Mechanic's vise
   / Mechanic's vise #1
MESSMAKER
Bluegrass,KY
DK4710SE
I need one to put on the back of the truck(hitch) for big jobs. I have had no luck with Craigslist or flea markets. Where can I get one that is sturdy, I can handle getting it off the truck by myself(under 75lbs) and will not break the bank?
   / Mechanic's vise #2
Have you searched ebay? i see some there for $65.00, but I'm sure there Chinese. My farrier has one that hooks into his receiver hitch. pretty cool.
   / Mechanic's vise #3
E Bay has a couple of nice looking pre-owned 4 inch Wiltons. I had one mounted on the tail gate of my work pick-up. Very handy.
   / Mechanic's vise #4
I saw one like that the other day. The vise was mounted on a plate that was welded to the 2 inch sq. tube, which obviously slid into the receiver on the hitch. It was neat, but this one was mounted with the jaws sideways, rather than the normal upright position (jaws on the top). I am sure it could have been rotated in 90deg increments, but the jaws would never be on the top. I guess it worked for the guy driving the truck though! :laughing:
   / Mechanic's vise #5
The jaws on the 6" Wilton I have on my service truck will rotate 360deg and has pipe jaws on the other side. The Wilton came on the truck. It is a great vice . So far I havent been able to brake it. After looking up the price of it it should be indestructable.
Bill
   / Mechanic's vise #6
Farrier supply houses are a good place. Harbor freight just sells the cast iron/cheap steel ones that are brittle and can't take a hammer blow without cracking. Try old tool auctions.
   / Mechanic's vise #7
I have a 6" Craftsman. Don't know if its "professional" quality. It serves my needs. I basically used it to hold stuff while I grind or weld and on occasion replace u-joints.
I had it mounted on my work table, but discovered being portable was more beneficial. I cut out the base from 3/8" steel using the vise as a templet and welded a 2" square tube to it.
   / Mechanic's vise #8
Bill
I have an old 5 inch one like that with the name, "Olympia," that I rescued from a scrapper friend. The round slide was broken near the jaws. I welded it back with nickel rod and I really love that vice.
About 35 years ago, I got a Prentiss Bulldog that opens 12 inches. I stole that for $100 back then. The guy was getting wiped out in a divorce and I was lucky to get a bunch of his stuff.
   / Mechanic's vise #9
I bought a 6" one from harbor freight a few years ago when they still had the pittsburg brand with "lifetime" warrenty. It was $60. I like it and havent been able to break it yet. And that includes beating on things with a 3lb sledge, and holding things in it and using a 2' pipewrench and 4' bar on that. It is oe tough vise.
Unfortunatally, I wanted another and they no longer have the pittsburg ones. They are central forge, only 1 yr warrenty, and dont look nearly as stout, and dont have the pipe jaws inside the main jaws:mad:
Whatever you do, dont get HF's "multi-purpose" vise. They are junk. The casting of the jaws is hollow inside and wont handle much torque without snapping the casting.
Something like this might be what you are looking for?? Wilton Multipurpose Vise — 5in., Model# 69999 | Bench Vises | Northern Tool + Equipment
2 year warrenty, and tons of good reviews.
   / Mechanic's vise #10
I have 3 leg vices I use. -different sizes, in different locations. My "portable" one is a small one with the leg folded upwards so I could mout it onto a hemlock stump that held my anvil- travelling forge set up.
I like leg vices because the are made by forging, not cast and are super tough. I could use a sledge on one, dent it and it would still work. They are all used and probably over a 100 years old. 25 was the most I paid. -also called blacksmiths vice. - If you see casting marks and casting rough edges- it is going to be brittle- don't hit it with a hammer. -Learned the hard way.
2018 Gatormade 20+5 Gooseneck Trailer (A52128)
2018 Gatormade...
2019 Harley Davidson (A50324)
2019 Harley...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
International 490 24ft Disc (A52128)
International 490...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
