Loader Curl strength
/ Curl strength #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
I have a 3720 with a 300cx FEL. I am wondering if the curl function for the bucket is strong enough. People on this forum always talk about how strong their curl is, and I am having doubts about mine.
For example, I lifted a 1500 # weight box with my pallet forks that was sitting on a pallet. The weight box was about a foot or so from the backstop on the forks.
I could lift this weight with no problem but I couldn't curl it back. It would only hold it level..
Is there any way to test this other than getting a gauge and putting it in the pressure line? If that would be the case, what would the pressure have to be for maximum curl.
Thanks,
Chuck
/ Curl strength #2
You get far enuf forward of the pins and lift is stronger than curl. The transition seems to occur 3 to 4 feet out from the pins. System pressure would have very little effect on the distance at which it occurs -- both would strengthen as pressure rises.
larry
/ Curl strength #3
How high was it?
Curl on pallet forks weakens as you go higher due to geometry changes - you need to keep extending the curl cylinders to keep the pallet level and your triangle collapses.
/ Curl strength
How high was it?
The center of the rectangular block was about 2-1/2 feet from the backstop of the forks. I lifted it up level about 1-2 feet and was going to tilt it back but it wouldn't do anything and I know the curl works with lighter loads. I am assuming as I write this that it is just to heavy along with the distance from the backstop. I thought as long as I could lift it, it should be able to curl it.
/ Curl strength #5
Hmm...based on the specs of the 300cx, I'd say it's reasonable that you couldn't curl a 1500# load 2.5 ft out - but it could go either way. Got any leaks around the bases of the curl cylinders? As others have mentioned, the pressure in the lift & curl cylinders should be the same.
/ Curl strength
Okay, thanks for your input North Country. There aren't any leaks anywhere, and i am starting to think I just am used to the tractor and am expecting it to do more that it should. As far as digging in dirt and digging holes, everything works out okay. I was going to try the weight closer to the fork backing but I have the bucket on and i didn't feel changing it just for a test. Take care.
John Deere 5525 (A60462)
John Deere 5525...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
CASE 586H ROUGH TERRAIN FORKLIFT (A64279)
CASE 586H ROUGH...
CASE 105C (A62177)
CASE 105C (A62177)
2004 John Deere 4720 (A60462)
2004 John Deere...
KMC 13 SHANK CHISEL PLOW (A63291)
KMC 13 SHANK...
