24x24 addition to existing shop
/ 24x24 addition to existing shop #1
Grayson Klassen
Gold Member
Fort St John, BC
John Deere 4020
We like I dont already have enough projects on the go I gotta finish this one before the snow flies. I will add more pics as I progress.
/ 24x24 addition to existing shop #2
Nice, I like the steel posts. Im going to start a build shortly with steel. Im not building anything out of wood in termite country.
I had the steel screw piles in for a different building that didn't wind up happening so thought I would stick with steel for the frame anyway. Everything after this will be of wood construction.
/ 24x24 addition to existing shop #4
What is the purpose of the offset at the base of the posts?
When the screw piles were originally placed they were lined up in one direction but the other direction was less critical. When the use was changed one pile was out of line by seven inches so i added to the cap and gussetted it.
here is last nights work, by tonight that side wall should be sheeted and tomoorow I will start on the other wall.
Hmmm Picture didn't load here it is
/ 24x24 addition to existing shop #7
What about tin worms?
Didn't get much done last night. Mama had a bad day so spent some time with her. back at er tonight.
Well got a bunch done over the weekend but not as much as I hoped. My BIL dropped off his scizzorlift for a fwe days so hopefully I can get the heavy tall stuff done before I lose it.
Here is a pic of progress
Got some more done this weekend with a little help.
Beams are all in place and have started on trusses. 7 out of 13 up and then strapping and tin. Snow snow stay away LOL :thumbsup:
/ 24x24 addition to existing shop #12
Can you get a close up picture of how those rafters connect to the ridge beam? I'm interested in your methods.
I will try to get a picture tonight, but basically it is a birds mouth notch in both ends so weight sits directly on the beams. Then a plywood plate completing the joint on both sides of the truss.
The last four days has seen a lot of progress. I left early from work Thursday and Friday and finished the rafters. Yesterday two guys from work came over and we got the fascias on and all strapping ( see pic), Thanks Mike and Todd. Today my son came over and we got all but two sheets of roof in on.
Should be as far as I am going this year by this comming weekend.
YAY
PS too dark to snap pic with tin on will grab one tomorrow.
/ 24x24 addition to existing shop #15
Looks great from what I see. Never saw rafters sitting on top of the ridge board,But Ill rember that, It looks good.Well done, Snow will not be a problem.
Army Grunt
Army Grunt
My intention of sitting on top was to keep as much of the force vertical as I could, otherwise cross bracing tends to need to be much larger. The rafter span is only about 11 feet and they are 2x6 select so hopefully LOL they stand up to snow load.
here is a pic I took before I left for work, its a little dark and blurry but shows progress to date. I will rty to take a better one if I get home before dark.
Well some more work got done on the weekend, the roof tin and ridge cap are all done with the help of my son.
The gable end I will tin in and then just tarp in the openings until spring. I have already started putting tha hay that is in the original part of my shop in there so I can finish all my other projects.
On this one I actually beat old man winter! YAY!!!
/ 24x24 addition to existing shop #18
Looks great, I think I would install two 3/8"pieces of cable at the top of the 2x10. to insure they dont go out with snow load.Your frame work will keep it at start, middel, an finish with ease.
Army Grunt
Army Grunt
Not quite sure where you are wanting the cable.
/ 24x24 addition to existing shop #20
I didn't enplane it very good at all, sorry
Tie a piece of 3/8" cable with a eye bolt (3/8') perpendicular to the 2x10. Youll need 2 of each. if your building is say 24 ft from gable to barn ,an you have a cross tie at 12 ft, what I am suggesting is put another one at 6ft. an another one 18ft.what your building will try to do with a heavy snow load is push the walls out the cables will stop this.
Hope this helps
Army Grunt
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2025 Swict 66in Bucket Skid Steer Attachment (A59228)
2025 Swict 66in...
206707 (A58375)
206707 (A58375)
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
