hydrolic remotes q
/ hydrolic remotes q #1
bigbull338
Elite Member
texas
7040 HDC 1153 fel
1st let me say that i dont have the rear remotes on my tractor.an im kinda in a tight,as the baler man wants to use my tractor to cut an rake with.i do have a fel on the tractor.so im going to make an extra hydro hose an plug it into my loader remotes an run things from there.have any of yall ever done something like that.
/ hydrolic remotes q #2
I don't see how that would be a problem. Aren't you going to take the loader off anyway?
i wasnt planning on taking it off.was going to leave it on lock it an unplug the remotes thats needed.an plug in an work from there.
/ hydrolic remotes q #4
Unless the added weight of the loader is needed, I would remove the loader to do those tasks. Much nicer to operate the tractor without the loader and less wear and tear with all the bouncing around.
Just my opinion. ;)
well im used to running with the loader on an have the added weight to boot.
/ hydrolic remotes q #6
In your first post you said...: "im going to make an extra hydro hose an plug it into my loader remotes"
If you meant to say you intend to make an extra 'PAIR of hoses'... that will work... You can NOT run a single action cylinder from your loader control... KennyV
/ hydrolic remotes q #7
Could he not remove the curl hoses from the valve, and plug the work port A, and use work port B.
my thinking was to remove the raise an lower hose an plug into that.itll only be 1 remote as far as i know.but im going to talk to my dealer sat or monday.an see wich remote i need to plug into.
/ hydrolic remotes q #9
Do not use the lift work ports for your hyd source, use the curl work ports. You will need the lift circuit to raise the bucket to get it out of the way.
If your attachment has a control valve, then you would lock the loader valve in curl position, and use the attachment to control the attachment hydraulics.
If your attachments has no control valve, then the curl function will control the rear hydraulics.
thanks JJ after i typed my reply i knew i was wrong that they had tobe plugged into curl ports.i just ordered the hose,its going to cost me $95 for a 10ft hydro hose.
/ hydrolic remotes q #11
How are you going to run the remote hyd on a single hose unless the cyl is a single action cyl?
You can do it with a single hose if you plug the A work port and use the B port for the single action hydraulics.
The reason you plug the A port is so you don't spit fluid all over the place.
If it is double action cyl, use two hoses and plug into the curl cyl work ports.
/ hydrolic remotes q #12
I agree with JJ on this. Use the bucket curl ports. You said you purchased a 10 foot hydro hose, is that an extension hose from your implement? 10 foot just does not sound long enough to reach the mid hydro mount from the implement. And if that is the case, make sure you attach the hose in a way not to get into a tire while turning or able to catch on anything on the ground.
yes its a 10ft extension hose to plug into a single remote hose to reach the loader ports.i know what im doing will work because i made sure of that when i bought the tractor an loader.orginally i was just going to pull along side an plug into my remotes an make the adjustments an then hook up.everything ill run with the tractor requires 1 hydro hose hookup.now if i start pulling a 4 by 5 rd baler ill have to install the rear remotes as they take 2 to run the baler.1 to run the twine tier an 1 to open an close the tail gate.
/ hydrolic remotes q #14
Bull
Let us know how you make out, I may be in the same boat next year as I have no rear remotes on my L5740. I didnt think it would be 95 dollars for a ext hose. That 190.00 dollars may go into a rear remote kit.
Anyone price rear remotes for a Grand L? Any one have instructions for hydralic challenged types Ie specific this goes here type with pictures?:D
Dont know squat about some of the terms I see tossed out hear.
/ hydrolic remotes q #15
My 1st (base) set was $718 (L8335-20 + L8309-2). My 2nd set was $426 (L8336 + L8308). Includes parts, tax, installation. Philip.
im still waiting on my dealer to send the hose to me.to put rear remotes on it would be $750 a set.
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
Case IH 4200 Combo Mulch (A66285)
Case IH 4200 Combo...
(2) FORESTRY TIRES ON RIMS (A64276)
(2) FORESTRY TIRES...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
F-250 Super Duty 4WD 6.2 (A63688)
F-250 Super Duty...
4021 (A59228)
4021 (A59228)
