rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,742
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I have a Kubota 3400 with the treadle pedal and for the most part love it. But as always there is a but. We own a marina and use this tractor extensively for moving boats around our facility. When using the tractor a lot like eight to ten hours a day in spring when the boats are going out and now in the fall when the boats are coming back,,,,,,,, the positioning of my foot on the pedal when backing really stresses the right knee thus causing great pain and swelling during the busy season. You may never use your unit as long at one time as I do but you mention arthritis so you might want to try before you buy to make sure it doesn't bother the old joints
I agree. The separate controls like JD has are a lot easier on my old joints than the Kubota treadle rocker is. When I was younger it wouldn't have made a difference, but reaching out sideways to work the Kubota rocker makes my knee and hip hurt. Thinking about it though..... It isn't the rocker so much as the weird position that Kubota's rocker position forces the operator into because the brakes take up the space where the rocker ought to be. Seems odd that Kubota doesn't offer a change-over kit for putting the brakes on the proper side to use them as wheel brakes just as all other tractors do.
But then Kubota doesn't spend much energy on fitting western ergonomics. On my M59 the seat swivels around to use the backhoe.....but there is a large handbrake on a heavy bracket that is welded to the floor boards right where your feet have to go to swivel around. It would have been simple to mount the handbrake on the other side of the seat, but as is, you can swivel the seat, and swivel your torso just fine. But actually turning around requires double-jointed ankles and feet. Hmm.....you know something? That's similar in a way to the ergonomic mistake they made positioning the HST treadle rocker. I wonder if the two mistakes are connected? And if either one is connected with the fact that the seat is a little low?
rScotty
