passage less that 1/2 in ID. If that is true, is there any way to prevent that.
I suspect, but can not verify that a 1/2 in QD is not 1/2 in throughout the QD, and is passing fluid at a lower ID rating, and that is where is the recommendation comes from to use a larger QD than hose size. The only disadvantage is cost.
/ New built 3pt log splitter #27
wdchyd,
That's exactly what I'm saying....
As I sit here at work I'm measuring a new Gates #8 hose end at the inside diameter where it slips in the hose and it's .390".....and that's before crimping
#6 hose end is .270" ID
#4 hose end is .157" ID
these measurements are BEFORE crimping.....so they'll shrink a little
the #8 (1/2") hose is measured .500" ID
No way of getting around it, it's a fact of life, that's why the gpm ratings at 20 fps of velocity is lower than the same pipe sizes.....
/ New built 3pt log splitter #28
We're starting to get into some technical details here. The area reduction in a fitting doesn't necessarily cause a lot of pressure drop. Pressure drop of a fitting is often calculated by determining the length of straight pipe that is equivalent in pressure drop. Fittings that cause a change of direction are much more significant than those that just cause speed increases and decreases.
I don't have my references handy, but as I recall, for small pipe, a 90 degree elbow might be equivalent to 5 feet of pipe while a sudden decrease to half the diameter and return to the original size might only be a foot or two. A smooth nozzle like diameter change causes very little energy loss.
I'm not really sure how carefully hydraulic fittings are designed, but it wouldn't surprise me if a few elbows in the system would have a lot more effect than the end fittings.
/ New built 3pt log splitter #29
We're starting to get into some technical details here. The area reduction in a fitting doesn't necessarily cause a lot of pressure drop..
It may be just technical details but according to this .......http://www.cylinderservices.net/store.asp?pid=10726......there is a significant (30 to 40%) reduction in recommended flow (using 20 feet per second max) on hyd hoses
look at 1/4" size, it's almost 45% less.......surely it has more to do with hose fittings than elbows.....
I'm sure they didn't pull these numbers out of the sky and they don't mention any elbows
/ New built 3pt log splitter #30
Those tables are based on velocity, not pressure drop. The suction line is limited to 5 feet per second, probably to insure the flow doesn't cavitate. The pressure side is limited to 20 feet per second, to keep the flow laminar. At higher velocities, the flow may go turbulent at obstructions or fittings, resulting in very large losses.
Those tables don't appear to consider the size or configuration of the fittings. There's a note that says you should go to a larger size if you have long lines or a large number of fittings, but that doesn't provide very useful guidance.
/ New built 3pt log splitter #31
Any abrupt change in geometry of the flow profile will cause turbulence at any velocity. The pressure drop is proportional to velocity squared. If the flow profile changes gradually and the flow remain laminar all pressure is recovered and there is no loss (in ideal circumstances). In real world there will be some small loss. Since elbows always cause turbulence they have significant effect on pressure drop.
/ New built 3pt log splitter #32
OTOH, I wasn't figuring that pipe sizes are not the same as what they say too.....1/2" pipe sched 40 is .622" dia and sched 80 is .546" dia...
So refering to JJ's question, it may be the odd sizes of pipe that is more the consideration for max flow conditions....:eek:
/ New built 3pt log splitter #33
This is what I was trying to figure out.
If you put a 1/2 in ID hyd fitting on a 1/2 in ID hyd hose, should you be able to push a 6 in long , 1/2 in dowel through the steel fitting and hose. If not, that indicates the hose was crimped a little to much, and you are now flowing less than 1/2 in capability.
Another thought here is that the hose will expand some with pressure, increasing the ID, except at the fittings.
/ New built 3pt log splitter #34
I see where you're coming from JJ, but 1/2" hose end is not 1/2" ID through the fitting....... .390" to be exact ID for the 1/2" fitting(before crimping)......1/2" ID for the hose Yes..
/ New built 3pt log splitter #35
Can I get a little advice. I have a MF 165 for which I am building a 3pt log splitter. Today I bench tested my cylinder and it worked both ways a little slower than I had hoped(17sec out 14sec in) but perhaps that is being caused by my plumbing. Here is how I did that and I would like to know if this is correct and if not what do I need to do to correct it. I first tied back the control handle on my remote control valve. I then attached a line to the pressure side of the remote QD and attached that to the in port of my valve. I then plumbed the out port of the valve to the other QD line.I am using 1/2 line on all and a 2 spool valve(only using one spool keeping the other in reserve for a log loader later) cylinder is 3.5in x 24in with 1.5in shaft. My tractor has a small valve on top of the lift cover plate that simply says 3pt-aux when placed in aux the remotes work. That is how I am thinking of running the splitter. What say yea.
/ New built 3pt log splitter #36
165massy : that seems reasonable. I have done something similar when I did not have power beyond available. I am going to guess that all the resistance of two valves in series and the plumbing and quick connects all adds up to slow down your cylinder.
/ New built 3pt log splitter #37
That sure is messing up my idea for a 1/2 in ID being exactly that.
I will have to start using my calipers.
/ New built 3pt log splitter #38
Here is what I say.
3.5 in cyl bore
1.5 in shaft
4.5 GPM
Extend speed should be 13.33 sec
Retract speed should be 10.9 sec
Was your tractor running at max? 4.5 GPM is the hyd pump GPM flow at max engine speed.
/ New built 3pt log splitter #39
Here is what I say.
3.5 in cyl bore
1.5 in shaft
4.5 GPM
No that was at flat idle my RPM\PTO gauge is working but missing the needle I need to order a new one just haven't had the extra cash so I didn't want to rev the engine and not know what RPM I was at. I think that speed will work for me if it will give me enough pressure. I can stand a little slower speed and use a 4 way wedge if it will push the wood through. I am going to try pushing the piece first and then the wedge to see which works best but I am betting a stationary wedge will be much better. After i find out for sure then i will know where and what design of work table and log stabilizers I will need.
/ New built 3pt log splitter #40
Here is what I say.
3.5 in cyl bore
1.5 in shaft
4.5 GPM
Ok that being said here is another question. I read somewhere in all my researching that there was an option on the mf 175 & 180 of a "combination valve". This allowed the gpm of the aux and system hydraulics to be combined into one flow stream. Can this be done on a 165 and if so how?
2020 ASV RT120 Forestry Skid Steer (A61166)
2020 ASV RT120...
2024 Blue Diamond Skid Steer Vibratory Roller (A63116)
2024 Blue Diamond...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
