How often do you powerwash your equipment
/ How often do you powerwash your equipment #41
The only washing is once in the spring with the pwash to get salt off from the winter, once in the fall to get mud off. I don't pwash electrical connectors or near pins. Gets a greasing right afterwords.
Oh I guess I pwash the glass a few times a year so I can see out.
A friend of mine waxes it each year when he borrows it.
/ How often do you powerwash your equipment #42
If I ran a dozer or excavator, I might use a power washer too, but I don't need one for my equipment and how I use it.
We have a power washer, but have yet to need it for any of our tractors or equipment.
/ How often do you powerwash your equipment #43
How often power wash?...... Never! And I too have some very old equipment...not with dozer tracks however. Compressed air and a rag most of the time; and rarely do I use some Gunk and a garden hose. Older models of cars/trucks used to get a Gunk/hose bath occassionally, but not these newer (post 80's) engines. Maybe if one lived on dirt and gravel roads those car engines would really be dirty.....but that would be a losing battle.
/ How often do you powerwash your equipment #44
The tractor gets a good washing about 3 times a years. Sometimes I wash under the fenders and the tires, in between washes, when they are muddy. I always keep the spray from the electrical connections, fuses, grease fittings; etc. I protect the important components from the spray. The tractor gets a good greasing afterwards. The equipment gets washed when necessary, and the bush hog gets cleaned and lubricated before retiring for the winter. And I forgot to mention that my wife reminds me to wash the seat cover at times also.:):laughing:
/ How often do you powerwash your equipment #45
When I power wash my tractors I open the hood and do the engine also.
The first picture is the engine compartment on my 10 year old Kioti DK 35 with 1600 hours. Pictures 2 and 3 are of my 33 year old John Deere 850 with 1800 hours.
You don't keep tractors looking this good by just using air.
Vince
Do you make certain precautions such as cover up with plastic bags items like the alternator/put plastic bags over the oil fill tube, cover up main electrical connections etc?
I do cover up these items when I wash mine down with the hose.
/ How often do you powerwash your equipment #46
Vince
I don't cover anything up. Been pressure washing my motors for years, never had a problem.
/ How often do you powerwash your equipment #47
Do you let everything dry before you start it up? I would be concerned about water getting in a connector and shorting something out.
/ How often do you powerwash your equipment #48
I let the engine cool before I spray it.(Its not good to spray a hot engine with cold water)
No need to let it dry before you start it. I usually start the engine when I'm done powerwashing to let it dry out.
/ How often do you powerwash your equipment #49
Like most of the others I don't PW my equipment to clean it. A leaf blower works well enough. Otherwise a garden hose and a bucket of soapy water...
Bearings and electrical connections don't like high pressure water... brittle plastic parts are expensive ...
/ How often do you powerwash your equipment #50
One thing not brought up about washing down engines is never water down a hot engine...could lead to cracking of the block or head.
/ How often do you powerwash your equipment #51
...you can wash a tractor?
I'll be damned. Learn something new every day.
/ How often do you powerwash your equipment #52
When I finished yesterday, I parked it outside and it is being washed right now as it's raining.:thumbsup:
/ How often do you powerwash your equipment #53
When I first got my tractor I would wash it after every use. Then I would give it a good rubdown with Fluid Film.
Now I wash it maybe every two months, unless I get a lot of mud on it.
/ How often do you powerwash your equipment #54
All my hay equipment (discbine, balers, rakes, tedder) gets hand washed once a year, bucket of soap and the hose. I like doing the hand wash as my hands go over just about every part of the equipment, I see many issues that way long before they break - if just break it's always when you're using the equipment, never good for my BP! ;) Sometimes a prewash of real greasy areas with a solvent soaked rag, just so the soap and water isn't overwhelmed. I try to do this in the fall after the last of the haying is done. Then they get greased, oils levels checked, run for a few minutes, and put away. I'll usually do a spray can touch up of any bare metal as well. Tractors and fertilizer spreaders will get a hose down during the season after spreading.
I have been known to point the pressure washer at a piece of equipment if the equipment is there while I'm washing something else, but generally the only time I pressure wash equipment is when doing some service other than regular maintenance. Got a leaky valve cover gasket on the Case, it'll get washed before tackling that job, for instance.
/ How often do you powerwash your equipment #55
I'm with Vince and 20/20. I regularly use my power washer. I always lube after washing. I've never heard of a bearing/seal failure that could be directly contributed to the proper use of a power washer and proper maintenance.
I also contend that the velocity of an air blow gun a couple inches from the tip is greater than the velocity of water out of a pressure washer a proper distance from the same object. People tend to get very close with an air gun because that's the only way it'll remove grime.
I would never say that it's necessary to power wash equipment. I just like to keep my equipment clean and tidy. I wax my tractors at least twice a year. All my stuff is parked in a heated shop year around.
I run a John Deere motor grader. We buy a new machine every four years. When we traded this Summer the equipment appraiser said he'd never saw a machine with that many hours that looked that good. We received a premium price for our used machine. It got power washed diligently, at least four times a year. And was always serviced after each washing. I waxed it once a year.
This is an interesting thread that has perked some strong opinions. Some with credibility, some with amusing comments. It's all good. :)
/ How often do you powerwash your equipment #56
Thought it looked like you guys were getting some rain, lucky dogs.... We've had a little over an inch since 01 September. I haven't mowed my lawn for a month. Now we are getting freezing temps at night. I'd say the ole JD2210 is gonna change jobs from mowing to hauling in fire wood!!! :laughing:
/ How often do you powerwash your equipment #57
We sure did luck out and it was sorely needed; dry as a bone. We got a good slow rain that soaked in really well; coulda used a bit more, but a lot of people are still cutting beans and need some dry weather.
Our renters just finished cutting our beans the night before it rained.
Yeah, I'm going to pull the cutters off our tractors and store them then put a box blade and back blade on then do a bit of loader work.
I had to retire my chain saws, sure miss working in the woods.
/ How often do you powerwash your equipment #58
...and from the factory, most all the snap electrical connectors will be dry inside, that is, no di-electric grease. Water ingress coes bad things to connector lugs.
We've had problems on motorcycles from washing (bikes stay clean, it's a 'I have to look good' thing so they get washed religiously). I always suggest parting all the connectors and filling with di-electric grease to keep moisture out, even the sealed high quality Molex type connectors.
That applies to my tractors as well. No point in having problems down the road from high resistance in connectors caused by oxidation.
/ How often do you powerwash your equipment #59
Never have I even thought about power washing a tractor....:confused2:
Always figured a buildup of grease was just extra protection....:thumbsup:
just what is fluid film anyway?
/ How often do you powerwash your equipment #60
My tractor sat for 8 months in sea air on the lot before I got it. It's had a number of corrosion issues. This di-electric grease interests me.
2015 Volkswagen Golf Hatchback (A60352)
2015 Volkswagen...
Mini John Deere Truck (A55853)
Mini John Deere...
2012 Freightliner Cascadia (A61306)
2012 Freightliner...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
